Page 49 of 90 FirstFirst ... 394041424344454647484950515253545556575859 ... LastLast
Results 481 to 490 of 894
Thread: RRMedia Plugin by Blue ZX3 [v1.3.0 Released]
  1. #481
    Jun 2008
    Atlanta, GA
    Blue -
    I updated to v 1.2.2 (full, clean install but using the DB from 1.2), and now seem to be having problems with track names with underscores in them:
    12/10/2008 1:11:06 AM: RRMedia Builder> C:\Audio\Bear vs. Shark\Terrorhawk\13 Heard Iron Bug, _They're Coming T.mp3
    12/10/2008 1:11:06 AM: RRMedia Builder> near "They": syntax error
    Edit: Actually, in the tag info, that's a quotation mark, which may actually be the problem:
    Track name: Heard Iron Bug, "They're Coming To Town"
  2. #482
    Variable Bitrate GF-ler's Avatar
    Aug 2005
    germany
    hi blue,
    perhaps my installation is not correct, or i missunderstood how the RRMedia works.
    i thought that...
    1) if a song is rated... the number of stars i rated this song is always showing if the song is playing.
    2) if i push a button like "LOAD 4 STAR LIST" it shows me a list with all 4star selected songs.same for 3stars or 5 or 2.
    3) the next is the virtual playlist, i can use 10 different virtual playlists...how can i see what songs are in the playlist.
    please help a dummie german.
  3. #483
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    1) Correct
    2) Correct, it plays which ever rated list you selected, but going by your first one, sounds like you have an issue somewhere.
    3) The 10 virt playlists are really just the last 10 playlists(ie rotating history if you will) you have listen to.
    Are you using the newest version, the 1.2.0 did have a non functioning rating system.
    Current Project: DFXVoice [Beta Released]
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  4. #484
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    1) Correct
    i'll just add that you need to make sure that yoru exectbl.ini includes the following line:
    Code:
    "ONSONGSTART","RM_ONSONGSTART"
    this is what tells RR to check the song rating once a song has been played.
    Live mp3Car Facebook Chat
  5. #485
    Aug 2005
    germany
    thanks for answering,
    i have installed the version 1.2.2.0
    the onsongstart is written in the exectbl.ini. (i make a copy of the exectbl.ini from blues RRMEdia skin)
    with this skin i had the same problem, no showing stars if the song selected again. only the time when the song is playing and i rate him.
    its a hardcopy whats going on if i rate a song and play it again, maybe it helps.
  6. #486
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Really nice to get debug SC w/o even asking for it!! Also funny that, that is the first time that someone posted that....
    Other suggestion would be to run the 1.1 db updater an see if that fixes anything in the rmdatabase folder.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  7. #487
    Jun 2008
    Atlanta, GA
    Quote Originally Posted by spamminator View Post
    Blue -
    I took the quote out of that track title, and it got past it, only to fail at another track that had a quotation mark in the title. So, I think it's safe to say that it chokes on track names with quotation marks.
  8. #488
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Without check the code, that would be a good assumption, but werid that it only showed up now? And not in previous versions.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  9. #489
    Jun 2008
    Atlanta, GA
    Yeah, before it scanned through them fine. Not positive that it actually added the files to the DB though...
    Update: On a lark I deleted the DB and created a new one...and everything worked fine. I even went and rescanned on the new DB and it didn't throw any errors at me either. *shurg*
  10. #490
    Jun 2008
    Atlanta, GA
    Also, an operational question:
    What is the difference between files that have been added to the database, and those that have not but reside within the music path? It seems that I can still play them and add them to the various playlists. Is the only functionality lost by not adding them to the database the searching?
    Thanks.
  1. Is there an Alpine blue for RR?
    By turbosx in forum RR Skins
    Last Post: 06-01-2008, 04:35 AM
  2. problems with navigation in streetdeck
    By customaudioman in forum StreetDeck
    Last Post: 01-25-2008, 01:46 PM
  3. RR 04-08-05 .. BETA Base Plugin ...
    By guino in forum Road Runner
    Last Post: 04-11-2005, 12:39 AM
  4. Does Any Winamp Plugin Work With Media Car ?
    By ccsnet in forum MediaCar
    Last Post: 11-23-2003, 02:39 PM
