Page 1 of 15 1234567891011 ... LastLast
Results 1 to 10 of 150
Thread: RRCam 2.0 Final
    inh
    inh is offline
    Jan 2007
    Fort Riley KS
    RRCam 2.0 Final
    Lots of changes!
    Here is a paste from the changes.txt file. THese are just changes since the 2.0 beta release:
    -added minimized and normal startup options
    -added minimize and maximize com messages
    -Added border to make it a bit more user friendly when run outside of RoadRunner
    -Added '-minimize' command line switch
    -Added a setting to detect (and kill, if deisred) multiple instances of RRCam, so that only one will be running at any time
    -Fixed bug so that window messages/commands no longer have to be all uppercase
    -Added support to resize based on skin settings in general.ini. Note that if your skin isnt displaying at a multiple of your camera resolution, you will have grey bars on either side of the video window. IE: If your camera is 800x600, and you set your skin to display at 1024x768, there wont be any problems, but if you try 1280x800, there will be bars on either side.
    -Added support for touching the video window, etc. There are two sets of settings in the config. One is for while RRCam is in normal skin mode, the other is for when it is in fullscreen mode. You can set which actions you want RRCam to perform while in either mode, when either a single click is detected, or a click and hold. BY default, a single click takes in and out of fullscreen mode, and a click and hold takes a still picture of the video and saves it.
    -Added VIDEOWIDTH and VIDEOHEIGHT com messages to set the video display area of RRCam.
    -RRCam now defualts to testmode when started without RoadRunner running.
    -files and length in recording in config.ini
    -EXIT command changedto PREPEXIT, because now it just prepares RRCam to be closed. you need to use RoadRUnners CLOSEWINDOW command to actually close the program.
    -Added MOVE;X;Y command, where X and Y are the window postion for RRCam, in pixels
    -Added POSITION to ini files, where it is position=x,y for startup position
    There are still more things to do, but I wanted to get this released for you guys =]
    Download here
    Attached Files Attached Files
    cashtexts - Earn money for receiving text messaged offers
    cashtexts review not a scam
    Space Navigator - 6 Axis input device: Take it apart - Driver App
    RRCam - Video/webcam capture, text overlay, and recording: 2.0 Stable
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    thanks inh
    for your time and work ,will give ago sometime later , its xmas and all that.
    Riderunner / Genesis
    Wifiman_NET:Version 1.0.0
    Dec 2006
    Buffer
    INH, Many thanks for this Plugin.
    The overlay is exellent and is why i would prefer this plugin over Capture.
    I am in the car for two hours a day, and i see alot of eejits on the road, and some things you wouldnt believe ! , What i would like to be able to do is have a recording buffer and only save a file after i have seen an incident, i have tried the settings in the ini but they dont seem to do anything as yet.
    Files=2
    Length=10
    maybe i can achieve what i want using the idle and timer commands to record small clips and set a button to copy the file into an archive directory but thats about the limits of my skill.
    thanks again
    Dec 2007
    Hello
    I have a problem with this plugin
    When launching the program shows image of cinergy 600 and not my webcam
    Can I fix?
    inh
    inh is offline
    Jan 2007
    Fort Riley KS
    Quote Originally Posted by pablo1970 View Post
    Files=2
    Length=10
    thanks again
    Just press the record button whenever you see an accident, and it should record. or you could make an autoit script to copy the latest file to the archive directory whenever you press the button. then just change the command line in the config.ini for the button command to run the program.
    Quote Originally Posted by virussino View Post
    Hello
    Can I fix?
    No idea man.. sounds like an issue with your camera settings. or is the cinergy 600 a capture card?
    Dec 2007
    Resolved..
    to the windows control panel, audio devices, disabled cinergy tv capture, then I restarted windows, open rrcam and worked with camera....
    I enabled again cinergy TV capture and restarted windows..
    Hours everything ok
    I have other problem..
    I change the font written at the top, with the song listening
    I see too small and black
    How can I do?
    inh
    inh is offline
    Jan 2007
    Fort Riley KS
    How can I do?
    That is something i need to fix in the skin. here it is for anyone that has already downloaded it.. just paste everything below in to the rrcam.skin file. im also going to update the zip file in the first post to include it for anyone that hasnt already installed the latest..
