Page 23 of 26 FirstFirst ... 1314151617181920212223242526 LastLast
Results 221 to 230 of 251
Like Tree2Likes
Thread: RRTMS - RoadRunner tire monitoring system extension plugin
  1. #221
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by steven765 View Post
    Where did you find enforcer's version of the plugin? I'm just starting to install mine today.
    thx got it # 162
    Now in first post of thread.
  2. #222
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    I have now Updated the plugin to work with the new Dynamic Menus (This of course means I have also done Carwings skin files) Hope Robby doesn't mind - Enforcer
    See first post for download button.
    This is based on the 1.40 source and includes the Silent Alert fix.
    E.
  3. #223
    Newbie whteglve's Avatar
    May 2006
    Clemmons, NC
    Ok I've tried doing a reconfig using "RRTMS Config.exe" several times trying to fix my problem. When I run RR it stills shows KP and not PSI; also Celsius and not Fahrenheit. The "RRTMS.INI" says pressure=2 and temperature=1. What could it be??
  4. #224
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    those are the default settings, which means the plugin is not reading from the rrtms.ini
    Which version are you using?
  5. #225
    May 2006
    Clemmons, NC
    I'm using the 1.40 version. On a i7 Win7 box with 8GB RAM.
  6. #226
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Robbys 1.40 version reads the rrtms.ini in the plugins folder (in theory) (he has used app.path which could mean it will try to read a rrtms.ini in RR's root path.)
    Also if you are using Win7 unless you run the "RRTMS Config.exe" as admin it may not be able to write the new settings to rrtms.ini
    *edit
    I also notice the orginal plugin likes the ini to have spaces after the keyname (not sure whether it is important) but check for that also.
    ie
    PHP Code:
    [UNITS OF MEASUREMENT]
    Pressure =2
    Temperature
    as opposed to
    PHP Code:
    Pressure=2
    Temperature
    *edit2
    You could always try my updated version in the first post.
  7. #227
    May 2006
    Clemmons, NC
    WOOHOO!!! I figured it out. The "RRTMS Config.exe" placed a copy of the "RRTMS.ini" in two different places. One was a small one (29bytes) under RR/Plugins/RTMS. The other was a large one (2kb) in Libraries/Docs/RR/plugins/RRTMS. I changed the smaller one to match the larger one and bingo it works.
  8. #228
    Dec 2006
    India
    Many thanks for the update!
    Would it be possible to have a couple of features added to a later version to cover some of the deficiencies of the existing plugin/system?
    • Higher/configurable data refresh rate: I guess the current implementation checks for updates in the microcontroller (uC) register every 30 seconds only. In case of fast leak, this may not be sufficient as I experienced in one such practical case wherein the system alerted much after the tire was completely flat. I guess moderns CarPCs can easily keep up with a 3-5 second refresh rate.
    • Time Stamp: To see when the last data was received from each sensor to determine if the value is stale or valid. The uC does not seem to have an RTC to time-stamp the data received from the sensor, but I guess it would still be beneficial to time stamp based on system time.
  9. #229
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    The current refresh rate is 10 seconds.
    I'm not sure what extra info is available from either Robbys PIC or the the devices as far as timestamp is concerned.
    I will not be making any major changes to the RRTMS plugin, I was just bringing it up to date with the new RR and Carwings skin.
    However I am doing a TPMS plugin for FreeICE based on RobbyBMWs orginal RR Code and in doing so will mirror any new functions to a RRTPMS plugin.
    The Version I have working so far has user changeable refresh rate (secs) and I will look at doing a timestamp.
    However the timestamp will probably be based on last time the data changed, that I think is the only way of knowing that it is a new reading.
  10. #230
    Dec 2006
    India
    Quote Originally Posted by Enforcer View Post
    I think that would be perfect!
    Thanks!!!
  1. Velleman K8055 USB I/O Board Extension plugin
    By 307SW_NLD in forum RR Released Plugins
    Last Post: 02-24-2013, 06:59 AM
  2. Use serial port with extension plugin???
    By guillemasco in forum RR Plugins
    Last Post: 12-04-2006, 06:26 PM
  3. Extension plugin problems
    By festy in forum Road Runner
    Last Post: 06-23-2006, 06:20 PM
  4. Replies: 0
    Last Post: 06-11-2006, 05:49 PM
  5. Extension Plugin help ....
    By Gobby in forum Road Runner
    Last Post: 06-09-2006, 10:27 AM
