Page 4 of 22 FirstFirst 1234567891011121314 ... LastLast
Results 31 to 40 of 217
Thread: RRTMS - RoadRunner tire monitoring system extension plugin
  1. #31
    Low Bitrate erricson_nguyen's Avatar
    Feb 2007
    LA ca
    Quote Originally Posted by Robby BMW View Post
    Is this kit able to comunicate with ours car pc throug USB?
    oh gezz i felt like an idiot lol. why didnt i think of that b4 asking
    well i guess this's a stand alone kit
  2. #32
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    The one that robby refers to is supposed to be standalone, he has just made a bit of electronics that intercepts the signals and connects to the PC's USB. (he's also done the necessary software).
    Or maybe possible to do the same to your one.
  3. #33
    Maximum Bitrate Robby BMW's Avatar
    Aug 2005
    Italy
    Quote Originally Posted by erricson_nguyen View Post
    Don't worry
    I asked because I doesn't understand if that TPMS kit is provided of a comunication port and you was looking for a way to connect it to the PC or if you have asked if is possible to use it with my software.
    _______________________________________
    Car installation 95% [■■■■■■■■■■■■■■■■■■■]
    Current project: Parking sensor USB interface
  4. #34
    FLAC Sal R.'s Avatar
    Aug 2006
    Sun Diego
    Suggestion:
    Since the stems/sensors are color coded, anyway to use colors instead of sensor number w/ the option to use those labels in the skin?
    It'll make moving sensors around less...annoying...trying to remember which sensor number is associated w/ a color. (i.e. rotating tires)
    That was a real PITA w/ my SmartTire system. Always had to keep a list of which sensor was which color and the tire location.
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
  5. #35
    Aug 2005
    Italy
    There isn't any reference at the sensor number in the skin.
    Perhaps are you talking about the section "Sensor location" in the config utility?
  6. #36
    Aug 2006
    Sun Diego
    Yeah, the sensor location in the config. In addition to numbers, or instead of numbers, a color can be assigned since the sensors are color coded too.
    On top of that, a label could be added/created w/ the plugin so you can see in the skin which color sensor is associated with a specific tire for quick verification so you don't have to keep opening the config utility all the time.
  7. #37
    Aug 2005
    Italy
    It's a good idea, I will give a look in it after the 26st because the next week I will be traveling in Spain.
  8. #38
    inh
    inh is offline
    Jan 2007
    Fort Riley KS
    Better idea!
    In the config app, make so you have 5 sections, numbered 1-5, and then you can assign a sensor to each number. Then, next to each wheel on the car diagram, instead of 'learn' just make a little drop down combo box, and select the sensor 1-5. That way when you rotate tires, just gotta open the config and change which sensor number is at each wheel.
    Or instead of sensor numbers, you could do it by the colors on the sensors themselves =]
    cashtexts - Earn money for receiving text messaged offers
    cashtexts review not a scam
    Space Navigator - 6 Axis input device: Take it apart - Driver App
    RRCam - Video/webcam capture, text overlay, and recording: 2.0 Stable
  9. #39
    Aug 2005
    Italy
    The "Learn" button can't be replaced by the drop down lists, but it's posible to move the 5 drop down lists near each buttons.
  10. #40
    inh
    inh is offline
    Jan 2007
    Fort Riley KS
    Why cant it be replaced? Certainly you can move the learn buttons over to the side, next to the numbers 1-5 (or colors) for each sensor (in my suggestion above), and just have the drop downs by the car diagram, right?
  1. Velleman K8055 USB I/O Board Extension plugin
    By 307SW_NLD in forum RR Released Plugins
    Last Post: 12-25-2011, 04:15 PM
  2. Use serial port with extension plugin???
    By guillemasco in forum RR Plugins
    Last Post: 12-04-2006, 07:26 PM
  3. Extension plugin problems
    By festy in forum Road Runner
    Last Post: 06-23-2006, 07:20 PM
  4. Replies: 0
    Last Post: 06-11-2006, 06:49 PM
  5. Extension Plugin help ....
    By Gobby in forum Road Runner
    Last Post: 06-09-2006, 11:27 AM
