Wow Sonic! You have outdone yourself! This is definitely a full featured plugin! For some reason, the poster art has started working for me with the latest release (Screen Cap 2 below). I had not changed anything in the skin or files, just updated the dll.
I did fine one SMALL oversight however, sorry. When you are in the main listing, and highlight a theater, the "MOVIETHEATERNAME" is updated as you select something. This is not working for the "FAVTHEATERS" list as of yet. (As seen in capture #1 below) I am sure this is due to the fact that you just added in the code for the favorites, and just did not add the code to update the label.
Now one other SMALL request hahha.... Is there a way to make it default to the favorites, then you can change the zipcode if you want. I would think most would use the favorites more so than the zipcode as a dedault.... I tried "
MOVIETIMES||FAVTHEATERS" but when the plugin loads, it reverts back to the main list, only flickering the favorites for a brief second..
I know it is a pain to scrape sites to get information and display it. I have been doing this for a long time with my Home Automation system. Getting info such as stocks, news headlines, weather forecasts and the likes. Then when the page is change, even slightly, it breaks and has to be tweaked.
Fantastic work on this plugin!
EDIT: I just noticed that the
MOVIEDOWNLOADDATE and the
MOVIEDOWNLOADTIME are not displaying in the labels with the latest version.
Double Edit: After reloading RR a few times, and playing around the date and time labels filled in. Not sure what was causing it..
