inh - found a bug - when using com and gps utils - when you request gpslong using com to the gps util - it gets the response gpsspd and the correct gps longitude - thus when using this with rrcam it puts the actual gps longitude value into the gpsspd variable. Can you please have a look into this. All the other variables and values get passed correctly.
2004 Opel Opc
Phase 5 with NOS
CarPC
cashtexts - Earn money for receiving text messaged offers
cashtexts review not a scam
Space Navigator - 6 Axis input device: Take it apart - Driver App
RRCam - Video/webcam capture, text overlay, and recording: 2.0 Stable
This looks cool. Can I use this as a stand alone program and embed it into another front end?
I am looking for something that will continue recording after the pc resumes and stops when it enter standby. Will this do this?
K.
I'm confused. When I run rrcam.exe I don't get any skin at all, just default grey buttons.
Some of the settings in the config.ini do stuff and some don't. I tried turning all the test overlay to true but only gps speed shows up. When I record it goes to the rrcam folder and not where I specified. The buttons are different than what the ini file says.
The config says
Button1Label=Record
Button2Label=Stuff
Button3Label=Still
Button4Label=Stuff
Button5Label=Mirror
Button6Label=Close RRCam
but what I see is Record, Capture still, Mirror, List Drivers, exit
I also can't find any way to change my camera resolution to 640x480 in my drivers.
I can't figure out how to skin this thing as a stand alone. It does not pick up the skin files. None the button settings in the config.ini have any affect.
What am I doing wrong?
To be honest, I'm not sure this can be skinned outside of RR (ie standalone).
Yeah, that's what I thought. RRCam directly isn't skinnable, but you can hide the buttons to the right and send commands to it through your frontend (i.e. create the buttons in your skin and make them send the correct commands, f.ex record, exit, ... to RRCam).
(Correct me if I'm wrong.)
Doh, that stinks. I can't set up custom buttons in freeice.
is it possible to integrate ir with centrafuse?
Virando costas ao mundo
Orgulhosamente sós
Glória antiga, volta a nós!