    Code:
    MEDIACAR Skin
    MEDIACAR Games Skin
    /Remove the comment below to have RRCam close when you leave the skin page. By default,
    /it will leave RRCam running in the background when you go to another page in the skin
    /B,-2,525,99,78,"SENDMSG;RRCam.exe;PREPEXIT||CLOSEWINDOW;RRCam.exe||EXIT",
    B,-2,525,99,78,"ESC",
    L,215,21,567,34,255,255,255,25,"Arial","TAGTITLE",
    L,15,20,173,34,255,255,255,25,"Arial","TAGARTIST",
    B,98,526,99,78,"SENDMSG;RRCam.exe;PREPEXIT||CLOSEWINDOW;RRCam.exe||EXITMENU",
    /Button labels
    L01,617,100,160,60,255,255,255,16,"Arial:B","EXEC;SENDMSG;RRCam.exe;BUTTON1||=",
    I,611,67,174,23,"!RRCAMRECORD"
    L02,619,170,164,60,255,255,255,16,"Arial:B","EXEC;SENDMSG;RRCam.exe;BUTTON2||=",
    L03,616,245,169,60,255,255,255,16,"Arial:B","EXEC;SENDMSG;RRCam.exe;BUTTON3||=",
    L04,617,315,169,60,255,255,255,16,"Arial:B","EXEC;SENDMSG;RRCam.exe;BUTTON4||=",
    L05,619,390,164,60,255,255,255,16,"Arial:B","EXEC;SENDMSG;RRCam.exe;BUTTON5||=",
    L06,619,460,164,63,255,255,255,16,"Arial:B","EXEC;SENDMSG;RRCam.exe;BUTTON6||=",
    /button indicators
    I,613,95,175,67,"!RRCAMBUTTON1"
    I,613,168,175,67,"!RRCAMBUTTON2"
    I,614,241,172,64,"!RRCAMBUTTON3"
    I,614,311,176,65,"!RRCAMBUTTON4"
    I,614,387,175,67,"!RRCAMBUTTON5"
    I,613,459,175,64,"!RRCAMBUTTON6"
    /Button text labels
    L1,617,114,164,31,255,255,255,16,"Arial:B","!BUTTON1","CENTER"
    L2,618,186,164,30,255,255,255,16,"Arial:B","!BUTTON2","CENTER"
    L3,619,256,161,30,255,255,255,16,"Arial:B","!BUTTON3","CENTER"
    L4,620,329,164,30,255,255,255,16,"Arial:B","!BUTTON4","CENTER"
    L5,621,403,164,30,255,255,255,16,"Arial:B","!BUTTON5","CENTER"
    L6,618,474,164,30,255,255,255,16,"Arial:B","!BUTTON6","CENTER"
    /Audio player buttons
    B,198,526,99,78,"PREVTRACK",
    B,299,526,99,78,"PLAY",
    B,400,527,99,78,"NEXTTRACK",
    B,500,526,99,78,"VOL-",
    B,601,527,99,78,"VOL+",
    I,702,527,93,71,"MASTERMUTE"
    /, L, x, y, w, h, color R;RGB, G, B, font size;FONT, font name, Code;LABELCODES, Tooltip;LABELALIGNMENT
    A,0,75,599,449,,,
    END
    Dec 2007
    ok....tnx
    Maximum Bitrate vicky_obee's Avatar
    Dec 2003
    Hi Inh thanx for the wonderful software
    Well i am still having difficulty in configuring this.....
    BAsically i am using DFx skin at 1024 x 786 res....
    And am trying to use the in built PNG files for RR along with its buttons....
    and all i could figure out is the 3 buttons
    ---Record, Snap shot and Mirror ( working fine )
    ---Overlay, Custom text and Date/time ( not able to configure )
    Also the Active viewing area is not in the correct position and CHANGING the Config is not doing any change......
    Can u pls help me
    thanx
    Commell LV-677 DC 6 x 6" Mother Board
    2.6 GHz; 1 Gb Ram
    120 Gb Laptop HD
    7" InDash Xenarc MTD - X7000 Screen
    Gyration Mouse ; GPS Mouse ; ELM Scan ; TPMS
    Parrot MK 6000 & iPhone
    Re done the carputer...Into the Glove Box !!
    inh
    inh is offline
    Jan 2007
    Fort Riley KS
    So you tried changing the position settings in the config file and it didnt work?
    Are you using the latest DFX skin, and are you trying to use the skin that comes with DFX, or the skin in the latest release of RRCam?
    To set custom text, you just need to change it in the config file, and also make sure that it is set to display. Under the General section, you need to set these accordingly to get the text to display
    Text1Startup=True
    Text2Startup=False
    Text3Startup=True
    Text4Startup=False
    Set them to True to get the text to display
  1. Core Duo / Core 2 Duo Mini-ITX boards
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 10-03-2010, 11:30 PM
  2. Canīt get DirectX to work
    By Linde in forum Software & Software Development
    Last Post: 10-19-2007, 08:35 AM
  3. SD crashes on startup
    By mangus580 in forum StreetDeck
    Last Post: 10-05-2007, 12:14 PM
  4. USB 2.0 issues PLEASE HELP!
    By Kamakazie2 in forum General Hardware Discussion
    Last Post: 10-23-2006, 08:25 AM
