Page 54 of 92 FirstFirst ... 4444546474849505152535455565758596061626364 ... LastLast
Results 531 to 540 of 915
Thread: RRMedia Plugin by Blue ZX3 [v1.3.0 Released]
  1. #531
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    After you get the error, look in the RMDatabase folder and see whats in the debug_builder.txt file.
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  2. #532
    Feb 2006
    I think I solved it. See my edit to the post above this.
    The scanning is happening now on my CarPC. I got it to work fine on my HomePC (test machine). I did get an error on my CarPC (said something about it couldn't find RMBuilder.exe. I said OK on that dialog then tried again. It seems to be processing now. <shrug>
  3. #533
    Feb 2006
    Quote Originally Posted by EricE View Post
    I spoke too soon. It wasn't moving so I exited to see the dialog again...saying it couldn't find the RMBuilder.exe (but it IS there).
    Debug file says:
    11/7/2015 7:38:18 PM: RRMedia Builder> MediaInfo communitation OK!
    11/7/2015 7:39:03 PM: RRMedia Builder> File not found
    Edit: more info.
    It finds the music path and counts the files, then it says scanning...and then 200 files (...Checking file list) into my 2022 it fails with that error message. Window title is "Main" and the message is "File not found RMBuilder" The only button is OK.
    BTW, before that last message I tried uninstalling then installing, then rebooting.
    I thought it might be related to the date being wrong. The date was being set incorrectly by the GPS. I fixed that but that didnt fix the RMBuild error.
  4. #534
    Feb 2006
    Quick update to my problem.
    On the theory that the problem was related to some music file I had, I pointed winamp and RR at a directory with only one album in it. I was then able to build the DB just fine. So now I just have to sift through all my media and try and determine which file is causing the problem.
    Edit: I was able to solve my problem by finding all files with " ' " in them and removing the single quote from the file name and the track title.
  5. #535
    Mar 2008
    Hi Blue,
    I think something is not right with the unicode support in your plugin (which is great otherwise!).
    I have a lot of titles tagged with cyrillics (russian).
    They are shown correctly in most of the pages of most of the the skins (including your demo).
    Your demo skin uses unicode fonts throughout.
    Just 1 page - RM_Media.skin (one of the essential ones..) does not show the unicode correctly.
    Half-a$$ed solution - replace unicode fornt with non-unicode Win98 style font with Russian codepage 1251.
    Please see below:
    RM_Media.skin (bad. Arial font used)
    Audio_Playlists.skin (good. Arial font used)
    Audio_Player.skin (good. Arial font used)
    RM_Media.skin - FIXED (good. non unicode font used)
    Would it be possible to fix this? To fully support unicode?
    Thanks!
    --max
  6. #536
    FLAC Sal R.'s Avatar
    Aug 2006
    Sun Diego
    Database bug that was discovered after using EL CAMINO's MP3 Tag editor:
    i.e.
    Albums before tag edit:
    Splinter
    splinter
    I use EL CAMINO's MP3 tag editor to change "splinter" to "Splinter" and rescan database afterwards.
    Albums rescan after tag edit:
    Splinter
    splinter
    I delete the database file in $musicpath$ and re-build database.
    Albums after delete and rebuild dbase after tag edit:
    Splinter
    I've confirmed this with the Artist & Album list display (RM_Artist & RM_Album). Haven't tried Genre.
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
  7. #537
    Newbie fatrat's Avatar
    Jul 2008
    NORTH CAROLINA
    thanx for all the hard work. got one problem. when i installed the new skin, mt music would play until i selected browse. then it asked for me to build the music database, since then i can't listen to any of my music or will it build the database, any suggestion.
  8. #538
    Feb 2006
    Once again I am stumped on this.
    The issue is that the database builds but I do not get tagging info for my Flac files in my skin (Using Digital FX skin). I got winamp reading the flac tags fine. I am not sure the skin pulls the tags from the DB or from winamp. All I know is that winamp has the tag info but my skin doesn't. I don't see any errors when I build the RRMedia DB. It seems to build fine.
    Any help would be appreciated.
    Thanks.
  9. #539
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Try putting a copy of the "MediaInfo.dll" from the "Road Runner\RMDatabase\Support Files" folder in the RoadRunner folder and see if then your taginfo shows up. If there is already one in your roadrunner folder, just replace it as the one that comes with this plugin is newer that the one the might come with RR installer. RR does not nativly support non mp3/wma formats, but putting that file in RR dir will allow rr to read all kinds of different tag formats. I have brought this up to mitch and he will be including it with the next update installer..
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  10. #540
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    And as far as this plugin is concerned....I am making my way back to continue working on this, just trying to finish up some of the other projects as once i start working on this again it will be the only thing i will be working on as it is a type project that isn't easy to just jump in and out quickly.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  1. Is there an Alpine blue for RR?
    By turbosx in forum RR Skins
    Last Post: 06-01-2008, 04:35 AM
  2. problems with navigation in streetdeck
    By customaudioman in forum StreetDeck
    Last Post: 01-25-2008, 01:46 PM
  3. RR 04-08-05 .. BETA Base Plugin ...
    By guino in forum Road Runner
    Last Post: 04-11-2005, 12:39 AM
  4. Does Any Winamp Plugin Work With Media Car ?
    By ccsnet in forum MediaCar
    Last Post: 11-23-2003, 02:39 PM
