Page 50 of 90 FirstFirst ... 404142434445464748495051525354555657585960 ... LastLast
Results 491 to 500 of 894
Thread: RRMedia Plugin by Blue ZX3 [v1.3.0 Released]
  1. #491
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Searching, Rating, Top x played, Recently played...ect
    Current Project: DFXVoice [Beta Released]
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  2. #492
    Variable Bitrate GF-ler's Avatar
    Aug 2005
    germany
    hi blue,
    i uninstall all files for RRMedia, delete the both files in my MUSIC folder and start a new installation.
    if its try to scan my musicfolder it stops after 2 seconds and no entry in it.
    so i try it with the install of 1.0. there i get a complete scan of my music.
    after installation i make the upgrade to version 1.2.2.0, also run the file 1.1dbUpdater.
    the result of all is the same before. i can rate a song, it shows me the stars the time the song play. if the song change the stars are not showing (no star rated) after this song i switch the rated song again and it shows no stars.
    if i look in my music folder i see 2 files, the biggest is RRMediaDB and the second the Rate.IN_ file.
    in the Rate.IN_ file is written all songs i rate with 3,4,5 stars.
    my question is, is the suffix of the rate file correct ?
    perhaps i wait for the skin of MGD for comparing whats going wrong with my install.
  3. #493
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Yes, the suffix is correct. What is the size of you RMediadb.db file?
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  4. #494
    Aug 2005
    germany
    if i install with 1.2.2.0 its 29kB, if its installed with 1.0 its 2.362kB.
  5. #495
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    with the 1.2.2.0 that size of a db file tells me that nothing is getting added to it as that is the size of an empty db file. after a build using the 1.2.2, what is contained in the builder_debug.txt found in the RMDatabase folder?
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  6. #496
    Aug 2005
    germany
    hi blue,
    Builder_debug.txt
    it ended after looking in folder BLUES, a lot of other Genres / Groups behind.
    so i try it again after cleaning every genre folder, playlists.. mp3īs with 0Byte aso.
    if i rescan i get the message "Invalid procedure call or argument RMBuilder" and it breaks by 29kB.
  7. #497
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Ya, something deff does not look right there...
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  8. #498
    Aug 2005
    germany
    a last try of understanding how it works.
    1.step... i rate a song with 4 stars...
    2.step... RRMedia.exe (always activ) see it and save it in file rate.IN_ in my music folder. (with editor i can see the entries)
    QUESTION...is there another position where the number of stars would be saved too ?
    3.step...the song ended
    4.step.. a new song starts..RRMedia looks ???IN WHAT FILE?? for fixed stars to this song and set the flags.
    ALWAYS... cycled RRMedia looks if there are any changes.
    is there any thing i must fix in the rr.ini too ?
    the information in the exectbl.ini is the same as in your demo skin.
    also the entry in the menu.skin is done.
    i think the probelm is not the writing of selected stars, its the reading. therefore it would be nice if you can tell me which file(s) RRMedia read for fixed stars.
  9. #499
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    read the commands text file, couldn't work out if there was a Rescan media files option.
    say for example if you have dropped some extra mp3's in your audio directory.
    also is there a way to detect if RRMedia is running?
  10. #500
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Quote Originally Posted by GF-ler View Post
    #2 That "Rate.in_" file is really just for a backup purpose only, it writes the rating to the db and then to that file. This way if/when something tragic happened to the db file,
    all you have to do is delete ONLY the db file and upon creating a new db, it will put all of your prev rated songs back into to the db.
    #4 Everything is done through the db.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  1. Is there an Alpine blue for RR?
    By turbosx in forum RR Skins
    Last Post: 06-01-2008, 04:35 AM
  2. problems with navigation in streetdeck
    By customaudioman in forum StreetDeck
    Last Post: 01-25-2008, 01:46 PM
  3. RR 04-08-05 .. BETA Base Plugin ...
    By guino in forum Road Runner
    Last Post: 04-11-2005, 12:39 AM
  4. Does Any Winamp Plugin Work With Media Car ?
    By ccsnet in forum MediaCar
    Last Post: 11-23-2003, 02:39 PM
