Page 67 of 92 FirstFirst ... 17575859606162636465666768697071727374757677 ... LastLast
Results 661 to 670 of 915
Thread: RRMedia Plugin by Blue ZX3 [v1.3.0 Released]
  1. #661
    Nov 2006
    Turn on the RR debug and then the RRMedia builder debug opt found in the Support Files folder's builder.ini, in the debug sect status=true. Rerun the RR and in your RMDabase folder you should have a builder_debug.txt file...then just attach the the file here, and we'll go from there...
    Hopefully something simple....as I really don't want to spend too much time figuring out what it is as i do have another ver just around the corner...
    This is what I'm getting...
    6/30/2009 9:53:56 PM: RRMedia Builder> Mediainfo communitation OK!
    6/30/2009 9:54:05 PM: RRMedia Builder> Invalid procedure call or argument
  2. #662
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    try deleting the RRMediadb.db file in your music path, and try again.
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  3. #663
    Nov 2006
    I'm not sure I know where to find this, is this under the RMDatabase?
  4. #664
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Your music path as in the one you set in the RR Config. ie..where your musci is located...
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  5. #665
    Nov 2006
    Awesome!!! That fixed the problem. Sorry about the delay in my response, I'm actually at work I just give going back and forth in the parking lot...
  6. #666
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    Blue i'm attempting this mammoth pi here , and i had to add X,RRMediaDB to my menu skin... for it to work is this still the case when you update.
  7. #667
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    The "X,..." line in the menu skin is RR related, has nothing to do with my plugin. It just tells older RR's to load the PI, but newer RR's use the RR\Plugins\... folder for global loading a PI, and RR\skins\xx\Plugins\.. for skin loading a PI.
    You could put it in the menu screen as that will keep it cross version compatible, RR will only load each plugin instance once.
    I am forcasting a many IM's in near future from you...
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  8. #668
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    lol hope not just going to play at the moment ,, theres alot of cmds not in the demo,, bit mind boggling at mo lol.... as for the plugins folder yes i understand,,, as i used your install and it installed in rr root, so if i de-reg and move to the plugins/folder all should be good ???
  9. #669
    Raw Wave
    Jun 2002
    Virginia
    Okay, I've tried everything to get the database to work after a recent reinstall and can't. The database builds and everything works fine until I actually do a search. No matter what search criteria I use it produces no results. Relevant info is as follows:
    XP SP3
    RR Version 05/1/09
    Digital FX 4.0
    Followed RRMedia installation instructions and registered all DLL files.
    Built database and verified that database file exists and path is correct.
    Riderunner.exe, RRmediaDb.exe and Roadrunner.exe all show as running processes in Task Manager.
    Any thoughts?
    Update: I see now that the database is producing search results, they're just not showing on the screen. If I click somewhere on the results screen and click play select, the songs plays. The song is just not visible on the search results screen. Hmm, I thought I read something about that earlier in the thread and will double check.
  10. #670
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Well, I was gonna say about he size of the db but you say that everything else works fine...so that answers that...
    Aside from it not working for you in dfx 4, by chance did you try it in the demo skin?
    I'm kinda lost as for it working everwhere else, execpt the search. What search, one particual on or all ?
    Sorry I don't have a more definded answer for you...
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  1. Is there an Alpine blue for RR?
    By turbosx in forum RR Skins
    Last Post: 06-01-2008, 04:35 AM
  2. problems with navigation in streetdeck
    By customaudioman in forum StreetDeck
    Last Post: 01-25-2008, 01:46 PM
  3. RR 04-08-05 .. BETA Base Plugin ...
    By guino in forum Road Runner
    Last Post: 04-11-2005, 12:39 AM
  4. Does Any Winamp Plugin Work With Media Car ?
    By ccsnet in forum MediaCar
    Last Post: 11-23-2003, 02:39 PM
