Page 57 of 92 FirstFirst ... 7474849505152535455565758596061626364656667 ... LastLast
Results 561 to 570 of 915
Thread: RRMedia Plugin by Blue ZX3 [v1.3.0 Released]
  1. #561
    Variable Bitrate GF-ler's Avatar
    Aug 2005
    germany
    i asked it in january the 5th,
    is it possible to change the format of DATE and TIME to the way i select it in the rr.ini.
  2. #562
    Variable Bitrate Ramanator's Avatar
    Feb 2007
    Motor City
    Quote Originally Posted by spamminator View Post
    Is it also supposed to restore the volume once it jumps? In my car it stays muted even after the audio starts playing at the correct position.
    By design, yes. Its so that when it jumps back to the same loc in the saved track number you don't hear it play for a sec then jump to the position...
    O.K. that's what I thought, Mine used to restore the volume seamlessly (didnt notice it muted) now it stays muted. O well, Gotta love it
    If you cant DODGE em, RAM em.
  3. #563
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    At current, I only had to defined diplay methods but might look into it just using whats defined in the rr.ini date format setting.
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  4. #564
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Well....somehow I got a candle(motivation) going again for this next update...not sure when but at least im getting back started on it again.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  5. #565
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Current status:
    Working on having two scan modes, Quick & Full. Quick will only look for new media and imports whats found only,so should be much quicker. Full is basically the same an the current recan, adding new media and removing old media entries that no longer exist.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  6. #566
    Low Bitrate mnwcsult's Avatar
    Mar 2007
    Maryland, USA
    RMBuilder.exe
    just crashes and I get this from Visual Studio debugger:
    Unhandled exception at 0x01a92613 in RMBuilder.exe: 0xC0000005: Access violation reading location 0x01e51000.
    First-chance exception at 0x01a92613 in RMBuilder.exe: 0xC0000005: Access violation reading location 0x01e51000.
    When run as stand alone I get a panel
    That starts with Status getting file count: J:\MegaCollection
    Next Getting ready for Import, I click Import, at 1% it then pops up the error and my debugger screen.
    The RMBuilder.db file is always 27k
    Any ideas?
  7. #567
    Mar 2007
    Maryland, USA
    RMBuilder.exe crashes on rescan, always
    Quote Originally Posted by mnwcsult View Post
    RMBuilder.exe
    Any ideas?
    Here is my RRMediaDB.ini
    # These six star command lines are for adding custom commands to
    # execute after the star indicators are set to the found rating
    [Star Commands]
    0star=RM_Rated0
    1star=RM_Rated1
    2star=RM_Rated2
    3star=RM_Rated3
    4star=RM_Rated4
    5star=RM_Rated5
    # This adds the song to the database if not found with no rating.
    # Would be good for creating a list of unrated song to go though at a latter time
    # (True/False, default is off)
    [Database Settings]
    DiskLoadingSplash=False
    Autoaddsong=False
    VirtPl=True
    # These settings are list viewing settings,
    # ListOrderBy (0=Alphabetical , 1= By Track Number, 2= File Name, 3= )
    # HomeView(0=Artists,1=Albums,2=Genres,3=Songs,4=Fol ders)
    [Saved Settings]
    ListOrderBy=0
    HomeView=4
    VirtPlNum=2
    CdLoaded=False
    LoadedCD=--
    # debugging=Debug window(ON/OFF), and coords for it to be located at.
    LastFile=2 fabiola - freak out.mp3
    [Debug]
    debugging=true
    x=0
    y=600
    [Stats]
    Startup List Creation Time(miliseconds)=379
    This is Builder.ini
    [Files]
    Line=0
    Total=18546
    RescanLn=0
    [Stars]
    Path=
    [Database]
    Done=False
    Rescan=False
    Rescanstep=0
    And BlankDiskTitle.ini
    # This setting allows you to set the default(empty) disk names
    # use the second option to append numbers to the end of the default name
    # ( 0= don't append any numbers, 1= add the numbers 1-10 to the end of the defaultname )
    [Default Disk Name]
    DefaultName=Unknown
    AppendNumbe=1
    I'd really like to get this solved.
