Lots of changes!
Here is a paste from the changes.txt file. THese are just changes since the 2.0 beta release:
-added minimized and normal startup options
-added minimize and maximize com messages
-Added border to make it a bit more user friendly when run outside of RoadRunner
-Added '-minimize' command line switch
-Added a setting to detect (and kill, if deisred) multiple instances of RRCam, so that only one will be running at any time
-Fixed bug so that window messages/commands no longer have to be all uppercase
-Added support to resize based on skin settings in general.ini. Note that if your skin isnt displaying at a multiple of your camera resolution, you will have grey bars on either side of the video window. IE: If your camera is 800x600, and you set your skin to display at 1024x768, there wont be any problems, but if you try 1280x800, there will be bars on either side.
-Added support for touching the video window, etc. There are two sets of settings in the config. One is for while RRCam is in normal skin mode, the other is for when it is in fullscreen mode. You can set which actions you want RRCam to perform while in either mode, when either a single click is detected, or a click and hold. BY default, a single click takes in and out of fullscreen mode, and a click and hold takes a still picture of the video and saves it.
-Added VIDEOWIDTH and VIDEOHEIGHT com messages to set the video display area of RRCam.
-RRCam now defualts to testmode when started without RoadRunner running.
-files and length in recording in config.ini
-EXIT command changedto PREPEXIT, because now it just prepares RRCam to be closed. you need to use RoadRUnners CLOSEWINDOW command to actually close the program.
-Added MOVE;X;Y command, where X and Y are the window postion for RRCam, in pixels
-Added POSITION to ini files, where it is position=x,y for startup position
There are still more things to do, but I wanted to get this released for you guys =]
Download here
