Page 9 of 22 FirstFirst 12345678910111213141516171819 ... LastLast
Results 81 to 90 of 217
Thread: RRTMS - RoadRunner tire monitoring system extension plugin
  1. #81
    Low Bitrate mnwcsult's Avatar
    Mar 2007
    Maryland, USA
    The solution
    Quote Originally Posted by mnwcsult View Post
    I get "unknow device" on one of my computers the car computer. I have tried this device on three computers and on two them it works. I have tried thorugh direct connection and thourgh hubs.
    Does the device work differently through USB 1.1 and USB 2.0 devices? My guess is ??? I would not think that it would work through multiple hubs. In my setup there are two chained hubs to the front of the car. There are direct connection at the back of the computer.
    On the direct connection at the back of the computer I think those are USB 1.1.
    Any ideals?
    My carputer is a VoomPC II with front and back panel USB hubs. The front panel hubs are diasy chained to external Logitech premium 4 port hubs. The back panel hub is not in use (I thought).
    Note: The Logitech Premiums are way cool black in color with green indicator lights showing at a glance active USB devices.
    I had to go into control panel and look the power requirements of each of the hubs on the system. It turned out that my rear panel hub which would allow for a direct connection is actually "hosting" the Sierra Aircard in the nearby pcmcia slot as a USB device and it it drawing the full 500 ma.
    Solution was to provide additional power to the external hubs. Once I did that the TPMS device activitated and was recognized properly by XP and the TPMS Doctor program.
    Exact steps
    Start Control Panel -> Device Manager -> Universal Serial Bus
    You will see many entries, here you are interested in only the ones that specifically say "HUB", i.e. "Generic USB hub" or "USB root hub". Right click on first one and select properties. On the property panel you will see the "Power Tab". You will see Total amount of power available to each port on the hub. Also what is connected, power requirements of the connections, and finally number of ports still available. Repeat for each hub you have installed.
    -Michael
  2. #82
    Maximum Bitrate Robby BMW's Avatar
    Aug 2005
    Italy
    Quote Originally Posted by bes51659 View Post
    Thanks for your replies Robby. My questions in this matter was regarding learning process and problems that might occur _during_ mating, so we missunderstood eachother there.
    Oooh! Sorry, I had misrepresented your question.
    During the "learnig procedure", the PIC, besides to not save any identical sensor ID, it takes into consideration only the sensors in "pressure alert mode" state, so, unless you don't deflate simultaneously two tyres, it's virtually impossible to pick the wrong sensor.
    _______________________________________
    Car installation 95% [■■■■■■■■■■■■■■■■■■■]
    Current project: Parking sensor USB interface
  3. #83
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    Robby, any chance you can update the plugin for the new RR release.
    The battery indicators are not working anymore as the code changed.
    Also the parking sensors need updating for the indicators.
    Thanks Manny
  4. #84
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Fixed thread title misspelling.
    Want to:
  5. #85
    Aug 2005
    Italy
    Quote Originally Posted by MGD View Post
    Thanks Manny
    Fixed!
    A new version (1.40) as been released in the first post of this thread.
  6. #86
    Aug 2005
    Italy
    Quote Originally Posted by Bugbyte View Post
  7. #87
    Maximum Bitrate boelle's Avatar
    Oct 2008
    Odense, Denmark
    what the status on this? any chance of a complete kit?
    EDIT: cant download from link i first post
  8. #88
    Oct 2008
    Odense, Denmark
    just got hold of the software and did install pr instructions... but so far it does not show up in menu
    useing newest RR with default skin
  9. #89
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I've added more download links to th the first thread.
    Ride Runner RR's Myspace
  10. #90
    Nov 2008
    I have just installed this plugin it works great in RR but when I load the config I get an error message.
    "Component 'MSCOMCTL.OCX or one of it's dependecies not correctly registered: a file is missing or invalid'
    Can anyone help?
    Thanks James
  1. Velleman K8055 USB I/O Board Extension plugin
    By 307SW_NLD in forum RR Released Plugins
    Last Post: 12-25-2011, 04:15 PM
  2. Use serial port with extension plugin???
    By guillemasco in forum RR Plugins
    Last Post: 12-04-2006, 07:26 PM
  3. Extension plugin problems
    By festy in forum Road Runner
    Last Post: 06-23-2006, 07:20 PM
  4. Replies: 0
    Last Post: 06-11-2006, 06:49 PM
  5. Extension Plugin help ....
    By Gobby in forum Road Runner
    Last Post: 06-09-2006, 11:27 AM
