Page 11 of 15 FirstFirst ... 23456789101112131415 LastLast
Results 101 to 110 of 150
Thread: RRCam 2.0 Final
  1. #101
    FLAC Nomader's Avatar
    Apr 2006
    Greece
    i run setup.. it got stuck installing Net 3.5 SP1.. so i downloaded the SP1 standalone.. installed it then run setup again.. it installs it all right.. then it does not even run...nothing just this msg right away.. i only have one webcam connected no other devices
  2. #102
    Maximum Bitrate tempgp's Avatar
    Jun 2007
    New York
    welll sounds like either framework error or video library doesnt like Vista... let me add rebuild the application with debug handling....
    i dont have Vista so you will be my eyes ;-)
  3. #103
    Jun 2007
    New York
    ok i have debug mode completed but i gotta get out... so bare wih me... ill get back in 30 min and post the app for you
  4. #104
    Jun 2007
    New York
    ok i have posted the debug version of the app for Vista
    also I startted new thret as this one is really should be about RRCam 2.0 and not my app.
    For New Camera Plugin Flow the link Below
    http://www.mp3car.com/vbulletin/rr-p...ml#post1265791
    Acura / Honda A/V CarPC Adapter GA-NET+
    Centrafuse Garmin Mobile PC Skin - GMPC Rebellium Skin
    3D Tuning and Car Visualizer - Preview your car in 3D, change paint job and rims
  5. #105
    Jun 2007
    New York
    new preview is added to new thret for Road Camera HD
    Change Log
    0.1.2.10
    New Features:
    -Text Overly for Time
    -Text Overly preset for GPS
    -Mirrow Button
    General Notes:
    Left screen shows unpocessed images, right screen adds oberlys as result of opeation
    we loose come FPS for that.
    Bag Fix:
    None
    Known Bugs:
    Not Compatible with Windows Vista
  6. #106
    Jun 2007
    New York
    ok i'm happy to announce that the core of applicaton is done. It still needs few fixes but now only thing left is to do the config file and RR integration
  7. #107
    Jun 2007
    New York
    can some one help me out with getting the GPS data from the RR into my APP?
    I cant figure the staff out the forum postins on the topic
  8. #108
    Apr 2006
    Greece
    tell you what..why don't you access the gps data natively from the com port, that way people can use a com splitter, one for the gps software and one for the camera, that would make your app work with more front ends..(though i am a fundamental RR user ) i believe that would be faster too.. you can use "gps speed" "coordinates" natively from the com port
  9. #109
    Jun 2007
    New York
    i can put that as an option BUT processing NMEA does take some CPU and if RR alredy does it then it is better to use it from RR. Well I will do as u asked to have 2 options one is RR (as lond as i can figure how to do that) and second one from GPS directly.
    PS: GPS does not send the speed it only sends coordintates and service info and ten you can calcolate the speed from change from point A to point B (at least thats what I know)
  10. #110
    Aug 2004
    Germany
    You have to create an object to the rr sdk, then you can poll the information from it. In AutoIt the code looks like this:
    Code:
    $rr=ObjCreate("RoadRunner.sdk")
    $speed=$rr.getinfo("GPSSPD")
    $lat=$rr.getinfo("GPSLAT")
    $lon=$rr.getinfo("GPSLON")
    I guess it's similar with other programming languages.
  1. Core Duo / Core 2 Duo Mini-ITX boards
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 10-03-2010, 10:30 PM
  2. Canīt get DirectX to work
    By Linde in forum Software & Software Development
    Last Post: 10-19-2007, 07:35 AM
  3. SD crashes on startup
    By mangus580 in forum StreetDeck
    Last Post: 10-05-2007, 11:14 AM
  4. USB 2.0 issues PLEASE HELP!
    By Kamakazie2 in forum General Hardware Discussion
    Last Post: 10-23-2006, 07:25 AM
