Page 25 of 90 FirstFirst ... 15161718192021222324252627282930313233343575 ... LastLast
Results 241 to 250 of 894
Thread: RRMedia Plugin by Blue ZX3 [v1.3.0 Released]
  1. #241
    Feb 2008
    Blue, I changed directories again to show the 2 rrmediadb that are created. Here's a pic
  2. #242
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Yes, it is working 100% correctly, there only need to be one place for the db and that is at your musicpath location. You change your music path, you change where there should be a db file.
    I am confused as to why your trying to point this out to me?
    Current Project: DFXVoice [Beta Released]
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  3. #243
    Feb 2008
    Ah, perhaps I misunderstand, when rebuilding the db is it not supposed to remove the old database or at least move it to the new location? Until I delete the old file manually, I get the CheckforMP3.exe error. Again, I must be misunderstanding how the rescan works.
  4. #244
    Feb 2008
    If the rescan only builds a new db in the appropriate folder and leaves the original alone full intact then I have another issue to examine on my end-why is it looking at both or looking at the original database instaed of the new. humn...think I'll go play with that idea a bit.
  5. #245
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    "CheckforMP3.exe" is NOT part of my plugin. Rescanning does a combination of three things: remove missing media records from db, check for updated/changed files (ie upated tags in a file), and new files that have not been imported yet all on the original db file from the origanal scan, unless you change your musicpath, then ya its going make another db file as one doesn't yet exists at the path.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  6. #246
    Feb 2008
    Blue, it appears the CheckForMP3.exe located in the 'scripts' folder was/became corrupted. I replaced the .exe with a known working.
    Thanks for your help.
  7. #247
    FLAC Sal R.'s Avatar
    Aug 2006
    Sun Diego
    I don't know if this was intended or not, but RM_ADD1 does not "unload" a "loaded" disc like the other commands. Granted, it appends the playlist, but the "DISC" playing does not match the playlist.
    Also, when using "RM_Sel2Disk" at a file/song level in RM_MEDIA.skin, it doesn't update the the "DISC" song count label as seen in RM_ADD2DISK.skin.
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
  8. #248
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Quote Originally Posted by Sal R.
    The RM_ADD has the logic that if you have a disk loaded it will add that selection to both the current PL and to the disk, otherwise just to the current PL.
    Also, when using "RM_Sel2Disk" at a file/song level in RM_MEDIA.skin, it doesn't update the the "DISC" song count label as seen in RM_ADD2DISK.skin or add the song to an empty "DISC."
    This one I'm not sure about but will check on...
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  9. #249
    Constant Bitrate Stealth915's Avatar
    Bay Area, CA
    I figure I should post this here instead of the DFX thread. An update on my problem - I'm unable to get the database built. Originally I was getting this error while building the database:
    More recently I've tried building the DB with only 1 MP3 in my music directory, but still no luck. I did notice that my ID3v1 tag and ID3v2 tag was different on the same MP3 file. When I clear one of the two, the popup box during DB building goes away. However, I'm still not getting any entries in my database after building.
    After poking around the DB I got to this when going to Browse Mode > Recently Added. I still don't get anything when Browsing by Artist/Album/Genre and the DB file is blank.
    The 1 file I have in my Music dir is:
    RR Music Path: D:\Music\
    Filename: Akon.mp3
    ID3 tag (tried on both v1 and v2):
    - Title: Ghetto
    - Artist: Akon
    - Album: Konvicted
    - Year: 1998
    - Genre: Other
    - Comment: [left blank]
    Does this plugin scan both ID3v1 and ID3v2 tags? Is there a preference for any tag? Any help would be appreciated. I've spent a better part of this weekend trying to figure this out.
    I don't know if this matters, but I have "Prefer ID3v2 Tags", Show ID3 Playlist, Show ID3 Browse, and Lazy ID3 Load checked in my RRConfig.
    2004 Mazda3 Carputer Worklog - Update 5/17/11: Carputer 2.0 Hardware Selection
  10. #250
    Aug 2006
    Sun Diego
    Yeah, RM_ADD1 is not updating the loaded disc playlist nor it is updating the song count.
    In addition, RMA_ADD1 is not adding songs at a file/song level.
    I am using the beta you sent me.
  1. Is there an Alpine blue for RR?
    By turbosx in forum RR Skins
    Last Post: 06-01-2008, 04:35 AM
  2. problems with navigation in streetdeck
    By customaudioman in forum StreetDeck
    Last Post: 01-25-2008, 01:46 PM
  3. RR 04-08-05 .. BETA Base Plugin ...
    By guino in forum Road Runner
    Last Post: 04-11-2005, 12:39 AM
  4. Does Any Winamp Plugin Work With Media Car ?
    By ccsnet in forum MediaCar
    Last Post: 11-23-2003, 02:39 PM
