Page 2 of 15 FirstFirst 123456789101112 ... LastLast
Results 11 to 20 of 150
Thread: RRCam 2.0 Final
  1. #11
    Maximum Bitrate vicky_obee's Avatar
    Dec 2003
    Yes the config file i tried to modify...from position 0,0 to 10,90 ( just trying to get it sync with the Dfx 1024 x 768 screen
    and the size to 645,480...
    The size changed ... but the position wont move.....
    Well i am uisng the latest version of Dfx skin.... and am trying to use the skin that came with Dfx...
    And regarding the custom text ... if i write it in Config.ini can it work ON/Off with the skin button ( view / hide )
    Commell LV-677 DC 6 x 6" Mother Board
    2.6 GHz; 1 Gb Ram
    120 Gb Laptop HD
    7" InDash Xenarc MTD - X7000 Screen
    Gyration Mouse ; GPS Mouse ; ELM Scan ; TPMS
    Parrot MK 6000 & iPhone
    Re done the carputer...Into the Glove Box !!
  2. #12
    inh
    inh is offline
    Jan 2007
    Fort Riley KS
    I'll look in to it. It worked fine with my skin.. =/ Then again, when I tested with DFX< it scaled itself automatically and lined up fine.. SO i dunno..
    So you're saying its scaling right, so that the video is the right size, its jsut not lining up right in the skin?
    cashtexts - Earn money for receiving text messaged offers
    cashtexts review not a scam
    Space Navigator - 6 Axis input device: Take it apart - Driver App
    RRCam - Video/webcam capture, text overlay, and recording: 2.0 Stable
  3. #13
    Dec 2003
    Thats right ... its not Lining up right....
    So i tried to do it via INI 0,0 to any value but no effect.....
    2.6 GHz; 1 Gb Ram
    120 Gb Laptop HD
  4. #14
    Low Bitrate Cycfari's Avatar
    Nov 2006
    N1 22.921 E103 54.207
    Quote Originally Posted by vicky_obee View Post
  5. #15
    inh
    inh is offline
    Jan 2007
    Fort Riley KS
    It works fine for me using DFX 2.0...
    My screen res is 1280x800, but i run RoadRunne at 1024x768 by changing the showwdith and showheight settings in the General.ini in the skins folder. Try changing those (by default it is 800x600, and let me know if it still does that, because it is working fine for me..
  6. #16
    Nov 2006
    Quote Originally Posted by inh View Post
    No luck
    My skin & screen is 800x600. Even after changing the showwdith and showheight settings in the General.ini to 1024x768, is still get the same results.
  7. #17
    inh
    inh is offline
    Jan 2007
    Fort Riley KS
    I THINK i know whats going on then.. It probably an issue with the skin being a resized version of 1024x768 to fit the 800x600 screen.. I'll look in to it some more, but I would think that setting the position should fix that.. I'll check to see if maybe its broken and isnt moving..
  8. #18
    Nov 2006
    Thanks.
  9. #19
    Constant Bitrate notion's Avatar
    May 2002
    San Diego, CA
    Just installed a web cam in my 350z today and this is looking good in DFX 2.0.
    I'm assuming that it must be an older version included in the DFX download as this post seems so recent.
    2 questions which you may or may not be able to help with...
    My camera is 800x640 native but videos only seem to be capturing at 400x320 - any ideas on how to up the resolution?
    Also any luck on being able to capture higher framerates that 7fps without having fast video playback?
    Sorry if these are duplicate/non relavent questions.
    Love the app - I'll have fun with this, my little James Bond camera looks badass mounted up next to the head of my passenger seat lol
    Notion
    350z Roadster,
    Lilliput 7" touch, Opus 250w, 160gb, AMD3500+, 1gb ddr400, geforce 6500 pcie, SiRF Star 3, Wireless G, Sprint CDMA, Bluetooth, Creative iCam Pro, RR, iG 4, Digital FX 4.0
  10. #20
    inh
    inh is offline
    Jan 2007
    Fort Riley KS
    It shoudl capture at the resolution of your camera. Open the camera settings, make sure it is set to 800x640, theres a good chance it isnt.
    Still no way to record more than 7 or 8 frames a second =/ Eventually I want to fix that, but I am FAR to busy to attempt it now..
    Why not post some pics of your setup? =]
  1. Core Duo / Core 2 Duo Mini-ITX boards
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 10-03-2010, 11:30 PM
  2. Canīt get DirectX to work
    By Linde in forum Software & Software Development
    Last Post: 10-19-2007, 08:35 AM
  3. SD crashes on startup
    By mangus580 in forum StreetDeck
    Last Post: 10-05-2007, 12:14 PM
  4. USB 2.0 issues PLEASE HELP!
    By Kamakazie2 in forum General Hardware Discussion
    Last Post: 10-23-2006, 08:25 AM
