Page 51 of 90 FirstFirst ... 414243444546474849505152535455565758596061 ... LastLast
Results 501 to 510 of 894
Thread: RRMedia Plugin by Blue ZX3 [v1.3.0 Released]
  1. #501
    Variable Bitrate GF-ler's Avatar
    Aug 2005
    germany
    #2 That "Rate.in_" file is really just for a backup purpose only, it writes the rating to the db and then to that file. This way if/when something tragic happened to the db file,
    all you have to do is delete ONLY the db file and upon creating a new db, it will put all of your prev rated songs back into to the db.
    #4 Everything is done through the db.
    thank you both,
    is it possible that anyone gives me a copy of his support folder. perhaps i found the reason in this way.
  2. #502
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    The support folder only contians "helper files" and files that are created durring scans would only be related to the system that its being ran on.
    What I might suggest is to del the db file, do the scan and either after it finishes or you get an error, zip up - rmdatabase folder, db file & your rate.in_ files and email em to me at ard781976 at yahoo com i have a look at this, with having a snap shot of everything a once, it should be much easier to see what is causing your issue. Is your db file still only ~29k in size?
    Current Project: DFXVoice [Beta Released]
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  3. #503
    Aug 2005
    germany
    all of it is true if i scan my music folder with version 1.0. i get all files you are talking about. i see whats missing...year, genre..aso.
    i get NO file with faults in my songs.
    because the slider in roadrunner didnt work with version 1.0 i upgrade it to 1.2.2. (your patch)
    the starlist function didnt work.
    so i ran the DB1.1 updater.
    the db with scanned song is 2376kB.
    and it didnt works.
    i delete the db in my music folder and start in your RRMedia skin "Build Database"
    he found the musicpath...scanned it....found NO playlists..after a short time its ready and it told me "O files found"
    the file is 29k.
    because the disc space i use music was very small i build a new folder on another harddrive.
    1 genre folder i copied to this new music folder, fix the new adress in the rr.ini and start a new building of the db.
    the result is a 29k file
    RRMediaDB.rar
    you see i try all ways of getting a db bigger than 29k. it dont like me.
  4. #504
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Sorry, GF-ler but that empty db file tells me nothing, i need everything RRMedia related. If would re-read my post it said what i wanted.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  5. #505
    Feb 2008
    Hello, I just want to say this is a great plugin. I have one problem that I can't seem to figure out. When i'm in browse mode and I have a mp3 selected, when I hit the "Play Select" button, it doesn't work. After about 15 seconds, it starts playing all these weird sounds. The thing I figured out is that if the mp3 is in the root folder that it does this.
    ie I set my default directory to D:\Music and have some mp3s in this folder and sub folders for albums. When I try to play any songs in the root directory, it doesn't work. But when I go into a sub folder, it plays it fine with the "Play Select." I even changed to the default folder to "D:\" and it works fine this way.
    Any ideas on why this is happening?
  6. #506
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Good question...and right now, I don't know. I'd have to move some files around and see what is causing this.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  7. #507
    Feb 2008
    Great! So this is not just some user error then. I though it kinda strange that a simple thing like this kinda went unnoticed so I thought I was doing something wrong.
  8. #508
    Constant Bitrate Stealth915's Avatar
    Bay Area, CA
    Blue, is there a way to do a search for multiple tag properties? For example, songs from Genre=R&B AND Year>2000?
    Also, I'm running into some problems with loading a playlist to a Disc, but I'm not sure if it's a DFX problem or a RRMedia problem, or if it's just me. I'll play around with it some more to see what's going on.
    2004 Mazda3 Carputer Worklog - Update 5/17/11: Carputer 2.0 Hardware Selection
  9. #509
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    No, the only way something like that would be possible would be for me to add a cmd to be able to spec a custom query, like WA's "active winamp" plugin...hmmm
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  10. #510
    Bay Area, CA
    Not sure if would be easier, but being able to search only within search results would be another way to do it. I wouldn't mind manually doing two searches to slim down the results to get a more specialized playlist.
  1. Is there an Alpine blue for RR?
    By turbosx in forum RR Skins
    Last Post: 06-01-2008, 04:35 AM
  2. problems with navigation in streetdeck
    By customaudioman in forum StreetDeck
    Last Post: 01-25-2008, 01:46 PM
  3. RR 04-08-05 .. BETA Base Plugin ...
    By guino in forum Road Runner
    Last Post: 04-11-2005, 12:39 AM
  4. Does Any Winamp Plugin Work With Media Car ?
    By ccsnet in forum MediaCar
    Last Post: 11-23-2003, 02:39 PM
