Page 26 of 27 FirstFirst ... 161718192021222324252627 LastLast
Results 251 to 260 of 266
Like Tree2Likes
Thread: RRTMS - RoadRunner tire monitoring system extension plugin
  1. #251
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by HiJackZX1 View Post
    I dropped this idea. I am just going to have to wait till a TPMS Android App is made. I really want my project to be more Android centric. Yes I will still have a PC, but its really only for 7.1 audio processing, BT headset emulation, hotspot creation, media storage, also amp-screen-inverter control, etc. All media and car stuff I want Android. I read that Alok was making a BT version of the TPMS and that it would have an Android app. I wasnt clear on his answer on whether or not that app would work on people with the USB version.
    Well I'm not going out of my way to do anything with it yet.
    But when my focus goes onto FITPMS both an RRTPMS and a android app may be a by product.
    However no promises.
  2. #252
  3. #253
    Jan 2006
    Dublin, Ireland
    I've bought The 3rd Eye kit and I have the Robby Board too. I've chopped the 3rd Eye board in half and am soldering it to the Robby Board. Is there just the two pins (jp3) on the end of the board (the opposite end from the USB connector) ?
  4. #254
    Raw Wave SNOtwistR's Avatar
    Nov 2009
    Keswick,On Canada
    There are 3 connections from the cut board to the base board as seen in picture. you need to scrape the coating off on the one spot before soldering SNO
  5. #255
    Jan 2006
    Dublin, Ireland
    Many thanks,
    Whatever doc I have, wherever I found it, makes no reference to connecting JP1 and JP2.
    For the connection onto JP1 (bottom right of your photo) do I need to bring a leg off JP1 to the arrowed side of that on-board component, connecting only at the point under the marking B8 ?
  6. #256
    Nov 2009
    Keswick,On Canada
    you need to bend a pin over that component but it does not matter which side of component you solder to, that component is not used after you cut the board, the opposite side you need to scrape off the coating before you solder to the trace. Hope this is clear enough for you. SNO
  7. #257
    Jan 2006
    Dublin, Ireland
    Hi all,
    I bought the set of 3rd Eye sensors on eBay and then bought the Board needed to adapt it for the CarPC. I have chopped up the 3rd Eye board as specified and soldered it to the new USB board. However, after running RRConfig, it seems to see nothing.
    Is there any way of telling if I have made the new USB board correctly ? Or if my sensors are dead ? The instructions originally seemed to confirm that the sensors would become active when a tyre was pressureised. Or do I have to run the Config tool, and deflate and re-inflate each tyre one by one ?
  8. #258
    Nov 2009
    Keswick,On Canada
    let me see some pictures of your board and do you have the sensors in your tires now? SNO
  9. #259
    Jan 2006
    Dublin, Ireland
    Thanks SNO. The sensors are already inside the tyres
    Here is the module
  10. #260
    Nov 2009
    Keswick,On Canada
    Does windows see the device in device manager? should show as hid device. SNO
    Also have you tried TPMS Doctor its a robby made app for testing http://twintower.homeip.net/twintowe...octor-1.30.zip
  1. Velleman K8055 USB I/O Board Extension plugin
    By 307SW_NLD in forum RR Released Plugins
    Last Post: 02-24-2013, 07:59 AM
  2. Use serial port with extension plugin???
    By guillemasco in forum RR Plugins
    Last Post: 12-04-2006, 07:26 PM
  3. Extension plugin problems
    By festy in forum Road Runner
    Last Post: 06-23-2006, 07:20 PM
  4. Replies: 0
    Last Post: 06-11-2006, 06:49 PM
  5. Extension Plugin help ....
    By Gobby in forum Road Runner
    Last Post: 06-09-2006, 11:27 AM
