Page 22 of 26 FirstFirst ... 121314151617181920212223242526 LastLast
Results 211 to 220 of 251
Like Tree2Likes
Thread: RRTMS - RoadRunner tire monitoring system extension plugin
  1. #211
    Low Bitrate mnwcsult's Avatar
    Mar 2007
    Maryland, USA
    I have lost my 3rd Eye TPMS instruction sheet. I recently rotated my tires and need to switch sensor settings.
    Does anyone here have a scanned copy of the guide book? Or would post the instructions for relearning the whole setup?
  2. #212
    Maximum Bitrate boelle's Avatar
    Oct 2008
    Odense, Denmark
    just got it fully working here, the skin does need to have spare tire added thou
    but, yep there are a but: in tpms doctor it says battery full, but in plugin its almost half way down, others that have noted that?
    EDIT: my ini is edited so it shows the info from spare tire on all tires... just so i can test indoors
    EDIT2: I have used enforcers corrected plugin so that i can keep it true silent
    EDIT3: Also tried the ver from robby still the same
    Blessed are the "cracked" for it is they who let in the light.
  3. #213
    Oct 2008
    Odense, Denmark
    anyone ever had trouble with the learn process?
    i had some trouble... for some tires i had to almost empty the tire and then fill it up...
    some was wuick to do while other was slow.... some never got learned...
    status is that spare tire is ok... and 2 road tires show data... but one is way off.... it shows 4,4 bar and 112 degrees C.... the pressure is in fact 2 bars and 0 degrees C
    input welcome
  4. #214
    Oct 2008
    Odense, Denmark
    URGENT HELP needed.... have anyone discovered that they could read pressure in TPMS doctor but not in RR? i tried skintool and the data do not get to the dll it seems...
  5. #215
    Oct 2008
    Odense, Denmark
    btw... how many are using this plugin these days?
  6. #216
  7. #217
    Oct 2008
    Odense, Denmark
    i'm trying too.... just this thing that the DLL only reports --bar and tpms doctor have no trouble at all
    and even on a fresh install and dll's regged as admin
  8. #218
    May 2008
    Bend, OR
    Quote Originally Posted by boelle View Post
    Where did you find enforcer's version of the plugin? I'm just starting to install mine today.
  9. #219
  10. #220
    May 2008
    Bend, OR
    thx got it # 162
  1. Velleman K8055 USB I/O Board Extension plugin
    By 307SW_NLD in forum RR Released Plugins
    Last Post: 02-24-2013, 06:59 AM
  2. Use serial port with extension plugin???
    By guillemasco in forum RR Plugins
    Last Post: 12-04-2006, 06:26 PM
  3. Extension plugin problems
    By festy in forum Road Runner
    Last Post: 06-23-2006, 06:20 PM
  4. Replies: 0
    Last Post: 06-11-2006, 05:49 PM
  5. Extension Plugin help ....
    By Gobby in forum Road Runner
    Last Post: 06-09-2006, 10:27 AM
