Page 55 of 92 FirstFirst ... 5454647484950515253545556575859606162636465 ... LastLast
Results 541 to 550 of 915
Thread: RRMedia Plugin by Blue ZX3 [v1.3.0 Released]
  1. #541
    Feb 2006
    Try putting a copy of the "MediaInfo.dll" from the "Road Runner\RMDatabase\Support Files" folder in the RoadRunner folder and see if then your taginfo shows up. If there is already one in your roadrunner folder, just replace it as the one that comes with this plugin is newer that the one the might come with RR installer. RR does not nativly support non mp3/wma formats, but putting that file in RR dir will allow rr to read all kinds of different tag formats. I have brought this up to mitch and he will be including it with the next update installer..
    Yep, that did the trick. Thanks much.
  2. #542
    Variable Bitrate Ramanator's Avatar
    Feb 2007
    Motor City
    Brother Blue,
    Started another install with the latest RR, Did the data base build and this is what I get. Searched for overflow and came up empty. Did I forget something or did I miss something.
    If you cant DODGE em, RAM em.
  3. #543
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Nope, you've hit the limit...sorta. John already found this bug and its on the top of the list of things todo/fix.
    You must have more than 32767 files in your musicpath and Y your getting that overlfow error.
    I do see in your SC that is what your prob is. I might just have to do a quick fix for this before it bits my behind some more...
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  4. #544
    Feb 2007
    Motor City
    Will the DB build up to this point or will it stay empty?
    Still a great job on this.
  5. #545
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    I would go out on a limb and say that your db should contain at least close to that limit. The builder commits the scanned tag info on every 2% increment.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  6. #546
    Feb 2007
    Motor City
    O.K. Thanks for the swift response. I'll probably just remove the last 20k for now so I can have it fully functional.
  7. #547
    Maximum Bitrate boelle's Avatar
    Oct 2008
    Odense, Denmark
    a very noob question... can this play movies (dvd iso's)?
  8. #548
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    As of the current version, no. I am possibly looking to add video to futrue versions.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  9. #549
    Aug 2008
    hello,
    i need some help with the plug.. i downloaded a EXE file & installed the EXE file... now what should i need to do?
    i want to make a disc what should i need to do?
  10. #550
    Variable Bitrate GF-ler's Avatar
    Aug 2005
    germany
    hi blue, after a long time and refreshed vcredist file rrmedia runs on my machine.
    now i have a small problem with the look of date and time.
    in the roadrunner install i can set the way roadrunner should show me the DATE and TIME.
    at the moment rrmedia shows me the look of UK/USA. is it possible to change DATED ADDED and LAST PLAYED DATE in way we use it in the other part of europe ?
    DAY | MONTH | YEAR
    OURS in 24 hours look, no AM/PM
    thanks
  1. Is there an Alpine blue for RR?
    By turbosx in forum RR Skins
    Last Post: 06-01-2008, 04:35 AM
  2. problems with navigation in streetdeck
    By customaudioman in forum StreetDeck
    Last Post: 01-25-2008, 01:46 PM
  3. RR 04-08-05 .. BETA Base Plugin ...
    By guino in forum Road Runner
    Last Post: 04-11-2005, 12:39 AM
  4. Does Any Winamp Plugin Work With Media Car ?
    By ccsnet in forum MediaCar
    Last Post: 11-23-2003, 02:39 PM
