Page 21 of 27 FirstFirst ... 1112131415161718192021222324252627 LastLast
Results 201 to 210 of 266
Like Tree2Likes
Thread: RRTMS - RoadRunner tire monitoring system extension plugin
  1. #201
    Maximum Bitrate boelle's Avatar
    Oct 2008
    Odense, Denmark
    maybe the data from the tpms board in your system is different but the same chip? can you make a good closeup of the pin cloest to the blue cap? (top left one)
    Blessed are the "cracked" for it is they who let in the light.
  2. #202
    Low Bitrate topjohn's Avatar
    Oct 2009
    France /Wissous
    which component are you talking about?
    the cube with the blue dot?
  3. #203
    Oct 2008
    Odense, Denmark
    The solering in the red circle... i made sure that the small smd thing under the soldering was ok but i think the most important thing is that you solder at the end away from the edge of the board
    i checked my board and they look very much the same. will do a more close check after i have got some sleep
  4. #204
    Oct 2009
    France /Wissous
    Just because I redid the solder when I looked closer to the beginning, it was not welded to the end.
    So I remade a complete weld.
    can be made is still wrong!
    I will try to repeat again
  5. #205
    Dec 2006
    India
    IIRC, there was a revision made in the TPMS PIC microcontroller from Robby to accommodate the new sensors from 3rd Eye. I'm not sure what the new version is called, but the old version was 1.0 which your chip also shows!.
    If you've purchased the TPMS PIC microcontroller only recently this should not be a concern.
    May be its worthwhile to PM Robby to ascertain the facts.
  6. #206
    Oct 2009
    France /Wissous
    Quote Originally Posted by DigitalVampire View Post
    I do not think Robby is still active on the forum, and I do not know how to contact him, it actually may be a problem updating.
  7. #207
    Oct 2008
    Odense, Denmark
    The soldering looks ok, i only asked to make sure, it's the most tricky of the 4 pins
    Also your boards looks excatly like mine, even thou the box does not look like the one from 3rd eye I think 3rd eye made it like an OEM and sold it to the company where yours are from. 3rd eye also make the set for peugeot.
    Robby has not been on the from since 21. march.... but your board look very much like those Dejan makes. Maybe he can help you out.
    http://www.mp3car.com/vbulletin/members/_dejan_.html
  8. #208
    Oct 2009
    France /Wissous
    Thank you I will try to contact him, the problem is that I do not speak English very well and I go through the google translator, so it's not easy for me to understand. lol
  9. #209
    Oct 2008
    Odense, Denmark
    dont worry, I think he will understand.
  10. #210
    Sep 2009
    Sorry, but does this plugin work with Win 7?
    RRTMS.dll not reg under it...
  1. Velleman K8055 USB I/O Board Extension plugin
    By 307SW_NLD in forum RR Released Plugins
    Last Post: 02-24-2013, 07:59 AM
  2. Use serial port with extension plugin???
    By guillemasco in forum RR Plugins
    Last Post: 12-04-2006, 07:26 PM
  3. Extension plugin problems
    By festy in forum Road Runner
    Last Post: 06-23-2006, 07:20 PM
  4. Replies: 0
    Last Post: 06-11-2006, 06:49 PM
  5. Extension Plugin help ....
    By Gobby in forum Road Runner
    Last Post: 06-09-2006, 11:27 AM
