Page 18 of 26 FirstFirst ... 891011121314151617181920212223242526 LastLast
Results 171 to 180 of 251
Like Tree2Likes
Thread: RRTMS - RoadRunner tire monitoring system extension plugin
  1. #171
    Maximum Bitrate boelle's Avatar
    Oct 2008
    Odense, Denmark
    there are a small battery in there... it will last for 5 years...
    mine show full battery as i got them a month ago directly from 3rd eye in malaysia
    Blessed are the "cracked" for it is they who let in the light.
  2. #172
    Low Bitrate topjohn's Avatar
    Oct 2009
    France /Wissous
    hummm, so my problem for the future, but before placing the emetor in the wheel but I have watched or we could put the batteries, but I did not find, so I thought it was a battery that reloaded with the wheels.
  3. #173
    Oct 2008
    Odense, Denmark
    you cant change the batterys, it's a sealed unit that bolts to the valvesteam... and it does not transmit data before there is pressure in the tire
  4. #174
    Oct 2008
    Odense, Denmark
    i took an old leaking tire and mounted mine on that... it holds pressure for about an hour... enough to test
  5. #175
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    If they are not used for a while they go to sleep.
    You need to raise and lower the pressure by a minimum amount to wake them up.
    There is a post or thread about it somewhere.
  6. #176
    Oct 2008
    Odense, Denmark
    above 1,5 bar at least and then below... pump up again a bit above your setting and then hit learn and let out a bit of air
  7. #177
    Oct 2009
    France /Wissous
    Here is the original box sensors
    Here is what I have with the TMPS Doctor
    I bought the material used (already changed) there are about 2 years, I did a test right away, but it did not work, I thought they were absolutely set on wheels to make function.
    But even in the wheels, it still does not work ...
  8. #178
    Oct 2009
    France /Wissous
    Quote Originally Posted by Enforcer View Post
    Or is the post that talks about that?
    I do not speak much English at all, I use the google translator and it is therefore difficult to search
  9. #179
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by GizmoQ View Post
    Also, if I remember correctly the sensors go into sleep mode when below a certain pressure for some unspecified time to conserve the battery. Pressure has to go above 15PSI and back down 5PSI to wake them up.
    Oooooh, that's good to know.
    Quote Originally Posted by CannonBaller View Post
    FYI.
    I can confirm that the Sensors were in sleep mode.
    installed my new tims today and drove a bit. All sensor data now shows up in the plugin.
    Turning off the car for a 10-15 mins, and turning it back on, brought the sensor data up immediatly.
    So not sure what the timeout interval is.
    Anyway...All good.
    TPMS Sensor package works as advertised.
    It was in this thread
    Above is the conversation.
    I also think it was mentioned somewhere else
  10. #180
    Oct 2009
    France /Wissous
    Ok thank you, I'll do it just now.
    So if I understand correctly, I must put my wheels 0,3BAR (or less) and put under pressure to normal after.
  1. Velleman K8055 USB I/O Board Extension plugin
    By 307SW_NLD in forum RR Released Plugins
    Last Post: 02-24-2013, 06:59 AM
  2. Use serial port with extension plugin???
    By guillemasco in forum RR Plugins
    Last Post: 12-04-2006, 06:26 PM
  3. Extension plugin problems
    By festy in forum Road Runner
    Last Post: 06-23-2006, 06:20 PM
  4. Replies: 0
    Last Post: 06-11-2006, 05:49 PM
  5. Extension Plugin help ....
    By Gobby in forum Road Runner
    Last Post: 06-09-2006, 10:27 AM
