Page 44 of 90 FirstFirst ... 343536373839404142434445464748495051525354 ... LastLast
Results 431 to 440 of 894
Thread: RRMedia Plugin by Blue ZX3 [v1.3.0 Released]
  1. #431
    May 2007
    Yep, the download link isn't working Blue!
  2. #432
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    It is working just fine. Maximise the new window, the files are on the right.
  3. #433
    May 2007
    Thanks MGD and thanks very much for the update Blue.
  4. #434
    Jun 2008
    Atlanta, GA
    Blue:
    Tried rescanning my DB (after updating it to the 1.1 standard) and got the following at the 10,760th file:
    9/7/2022 10:12:35 PM: RRMedia Builder> MediaInfo communitation OK!
    9/7/2022 10:13:22 PM: RRMedia Builder> Subscript out of range
    I tried deleting the DB and starting from scratch, but I got the same error at the 10760 mark again. Is there a way to turn on more debug in the plugin?
    Edit:
    I turned on RRDebug, but there doesn't seem to be anything weird in the log:
    9/7/2022 10:17:28 PM: Enter Exec: False, rm_builder.skin, , False
    9/7/2022 10:17:28 PM: Que Exec: True, rm_builder.skin, "RM_SETLABEL;RM_BuildCounter;Found 10724 Files", False
    9/7/2022 10:17:28 PM: Que Exec: True, rm_builder.skin, "RM_SETLABEL;RM_BuildCounter;Found 10735 Files", False
    9/7/2022 10:17:28 PM: Que Exec: True, rm_builder.skin, "RM_SETLABEL;RM_BuildCounter;Found 10749 Files", False
    9/7/2022 10:17:28 PM: Leave Exec: False, rm_builder.skin, RM_SETLABEL;RM_BuildCounter;Found 10749 Files, False
    9/7/2022 10:17:28 PM: Que Exec: True, rm_builder.skin, "RM_SETLABEL;RM_BuildCounter;Found 10760 Files", False
    9/7/2022 10:17:28 PM: Leave Exec: False, rm_builder.skin, RM_SETLABEL;RM_BuildCounter;Found 10760 Files, False
  5. #435
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    @nasa
    Lets start with a few things first...
    When you put a playlist on a disk, there is no link between the playlist and whats on the disk, it reads the selected playlist
    then removes the musicpath set in rr from all of the songs before writing the remaining path data to the selected disk number wi
    along with the resume info.
    So the reason that your disks are not playing is that these playlists you are creating, are using a different main musicpath to
    the relivive part of the path. This probably sounds kinda confusing as trying to describe it, isn't easy either..
    Lets try this example...
    rr musicpath=D:\Music\MP3\
    Playlist#1
    #EXT
    D:\Music\MP3\AC-DC\Razors Edge\Thunderstruck.mp3
    D:\Music\MP3\Ac-Dc\Razors Edge\Are You Ready.mp3
    D:\Music\MP3\Metallica\Metallica\Enter Sandman.mp3
    D:\Music\MP3\Metallica\Metallica\The Unforgiven.mp3
    When putting the playlist to disk, it removes the "D:\Music\MP3\" part so the remaining data written to the disk looks like
    (this is to keep all stored paths in the db relitive to the set music path)
    Disk#4
    When you load a disk, it re-adds the musicpath, then tells rr to play the temporly created playlist at the last track and posistion played.
    So, if you playlists you are creating don't include the musicpath that is used where you are trying to use it from then that is probably
    where the issue is coming form and then when you rate one, it can't find a match in the db to save your rating to.
    Hope this helps to narrow your problem down, if not, post what you still don't understand.
    PS. By chance, where you the one that many moons ago, asked about importing ratings from MediaMonkey?
    Current Project: DFXVoice [Beta Released]
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  6. #436
    Maximum Bitrate nasa's Avatar
    Aug 2006
    PA
    Blue,
    Great explanation.... It clearly identifies my issue. Let me explain my issue (BTW: Yes, I am the one who asked about MediaMonkey). I am trying to sync my music collection on my media server with my music collection in my car. I do most of my music listening in my home. So I prefer to do most of my music tagging, rating, etc in my home as well. I can use MM to create an array of different playlist (and I am sure this is true for any music management software) -- however, the path in my house doesn't match the path in my car. To get around this, I have created a folder structure like this:
    .../abcde/<artist>/....
    .../01playlist/<playlist>
    .../fghij/<artist>/...
    and so on. With this structure, I could create relative paths for my playlist, which would work in both areas.
    From your description -- that's not going to work.
    Possible solutions:
    -- Match all my systems to use the same path....
    -- Help Blue do a minor software fix
    I'm assuming you programmed this in VB with sqlite as the database. I know next to no VB, however a quick google search lead me to a suggestion:
    Dim TestString As String = <full mp3 path from playlist>
    Dim TestArray() As String = Split(TestString "/", ,CompareMethod.Text)
    Dim Song as String = TestArray(TestArray.length - 1)
    The song string is now in "Song". Again, my VB is no existant -- but this should work....
  7. #437
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    The only parts that are in vb are the dll and the builder as the main app is in Autoit. I do have a app that i did start work on importing the rating from MM as it too uses a sql db to store its data but found that MM uses a 0 to 5 star going in 1/2 star increments(I think, been awhile since I actaully worked on it).
    The whole reason that I only store the relitive paths in the db is so that you could have a mirrored image of a music collection in two diferent places, in two different paths and be able to just sync the needed RRMedia files and everything would work.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  8. #438
    Aug 2006
    PA
    I'm such a dunce... After rereading both of your post -- suggesting a change/addition to your code was a little premature.
    I now have a new question.... When you add a playlist to disk, if the music paths used don't include the music path -- what does the software do? Will it just add it to the database as is? Then when a song is called up, it addes the music path to the database entry?
    Thanks again
  9. #439
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    That is correct, this way as long as the music collection is mirrored past the music path you could use the db in either location becase it would just add the musicpath + path from db = full path
    So, like this example would work..
    House comp:
    Musicpath=C:\Doc & Settings\bla bla\My Docs\My Music\
    example song path would be: C:\Doc & Settings\bla bla\My Docs\My Music\AC-DC\Razors Edge\Are You Ready.mp3
    Car comp:
    Musicpath=D:\Music\MyMusic\
    example song path would be: D:\Music\MyMusic\AC-DC\Razors Edge\Are You Ready.mp3
    As long as the the folder structure is the same past the set music path this works. Allows building of the db in the house and only need to transfer the db file & rate.in_ to the car's music path to use it...
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  10. #440
    FLAC Sal R.'s Avatar
    Aug 2006
    Sun Diego
    House comp:
    Car comp:
    Now that is a useful tidbit of information.
    Does your plugin perform a similar operation when loading playlists (*.m3u)?
    i.e. create a playlist on the desktop > copy playlist to carPC > load playlist (same folder structure, different $musicpath$)
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
  1. Is there an Alpine blue for RR?
    By turbosx in forum RR Skins
    Last Post: 06-01-2008, 04:35 AM
  2. problems with navigation in streetdeck
    By customaudioman in forum StreetDeck
    Last Post: 01-25-2008, 01:46 PM
  3. RR 04-08-05 .. BETA Base Plugin ...
    By guino in forum Road Runner
    Last Post: 04-11-2005, 12:39 AM
  4. Does Any Winamp Plugin Work With Media Car ?
    By ccsnet in forum MediaCar
    Last Post: 11-23-2003, 02:39 PM
