that is truly awesome, well done
EXCELLENT!!!!!! You build it, they will come!!! I SOO want this!
CAR:2001 Ford Crown Victoria
PC: Acer EEE 900HA with Win7 with CF 2.0.
Memory:1G
Drives:160gig
WI-FI:Cingular
GPS:IG2k9
Screen:Xenarc 700TSV
The Florida Meets Thread
Well i dont know about anyone else but i think this is one of the best Plugins I have seen for RR since i have been using it!
Shame i havent had the know-how to do this before but hey!
Im working on the hardware side of things, il post any updates on the other detailed thread!
Wow, fantastic work on the hardware, skin, and configuration utility! Just wish there was a current place to buy the "whole package".
Over here in the U.S. we use PSI (Pounds per square inch) and not Bar's. In preparation to the hardware becoming avail, is there a way you could add a math conversion into the extension plugin to measure in PSI? Possibly just a check mark / drop down list in your config utility? I have never personally seen a tire pressure gauge, compressor or such using Milibar's here.
Secondly, another very useful addition, would be the ability to have a "Add Air" mode button on the skin. Pressing this & then adding air to the tires would sound an audible tone, speech or something to let you know you are at the correct pressure. It would save on adding air, checking with a gauge, adding more air, checking with a gauge... Adding air, OOPS too much...hisssssss.![]()
My Fiero Build Thread
Robby has already done that John! you can change it in the settings (second picture down!!)
Oh and just another thing... robby's software has the capability to set a maximum pressure too so when you could set that to say 32PSI or whatever havee your pc running and when pumping up your tyres when it reaches that the alert will come up "Tyre pressure acheived "
the links for the binary and surce code dont work
can i get them ?
work for me.
