Originally Posted by
bes51659
Only problem I have left is a problem I started to get when I moved the receiver from the USB in the back to the hub under the dash. I get "unknow device" and "not connected" a lot, but not always. If I disconnect and reconnect the plug it works fine. Rebooting PC or restarting TPMSDoctor is not enough.
On the same hub is only my OBDII and a cable for extra's like ipod etc. They work fine. The hub is active but the DC/DC (15W) also drives the DVD (10W max), so there should be sufficient power. I have cut 5V and GND in the USB cable from the back to the front of the car to avoid ground loops.
I have had difficult USB problems so I have looked into that a lot, and cannot see what is wrong, and I am 95% sure its not a power problem. I have 10 or more device not giving me any problems anymore. How much power does the receiver need?