    TIA
  8. #568
    Mar 2007
    Maryland, USA
    RMBuilder.exe
    Any ideas?
    This is from file Builder_Debug.txt
    2/8/2009 1:19:00 PM: RRMedia Builder> MediaInfo communitation OK!
    2/8/2009 1:19:35 PM: RRMedia Builder> Data_Dump > 'REM - Losing My Religion (Acoustic).mp3','Losing My Religion (Acustico)','REM','xxx','','32','.m','Alternative. Punk\','',0,'','20042103094048','2009/02/08/13:19'
    2/8/2009 1:19:35 PM: RRMedia Builder> unrecognized token: "xxx"
    I subsituted the NULL character with 'xxx' so that I could cut and paste the text in this message.
    On my day job I a Software Engineer and we see this a lot when passing data into SQL Server. In the helper folder there sits Sqlite3.exe and Sqlite3u.dll so my guess is something similar is happening here.
    My first hint of what might be happening was a folder name "70's Rock" RMBuilder returned this message RRMedia Builder> unrecognized token: "'" I had to really look at it and noticed the aposthrophe between the quotes. So I changed the folder name to "70s Rock" and reran the builder.
    RMBuilder got further next returned RRMedia Builder> unrecognized token: "'" on the next folder "80's Rock". There is a trend forming here. So changed the name to "80s Rock" and started over.
    Which got me to the message I began the discussion with the NULL character.
    SQL in general is sensitive to apostrophes, quotes and many other characters in text fields.
    We filter much more heavily to prevent SQL injection attacks, here is some example code:
    'Function IllegalChars to guard against SQL injection
    Function IllegalChars(sInput)
    'Declare variables
    Dim sBadChars, iCounter
    'Set IllegalChars to False
    IllegalChars=False
    'Note vbNullChar is the same as chr$(0)
    'Create an array of illegal characters and words
    sBadChars=array("select", "drop", ";", "--", "insert", "delete", "xp_", _
    "#", "%", "&", "'", "(", ")", "/", "\", ":", ";", "<", ">", "=", _
    "[", "]", "?", "`", "|", "declare", "convert", chr$(0))
    'Loop through array sBadChars using our counter & UBound function
    For iCounter = 0 to uBound(sBadChars)
    'Use Function Instr to check presence of illegal character in our variable
    If Instr(sInput,sBadChars(iCounter))>0 Then
    IllegalChars=True
    End If
    Next
    End function
    You could use something similar to this to replace unwanted/illegal characters with "" a NULL string.
    I hope this helps as I like to program but outside of work I really just do not have the time. So I greatly appreciate your efforts and the work of all of the others who contribute so much to the rest of us.
    -Michael
  9. #569
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    First...Thanks, if you've followed this whole thread, you'd see how much time/effort I have put into this project already(~10 monts & ??? hrs), and like everything else...its never really done.
    Back to topic. I do know about the whole quote thing and have tried my best so far to fix what I find or others have reported. The only big problem with removing any chr's from the path, is that when a playlist is needed to be created, the path will be incorrect and those songs contained with that path will not be played.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  10. #570
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    What you could do then is do a substitution. Here's an idea.
    Convert the illegal characters/words into HEX representation of the ASCII value, then prefix it with a character which is invalid in Filenames but has no effect in SQL and follow the prefix by a number representing the number of characters in HEX.
    then do the reverse conversion when reading from the database.
    or just convert the whole string you put into the database into HEX, and then reconvert when reading.
  1. Is there an Alpine blue for RR?
    By turbosx in forum RR Skins
    Last Post: 06-01-2008, 04:35 AM
  2. problems with navigation in streetdeck
    By customaudioman in forum StreetDeck
    Last Post: 01-25-2008, 01:46 PM
  3. RR 04-08-05 .. BETA Base Plugin ...
    By guino in forum Road Runner
    Last Post: 04-11-2005, 12:39 AM
  4. Does Any Winamp Plugin Work With Media Car ?
    By ccsnet in forum MediaCar
    Last Post: 11-23-2003, 02:39 PM
