Page 56 of 92 FirstFirst ... 6464748495051525354555657585960616263646566 ... LastLast
Results 551 to 560 of 915
Thread: RRMedia Plugin by Blue ZX3 [v1.3.0 Released]
  1. #551
    Sep 2006
    I have been working to finally get RRMedia working and after finally getting my library converted from WMA's to MP3's, downloaded version 1.2.2 and I am getting the following errors.
    AUTOIT ERROR
    Line-1:
    Error. the requested action with this object has failed
    This splashs over the main RR screen. Then when I try to rescan, I get another error.
    The second error is Main:
    Invalid procedure call or argument in RMbuilder
    The database is not scanning any of the music files.
    Any idea what the problem could be? Are there any windows services etc that RRMedia depends on?
    Edit: Solution
    For some reason there were .directory files in all of my music folders that was causing RRmedia to crash. Once the files were deleted the database built properly and the AutoIT error stopped popping up when loading RR.
  2. #552
    Mod - iPad Forums RipplingHurst's Avatar
    Dec 2007
    Danville, CA
    I have 43.157 music files in 10.253 folders. I have no problem using RR before (LSXVoid 3.0). So you're saying your great solution won't work for me? Will I get overflow errors?
    Also, will this help me index my collection of music video files (287 files)?
    Thanks.
    Update: Nope, I can't get it to scan my music folder. It freezes when it reaches 14% @ 3710 songs, and apparently does not see the entire library (it sees only 26493 files). I click to rescan it, but it stops again at the same point.
  3. #553
    Variable Bitrate Ramanator's Avatar
    Feb 2007
    Motor City
    Just realized that if I pressed a disk button in DFX the sound mutes/lowers. I can however raise the vol. back up through the skin after it does this but I do not remember this ever happening before. I have upgraded to the new RR but not sure if that is when it started.
    If you cant DODGE em, RAM em.
  4. #554
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    No it has always done that from the begining, lowering the vol when loading a disk.
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  5. #555
    Feb 2007
    Motor City
    Thank you Blue. But I do have another unrelated question that does not have to do with your plug-in, that I'm sure you know the answer too.
  6. #556
    Feb 2007
    Motor City
    Thanks, check your PM
  7. #557
    Jun 2008
    Atlanta, GA
    Is this by design or a future fix?
  8. #558
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    By design, yes. Its so that when it jumps back to the same loc in the saved track number you don't hear it play for a sec then jump to the position.
    For the next version, i might change how its doing it as well as a setting whether to allow it or not..
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  9. #559
    Jun 2008
    Atlanta, GA
    Is it also supposed to restore the volume once it jumps? In my car it stays muted even after the audio starts playing at the correct position.
  10. #560
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Yes, and there have only been like two reported cases where it didn't, and I have no idea why either.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  1. Is there an Alpine blue for RR?
    By turbosx in forum RR Skins
    Last Post: 06-01-2008, 04:35 AM
  2. problems with navigation in streetdeck
    By customaudioman in forum StreetDeck
    Last Post: 01-25-2008, 01:46 PM
  3. RR 04-08-05 .. BETA Base Plugin ...
    By guino in forum Road Runner
    Last Post: 04-11-2005, 12:39 AM
  4. Does Any Winamp Plugin Work With Media Car ?
    By ccsnet in forum MediaCar
    Last Post: 11-23-2003, 02:39 PM
