Page 63 of 92 FirstFirst ... 13535455565758596061626364656667686970717273 ... LastLast
Results 621 to 630 of 915
Thread: RRMedia Plugin by Blue ZX3 [v1.3.0 Released]
  1. #621
    Variable Bitrate Jebus's Avatar
    Dec 2007
    Washington, USA
    Hmmm...
  2. #622
    Oct 2006
    Midlothian, VA
    I have that exact same problem. Also, nothing shows up under the plugin manager in DFX 4.
  3. #623
    Feb 2006
    Quote Originally Posted by EricE View Post
    I am getting an error when I try and build the media db.
    5/4/2009 12:25:26 PM: RRMedia Builder> MediaInfo communitation OK!
    5/4/2009 12:25:32 PM: RRMedia Builder> no such table: Audio
    Then a dialog pops up that says something about no such volume table. I looked in the voltable.ini and there is nothing but comments but I think that is the default anyway. Whats going on here?
    Please help. I have spent close to 20 hrs trying to debug an error that I get on startup and I have finally tracked it down to the media db plugin.
    Edit: I am on the latest version 1.2.2 and I just reinstalled to make sure everything was fine. Still getting error.
    I was able to fix this by deleting the media.db and backup... The media.db is not easy to find, one has to look in your root music path.
  4. #624
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Quote Originally Posted by Jebus View Post
    Hmmm...
    Quote Originally Posted by ksgoh88 View Post
    This is related to the 5/1/09 release, the added img list support and incorrect skin files with an incorrect custom list definition.
    My DT PSU crapped out on sunday , so momentarly can't exactly get to said files that I fixed. I'll see what I can do have John post a Fixed zip of all the DFX screens that contain a custom list.
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  5. #625
    Dec 2007
    Washington, USA
    Just do this in Any skin that has Ilist BEFORE list definitions:
    SC,55,140,381,373,#DFX1R#,#DFX1G#,#DFX1B#,255,128, 0,255,255,255,0,0,0,,20,"Arial"
    IL,CL,transparent.bmp,sel.bmp,end.bmp,2,50,80
    Flip em so the Ilist is after....
    And it all works again. Something IN the last RR release?
    ...JJG
  6. #626
    MySQL Error
    Oct 2004
    NO, Jebus, just a illegal skin command there...
    the SC definition is bad... the 255 after #DFX1b# should be a 0
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  7. #627
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    FYI...
    No PSU yet, but....
    John is/has posted in the #2 post in the DFX thread a zip of all the screens that have a custom list defined with all the correct parameters. So now works with all RR versions again...
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  8. #628
    Newbie taguy83's Avatar
    Mar 2008
    Roseville, MI
    Virtual Disk Problem
    I have read this entire thread looking for an answer, but couldnt seem to find one. I am using v. 1.2.2 and DFX 4.0, my database works wonderful, never any errors, the only problem I am having is I will open RR, and assign names to all my Virtual Disks, and then add all the songs I want to each one. Then I will push the backup button and it says it backs up the disks and everything works fine. However when I reboot the machine, I go back and open RR again and all of my Virtual Disks go back to default, no names, no songs, I push restore Disk, and it restores nothing. Any ideas? Thanks!
    1995 Pontiac Trans Am
    AMD X2 Dual Core, 4GB Ram, 500GB Hard Drive, Lilliput 629GL, BU353 GPS w/Iguidance, Opus 360 Psu
    Parts - 100%
    Software - 70%
    Installation - 30%
  9. #629
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    After you back them up, look in your music path for a RMDisksbackup._ file. If its there(should be), open in notepad and see if it has disk names/tracks.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  10. #630
    Mar 2008
    Roseville, MI
    Thanks Blue, I will check that later when I am home, so if it does have the disk names and tracks then it should be ok?
    Parts - 100%
    Software - 70%
    Installation - 30%
  1. Is there an Alpine blue for RR?
    By turbosx in forum RR Skins
    Last Post: 06-01-2008, 04:35 AM
  2. problems with navigation in streetdeck
    By customaudioman in forum StreetDeck
    Last Post: 01-25-2008, 01:46 PM
  3. RR 04-08-05 .. BETA Base Plugin ...
    By guino in forum Road Runner
    Last Post: 04-11-2005, 12:39 AM
  4. Does Any Winamp Plugin Work With Media Car ?
    By ccsnet in forum MediaCar
    Last Post: 11-23-2003, 02:39 PM
