Page 40 of 90 FirstFirst ... 303132333435363738394041424344454647484950 ... LastLast
Results 391 to 400 of 894
Thread: RRMedia Plugin by Blue ZX3 [v1.3.0 Released]
  1. #391
  2. #392
    Constant Bitrate Stealth915's Avatar
    Bay Area, CA
    is there any other place to download the 1.1 installer? The link on the first post isn't working.
    2004 Mazda3 Carputer Worklog - Update 5/17/11: Carputer 2.0 Hardware Selection
  3. #393
    Jun 2008
    Atlanta, GA
    Second error isn't related to this plugin, that "Play this album" in the released DFX skin is still using the old way of doing that, the upcomming patch will use the db cmd instead.
    Should we wait for the update to DFX to come out before using v1.1?
  4. #394
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    @MGD
    I did find some a bug with the album art coding in the ext plugin. The next update should be working fully(fingers crossed). The art should also show whether it's set to hidden or not.
    Current Project: DFXVoice [Beta Released]
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  5. #395
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Quote Originally Posted by spamminator View Post
    You don't have to but there are still some bugs I'm finding in the 1.1 version, which all have been fixed.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  6. #396
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    @All
    You can NOT just change between the two versions w/o any db problems. There was a format change in the 1.1 version.
    Going v1.0 > v1.1 you have two options:
    #1 At then end of the install you should be getting a msgbox tell you it needs to update your already exsisting db, if you did not get such box, then you need to either run the "v1.1 DbUpdater.exe" in the RMDatabase folder or #2
    #2 Delete ONLY the RMediaDb.db file in your music path set in rr. Then just build the db again.
    Going v1.1 > v1.0:
    #1 Only one option, which is #2 above
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  7. #397
    Maximum Bitrate nasa's Avatar
    Aug 2006
    PA
    Hi Blue,
    1st -- thanks for all the effort, it's truely appreciated.
    I did follow option #2.... That's how I got the error I left the bug report for....
  8. #398
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    Quote Originally Posted by Enforcer View Post
    make sure it's not a hidden .jpg.
    I used Notepad,,,to unhide the jpg
    attrib -r -s -h /s
    I know my DOS
  9. #399
    FLAC Sal R.'s Avatar
    Aug 2006
    Sun Diego
    Possible bug:
    Using RM_!PLSelect or RM_PLSelect isn't updating the "RM_Disk_Loaded" indicator.
    i.e. Have a disk loaded and it has the corresponding indicator state. Loading a playlist from a playlist screen w/ DL skin code isn't turning off the disk loaded indicator to off.
    EDIT: Cured by adding command line: "BYIND;RM_Disk_Loaded;<<RM_UnloadDisk" to RM_PLSelect button.
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
  10. #400
    Bay Area, CA
    Hi Blue,
    I seem to be having the same problem as nasa. I have the music path correctly set but attempting to build the library shows a Music Path Error on the skin, and checking the builder_debug.txt shows the error as an "invalid music path"
    My music path is:
    D:\Music
    with subfolders
    D:\Music\new
    D:\Music\Sorted
    If I set my music path to either of the subfolders, RRMedia will build the database with no problems.
    I found a little workaround to this problem: I set my music path to D:\Music\Sorted so that it would build the database. Then I moved the RRMediaDB.db file to D:\Music, set RR's music path to D:\Music, and rescanned the database. It removed the 2000 or so songs from the initial scan and rescanned everything in both "Sorted" and "new" folders (around 3000 songs total).
    Hope this info helps you to determine what is causing the bug, Blue.
  1. Is there an Alpine blue for RR?
    By turbosx in forum RR Skins
    Last Post: 06-01-2008, 04:35 AM
  2. problems with navigation in streetdeck
    By customaudioman in forum StreetDeck
    Last Post: 01-25-2008, 01:46 PM
  3. RR 04-08-05 .. BETA Base Plugin ...
    By guino in forum Road Runner
    Last Post: 04-11-2005, 12:39 AM
  4. Does Any Winamp Plugin Work With Media Car ?
    By ccsnet in forum MediaCar
    Last Post: 11-23-2003, 02:39 PM
