where do i download roadrunner as a executable ?
Printable View
In the config app, when you chang the units to degrees F, does it change the units used to enter the data in the app as well? I would just download and see but I dont have a computer at the moment (at an internet cafe)
Now if I could find a 3D picture of a Vibe to replace the BMW, it would be perfect. :lol:
It is not essential, you can use also a 2D picture :lol:
You mean like this? Top view of an S60
http://www35.homepage.villanova.edu/...tms_teeser.jpg
Maintaining correct tire pressure saves you fuel, protects against tire wear, and guards against dangerous loss of traction. Keep track of your tires in real time with Hella's TC-400 tire pressure/temperature monitor system.
The TC-400's four sensors transmit the tire data to the cockpit display, saving your hands from getting dirty every time you want to check your tires. You can change the display's background color to match your car's lighting. This kit comes with everything you need to monitor your car's four tires.
Note: The remote sensors replace the valve stems in your vehicle's wheels. Proper installation, tire replacement, and wheel balancing should be performed by a professional mechanic.
Details:
tire pressure monitor system
4 wireless in-wheel sensors
display with choice of 7 background colors
warning buzzer and graphics
2-stage low pressure alerts, fast leak alert, high-pressure and -temperature alerts
warranty: 1 year
Top of page
Is this kit able to comunicate with ours car pc throug USB?
