Page 16 of 27 FirstFirst ... 67891011121314151617181920212223242526 ... LastLast
Results 151 to 160 of 266
Like Tree2Likes
Thread: RRTMS - RoadRunner tire monitoring system extension plugin
  1. #151
    Maximum Bitrate vicky_obee's Avatar
    Dec 2003
    Quote Originally Posted by Enforcer View Post
    Any way to answer your question, you will need to put an indicator “TMS_SILENT” in your skin to indicate that it is running in silent mode.
    Hi Sorry for being so impatient... Actually bein breaking my head over this for almost a month now...
    Thanks dat you came for my rescue....
    Ok can you pls tell me as what do i have to do SO THAT i can GET the AURAL warnings if the press or temp is lo...
    These are the lines from the .Skin
    I01,219,80,40,71,"TMS_ALERT_FL:B"
    I02,381,79,39,72,"TMS_ALERT_FR:B"
    I03,216,346,40,76,"TMS_ALERT_RL:B"
    I04,385,345,38,74,"TMS_ALERT_RR:B"
    I05,644,28,138,161,"TMS_ALERT"
    I06,693,513,28,18,"TMS_SILENT:B" ( DO I HAVE TO REMOVE THIS LINE )
    I07,288,408,68,71,"TMS_ALERT_ST:B"
    B01,630,507,97,86,"TMS_SILENT","" ( Or DO I HAVE TO REMOVE THIS LINE or both )
    B02,727,507,67,86,"EXIT",""
    if i do it like this /B01,630,507,97,86,"TMS_SILENT","" the red indiacator doesnt work any more and still there is no audio warning..
    ive tried all 3 combinations but still i get no AUDIO warnings..
    The music keeps playing.. ( so it means the vol is ok and not mute )
    Can you pls help from here
    vicky
    Commell LV-677 DC 6 x 6" Mother Board
    2.6 GHz; 1 Gb Ram
    120 Gb Laptop HD
    7" InDash Xenarc MTD - X7000 Screen
    Gyration Mouse ; GPS Mouse ; ELM Scan ; TPMS
    Parrot MK 6000 & iPhone
    Re done the carputer...Into the Glove Box !!
  2. #152
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Taking the lines out of the skin won't change the mode of the plugin.
    You need to leave the indicators and buttons in the skins.
    Pressing the TMS_SILENT button should change between having the alerts audible or silent, the TMS_SILENT Indicator will indicate if it is in silent mode or not.
  3. #153
    Dec 2003
    My friend thats the prob i am facing...
    This is my .SKIN
    can you pls lok into it and tell me what am i doing wrong
    RoadRunner Skin
    RRScreen "TMS"
    /, I, x, y, w, h, Code;INDICATORCODES
    L01,444,348,160,30,255,255,255,22,"Tahoma","TMS_PR ESSURE_RR","LEFT"
    L02,444,387,110,30,255,255,255,22,"Tahoma","TMS_TE MPERATURE_RR","LEFT"
    L03,444,78,160,30,255,255,255,22,"Tahoma","TMS_PRE SSURE_FR","LEFT"
    L04,444,116,110,30,255,255,255,22,"Tahoma","TMS_TE MPERATURE_FR","LEFT"
    L05,36,348,160,30,255,255,255,22,"Tahoma","TMS_PRE SSURE_RL","LEFT"
    L06,36,387,110,30,255,255,255,22,"Tahoma","TMS_TEM PERATURE_RL","LEFT"
    L07,36,78,160,30,255,255,255,22,"Tahoma","TMS_PRES SURE_FL","LEFT"
    L08,36,116,110,30,255,255,255,22,"Tahoma","TMS_TEM PERATURE_FL","LEFT"
    L09,246,499,160,30,255,255,255,22,"Tahoma","TMS_PR ESSURE_ST","LEFT"
    L10,246,538,110,30,255,255,255,22,"Tahoma","TMS_TE MPERATURE_ST","LEFT"
    Y01,"SLIDER_BATTERY\SLIDER_*.gif"
    S01,557,387,47,30,559,77,47,34,H,01,"",0,"TMS_BATT ERY_RR",""
    S02,557,116,47,30,156,77,47,34,H,01,"",0,"TMS_BATT ERY_FR",""
    S03,151,387,47,30,559,532,47,34,H,01,"",0,"TMS_BAT TERY_RL",""
    S04,149,116,47,30,156,532,47,34,H,01,"",0,"TMS_BAT TERY_FL",""
    S05,361,538,47,30,156,532,47,34,H,01,"",0,"TMS_BAT TERY_ST",""
    END
    If I press the button to mute, the indicator Blips and there is no audio..( correct)
    Now when I Un press the Button ( no blips ) still i have have no audio warnings ( wrong)
    Here is where i am either missing something or doing wrong
    Thanks once again
    2.6 GHz; 1 Gb Ram
    120 Gb Laptop HD
  4. #154
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Just read the first post, don't think it is an audible warning.
    “TMS_SILENT” – Silent mode. If active, the plugin will not show any warning
    in silent mode it won't show a warning gif.
    Seeing as it's an indicator you need to find a way to monitor this indicator and when it is on, get a sound to play.
    I think there have been a few questions asked before on how to do things when an indicator goes on. Have a little search around.
    OK, scrap the above, I have just downloaded the source and taken a look at it.
    If SilentMode is false, if there is an alert the screen will switch to the TMS screen (if not already on it) and then sends a say command to RoadRuner to say whatever text is set in RRTMS Config.
    So first check that RR switches to the TMS skin with SILENT MODE OFF, if it does then it is an issue with the say command possibly. If it doesn't switch then it is not handling or getting the alerts.
    Also try using the RRTMS config to test the warning messages.
  5. #155
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    If I recall correctly, The SAY Command only works when set in rr.ini.
    Look at RR.ini for this line.
    voice=false
    if set to false it will not work with the say command.
  6. #156
    Maximum Bitrate boelle's Avatar
    Oct 2008
    Odense, Denmark
    hi
    is it possible to have a setting that prevents the tms screen from poping up even if there is a low pressure condition? of course a small change is needed, but i'm not good at VB or any programming
    Blessed are the "cracked" for it is they who let in the light.
  7. #157
    Nov 2007
    Sydney, Oz
    Why would you want that? The purpose of TPMS alerts is to advise you when there is an unusual condition. You don't want to know if you have a low pressure?
  8. #158
    Oct 2008
    Odense, Denmark
    i want to be able to choose... ad i'm sure a few others want that to
  9. #159
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Have you tried putting it in silent mode?
    That's the button with the head and a line through it.
  10. #160
    Oct 2008
    Odense, Denmark
    the icon with a speaking man? yep
    also tried the icon with the small arrow... but it pops up each time i open RR
  1. Velleman K8055 USB I/O Board Extension plugin
    By 307SW_NLD in forum RR Released Plugins
    Last Post: 02-24-2013, 07:59 AM
  2. Use serial port with extension plugin???
    By guillemasco in forum RR Plugins
    Last Post: 12-04-2006, 07:26 PM
  3. Extension plugin problems
    By festy in forum Road Runner
    Last Post: 06-23-2006, 07:20 PM
  4. Replies: 0
    Last Post: 06-11-2006, 06:49 PM
  5. Extension Plugin help ....
    By Gobby in forum Road Runner
    Last Post: 06-09-2006, 11:27 AM
