OK finally got this working great.
I had to add a delay from when it loads IG to the time that it calls the menus.
I added 1500MS. Maybe too long, but works none the less.
Thanks all for the help
New Age Garmin - Skin for RR
Live mp3Car Facebook Chat
all though some movie theaters still do not work correctly as far as mapping. A few do and a few dont. Maybe a lack of information.
I searched though the thread but I didn't see anything about pulling the current locatin from GPS. Woud it be possible to take the current position GPS provides, convert it to a Zip code and use that instead of entering it manually?
if you're in the united states,have zips.dat in your rr folder and have localdatacaptureinterval=/0 (meaning not zero, should equal 1,2,5,10,15,or 30) then yes this will work.
Sonic, beta2 works great....
a couple of questions.. has the long description issue been fixed? cuz look at the screen shot.. second, navigate works great, but for some reason, it goes back to movie detail screen instead of staying at navigation view.. I have to click any button to bring the navation view back... is that by design?
Also, if i wanna go back to the last movie view from GPS, what's the command i need to use? I created a button just for that.
oh about the rating problem.. i got it resolved.. i just swapped the loading order of mp3art plugin and movietimes..
so, MT gets loaded last.. however, i got the feeling that's gonna break the mp3art functionality..
here is my screenshot of the exact same theater and the exact same screen.
i dunno whats goin on with ur data capture but its not completing correctly. Do me a favor and notate all plugins except movietimes and try it again. I have a feeling the "plugin" bug is messing up more than just indicators in your case. Navigation swapping back to the movie details screen has something to do with the timing of commands being processed. I can fix that with a delay. Thats definitely not by design. And if you want to go from GPS screen back to movie detail screen the command "LASTSCR" should do the trick.
the next and hopeful final release will cure the plugin bug, fix the details list scroll issue, and HOPEFULLY add capability to download the data while you have net connection then use that data locally if no net connection is detected.
hmm... same result... this is all i have in my menu.skin file..
RoadRunner Skin
RRScreen "MENU"Skin
F,300,185,200,200,"autobot.swf"
/, I, x, y, w, h, Code;INDICATORCODES
I07,459,440,83,93,"MUTE:b"
/, B, x, y, w, h, Command;COMMANDCODES, Tooltip
B01,6,137,343,95,"RUNW;$skinPath$PlayFile\playfile .exe|sound.wav||AUDIO",""
B02,358,139,90,44,"RUNW;$skinPath$PlayFile\playfil e.exe|sound.wav||CDRIP",""
B03,453,139,343,94,"RUNW;$skinPath$PlayFile\playfi le.exe|sound.wav||VIDEO",""
B04,6,236,298,97,"RUNW;$skinPath$PlayFile\playfile .exe|sound.wav||RADIO",""
B05,497,235,298,97,"RUNW;$skinPath$PlayFile\playfi le.exe|sound.wav||MovieTimes",""
B06,6,338,338,95,"RUNW;$skinPath$PlayFile\playfile .exe|sound.wav||PHOCO","Telefono"
B07,352,383,97,50,"RUNW;$skinPath$PlayFile\playfil e.exe|sound.wav||WEB",""
B08,454,337,342,98,"RUNW;$skinPath$PlayFile\playfi le.exe|sound.wav||GPS",""
B09,5,434,87,101,"RUNW;$skinPath$PlayFile\playfile .exe|sound.wav||WEATHER","Tempo"
B10,461,441,80,92,"RUNW;$skinPath$PlayFile\playfil e.exe|sound.wav||MUTE",""
B11,543,442,81,90,"RUNW;$skinPath$PlayFile\playfil e.exe|sound.wav||VOL-",""
B12,625,441,81,90,"RUNW;$skinPath$PlayFile\playfil e.exe|sound.wav||VOL+",""
B13,707,439,82,92,"RUNW;$skinPath$PlayFile\playfil e.exe|sound.wav||MIXER",""
B15,5,535,152,61,"RUNW;$skinPath$PlayFile\playfile .exe|sound.wav||CAMERA",""
B16,164,535,152,61,"RUNW;$skinPath$PlayFile\playfi le.exe|sound.wav||GAMMA",""
B17,324,535,152,61,"RUNW;$skinPath$PlayFile\playfi le.exe|sound.wav||Load;MENU_2.skin",""
B18,484,535,152,61,"RUNW;$skinPath$PlayFile\playfi le.exe|sound.wav||Load;power.skin",""
B19,644,535,152,61,"RUNW;$skinPath$PlayFile\playfi le.exe|sound.wav||MINIMIZE",""
/, Y, Back Slider file path
Y01,"SLIDER_VOLUME\slider_*.gif"
Y02,"SLIDER_POSITION\slider_*.gif"
/, S, x, y, w, h, x1, y1, w1, h1, O, Style, Pointer file path, h2, Code;SLIDERCODES, Tooltip
/,S01,283,491,237,25,278,493,247,25,H,01,"",0,"MAST ER",""
S02,139,109,448,8,133,110,445,15,H,02,"",0,"SONGPO S",""
/, L, x, y, w, h, color R;RGB, G, B, font size;FONT, font name, Code;LABELCODES, Tooltip;LABELALIGNMENT
B,100,439,58,91,"RUNW;$skinPath$PlayFile\playfile. exe|sound.wav||STOP",
B,353,440,105,91,"RUNW;$skinPath$PlayFile\playfile .exe|sound.wav||NEXT",
B,159,442,94,91,"RUNW;$skinPath$PlayFile\playfile. exe|sound.wav||PREV",
B,254,441,99,91,"RUNW;$skinPath$PlayFile\playfile. exe|sound.wav||PLAY",
L,139,74,114,33,0,255,128,16,"HandelGotDLig","CURR ENTTRACKTIME","LEFT"
/, TMR, Seconds
TMR,
/, A, x, y, w, h, color R;RGB, G, B
A,18,22,765,106,,,
L04,502,28,160,24,0,255,128,16,"HandelGotDLig","TI ME","RIGHT"
L05,631,28,155,24,0,255,128,16,"HandelGotDLig","DA TE","RIGHT"
L,27,96,77,24,0,255,128,16,"HandelGotDLig","CPU"," LEFT"
L07,205,24,333,42,0,255,128,20,"HandelGotDLig:B"," TRACKNUMBER||= - ||TAGTITLE||= - ||TAGARTIST||= - ||TAGALBUM","SCROLL-CENTER"
L08,133,26,72,25,0,255,128,16,"HandelGotDLig","VOL UME","LEFT"
L,672,97,53,20,255,128,0,16,"HandelGotDLig","GPSHD G","CENTER"
L,731,97,53,20,255,128,0,16,"HandelGotDLig","GPSSP D","CENTER"
L,610,72,174,20,255,128,0,16,"HandelGotDLig","= SAT HDG SPD","CENTER"
L,613,97,53,20,255,128,0,16,"HandelGotDLig","GPSSA T","CENTER"
B,661,24,124,106,"RUNW;$skinPath$PlayFile\playfile .exe|sound.wav||NEXTAVS",
L,24,28,88,20,255,128,0,16,"HandelGotDLig","=VOLUM E",
B,17,22,111,106,"RUNW;$skinPath$PlayFile\playfile. exe|sound.wav||VISU",
/,X,Mp3Art
/,J,0,0,0,0
X,MOVIETIMES
END
are you using the lastest RR (12/13 i believe)? check and be sure.
