Page 9 of 41 FirstFirst 12345678910111213141516171819 ... LastLast
Results 81 to 90 of 408
Thread: Movie Listings... Coming to an RR near you!
  1. #81
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    about the navigate feature...
    i'm workin hard on the navigate feature but i may need some help. The problem is i cant find a good source of free data for the address-to-coordinates conversion. Right now i'm using http://geocoder.us because its free, requires no registration, and its a straight forward site i dont have to spend a lot of cpu's parsing. The drawback to using this site is that it uses tiger data which isnt updated nearly enough! This means some of the theaters you wont be able to navigate to uses that source. If anyone can find a free, no-registration site with updated data please by all means let me know.
    The second part of the navigation issue (and frankily the one i'm stumped the most on) is sending the mouse clicks /keys to iguidance. I'm trying my absolute best not to have to use autoit to do this but i havent found ANYTHING in vb that sends mouse clicks to external application controls. I could whip up a support script in autoit in about 10 mins but i've spent the last day and a half searching for methods for this. Does anyone have insight on this matter or should i just go ahead and succumb to autoit for that last step.
    Live mp3Car Facebook Chat
  2. #82
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by Enforcer View Post
    OK, I'm trying this out, but I don't seem to be getting anything.
    ir it just sits there saying "Getting movie listings"
    now in RR's debug file I have
    so it seems to be picking out the cinemas (used johns zip code from his screenshot as my post code won't work ), but it doesn't seem to create that txt file that it is supposed to be putting the info in. Further move, when I created that file manually in then got deleted.
    I am running no other plugins.
    Any ideas (apart my suspicion that it is something to do with hardcoded paths or drives maybe?)
    Ooooooooooops, my bad, was still using an older version of RoadRunner (12-Apr-2007) than this requires.
  3. #83
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by Sonicxtacy02 View Post
    Apart from the link I gave you in the other thread I can't help.
    However if you want to navigate to using FreeDrive (well my version anyway) I can help you.
    Also when you can get around to modifying for the UK yahoo movie listings I can help with getting GPS cords for a UK postcode
  4. #84
    Woodbridge, VA
    Blog Entries
    32
    once canada has been tested i'll move on to the neighbors across the pond
  5. #85
  6. #86
    Woodbridge, VA
    Blog Entries
    32
    Another observation.
    It loses the zip code next time you start RoadRunner
    it does this on purpose actually. I set it up so that it reads first from the CURRENTZIP label, and if that label isnt populated it requires you to enter a zip code to whatever destination u want.
  7. #87
    Woodbridge, VA
    Blog Entries
    32
    ok here's another vid.. this time showing the NAVIGATION feature. I used auto it(yea i know i cheated) and it works as its supposed to. First part of the video shows if my plugin can successfully find the lat and lon of the movie theater to navigate, the second part shows if the theater cant be found.
    The video also shows new stuff like the theater address label, and the numosk reloading the list when the enter button is pressed. Also of note is the larger theater list by default and extended movie information. So much stuff i probably forgot some things but anyways here it is.
    Attached Files Attached Files
  8. #88
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Can we have a variable that contains either a 0 if Theatres are listed and a 1 if it is films being listed?
    I want to have the label for the switch lists button to be either Theatres or Films.
    Also when you switch lists to the movies playing, the theatre label loses it's value, can it be set to keep it.
    Oh and the theater label keeps it's value when you go to movieinfo screen.
    Another thing (you starting to dislike me aren't you?) Now Playing comes up while it's trying to get the movie list, that should only change if it succeeds.
    And the poster art does not seem to be showing, I have the following line in the skin
    I,647,054,132,123,"FILE;$MOVIETIMESPOSTER$:A"
    and there seems to be art for some films in the poster art folder
    Oh yeah current look in the upcoming iDrive Night Red (movieinfo stars need doing properly when I can get to photoshop)
  9. #89
    Jun 2003
    Memphis - TN
    As requested Sonic..MOVIETIMESERROR
    If you need changes made, let me know.
    2011 Nissan Frontier SL
    AMD X3 2.2 | M4-ATX | 16Gb SSD | 2GB DDR3-1333 | MSI GF615M-P33 MB
    OBDPROS USB | BU-303 GPS l LILLIPUT TS | Car2PC adapter | XM Direct | USB Dual band N with custom mag-mount antenna.
  10. #90
    Woodbridge, VA
    Blog Entries
    32
    can do.. thats no prob
    Can do as well
    i want the theater label to keep its value in the event that people wish to display the theater name and theater address on the info screen
    i have yet to add the fail-safes to the buttons. I was gonna get that done as a part of the final build
    hmmm this one is tricky.. if you open up the poster art folder and see the art for the movie you just got information on the variable should be populated. i will check to see whats goin on with the SETVAR;movietimesposter
    nice lookin skin as always.. it makes me happy that i wont be the only one using this thing lol. If you find anything else please let me know I'd like as much feedback as possible
  1. XMD RR Hibernation & XMRESET
    By hank_kls65 in forum Road Runner
    Last Post: 10-25-2007, 04:14 PM
  2. Replies: 0
    Last Post: 09-23-2006, 09:38 PM
  3. Generalized Perception of RR from a new user
    By replicant in forum Road Runner
    Last Post: 11-15-2005, 11:41 PM
  4. RR doesn't start Phoco on initial load..
    By DutchBurner in forum Road Runner
    Last Post: 11-04-2005, 02:17 PM
  5. RR 09-09-05 ... Yup, it's my Birthday!
    By guino in forum Road Runner
    Last Post: 09-12-2005, 06:05 AM
