Page 8 of 15 FirstFirst 123456789101112131415 LastLast
Results 71 to 80 of 150
Thread: RRCam 2.0 Final
  1. #71
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    included skin? you mean the brushed metal?
    if so, then that TV button will not load up RRCam it will try to load up the Winamp TV plugin.
    To set that up read this thread.
    How do I setup TV / Camera Support ?
    if you still want to use RRCam, you will need to start editing the skin files or use a skin which already has support for RRCam. I think DigitalFX has support for it.
  2. #72
    Mar 2008
    that thread is the first one i found on how to do it
    i followed the instructions, but it wont work
    SO, i do think its a skin problem, so ill DL and install another skin and see if it works, im slowly working up to that point
  3. #73
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    setting up a camera using the winamp TV module has no skin specific parts, ie it can't be a skin problem as the skin just needs a button with a button code of TV and a tv.skin file.
  4. #74
    Dec 2007
    Help with problems RRCam 2.0 FINAL
    [MOVED FROM MAIN FORUM TO THE APPROPRIATE THREAD]
    Hello everyone I have a problem if someone can help me.
    When I run the RRCam 2.0 FINAL makes the following
    1Š error:
    VideoOCX(VIDEO) - Driver canīt be connected
    Accept
    To accept
    2Š error
    Unable to use MSVC codec for saving video. Please choose from an installed one.
    accept
    To accept opens the program and there is an option that puts List driver to give places:
    These are Driver Number and the names for all video for windows drivers:
    0- Microsoft WDM image Capture (Win 32) Version 5.1.2600.2180
    If no drivers are down, them you have no video for Windows cameras, and this pluing will not work for you. sorry =[
    accept
    The windows that I have is Windows XP Professional
    Using a targeta WinTV HVR 900 through RCA use the camera with its drivers
    May 2008
    Has anyone been able to get RRCam to work using a regular video camera (with a BNC connector)? I thought I would get better results using one of these instead of a webcam, but it is giving me the same errors as the previous poster. I am running the camera to a KWORLD DVD Maker VS- USB2800 USB 2.0 Interface and outside of RRcam it works great, but RRcam won't recognize it. If I need to get a new video capture device that works please let me know, but I would really like to stick with RRcam and the video camera I have now if possible. Although I would prefer not to switch cameras, if someone knows of a great webcam that works with RRcam, please let me know.
  6. #76
    May 2008
    Bump, anyone?
  7. #77
    Variable Bitrate tigergibb's Avatar
    Nov 2006
    Snellville, GA
    Has anyone had a problem with the winamp volume going to 0% if you shutdown with rrcam as the active window?
    2003 Nissan Xterra Worklog
    Total amount spent so far: $1196.64
    You will probably spend AT LEAST 2x what you initially budget for your CarPC Project!
    2003 Nissan Xterra - Modifications
  8. #78
    Jun 2007
    Anyone getting a blank white screen with RRCam? Now, every other camera app works on my CarPC except RRCam.
  9. #79
    May 2008
    Has anyone been able to set the resolution of a Logitech QuickCam Pro 9000 to anything over 320x240? If so could you please let me know. I have been trying to figure it out for a while now. I can set the resolution in Logitech's quick capture program but I cant find any setting for the camera that lets me adjust the resolution outside of their program.
  10. #80
    May 2008
    Hmm well according to the logitech support forum the quickcam pro 9000 assumes that the program using it will handle the resolution. Since rrcam also assumes that the resolution is already set correctly it ends up using the lowest resolution possible. Any ideas how to force one of them to operate properly with better resolutions?
  1. Core Duo / Core 2 Duo Mini-ITX boards
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 10-03-2010, 11:30 PM
  2. Canīt get DirectX to work
    By Linde in forum Software & Software Development
    Last Post: 10-19-2007, 08:35 AM
  3. SD crashes on startup
    By mangus580 in forum StreetDeck
    Last Post: 10-05-2007, 12:14 PM
  4. USB 2.0 issues PLEASE HELP!
    By Kamakazie2 in forum General Hardware Discussion
    Last Post: 10-23-2006, 08:25 AM
