Page 72 of 92 FirstFirst ... 22626364656667686970717273747576777879808182 ... LastLast
Results 711 to 720 of 915
Thread: RRMedia Plugin by Blue ZX3 [v1.3.0 Released]
  1. #711
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Quote Originally Posted by spamminator View Post
    Are you using 2.3 or 2.4 ID3 tags? I think I've had issues when using 2.4.
    This is some good intel (not the proc kind ) And to further the details even more... what SW are some using? I have Tag & Rename v3.4 that supports ID3v1-2.4 but only writes v2.3 which I'm assuming is the NON unicode one that all players old & new can read. And might be the reason that some are still having problems even though they do tag the media
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  2. #712
    FLAC Dougw133's Avatar
    Nov 2007
    PA
    This is some good intel (not the proc kind ) And to further the details even more... what SW are some using? I have Tag & Rename v3.4 that supports ID3v1-2.4 but only writes v2.3 which I'm assuming is the NON unicode one that all players old & new can read. And is the reason that some are still having problems even though they do tag the media
    I am using the same version of tag and rename blue. I thought I deselected the option for unicode as I have read it can cause issues.
  3. #713
    Dec 2006
    Netherlands
    i'm new to RMdb plugin. first i want to thank blue for his effort done so far.
    i also have some issue building the database. it stops at 33%.
    when i restart riderunner and clicked rescan, it picks-up from 32% and stops again at 33%.
    the rmbuilder returns an error: unrecognized token: "" Lite.X.LiteStatement.1
    i isolated the folder with the bad mp3s and renamed it with tag & Rename to 2.3 but it still doesn't work.
    will the new RM 1.3 resolve this?
  4. #714
    Variable Bitrate navputer's Avatar
    Jan 2007
    DFW Area
    Support sort by Track Number?
    Blue,
    Will the new version have the option to sort by Track Number?
    In Playlist (Sort List shows...)
    Title Alphabetical
    Filename Alphabetical
    Reverse Order
    Randomize
    Thanks...
    Gee
  5. #715
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    RRMedia supports By Track when it creates the playlist to play. Those opts are using WA directly to sort the list, which doesn't have that. I don't know why either....
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  6. #716
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Quote Originally Posted by DJCannonball View Post
    It might, do you have any quotes ->"<- in any of those tags?
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  7. #717
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Maybe a simple $SongTitle = StringReplace($SongTitle,Chr(34),"") would do the trick in the builder code where the tag is initially read? This would kill any potential errors, if they exist or not, more just "Being on the safe side" so to speak.
    My Fiero Build Thread
  8. #718
    Aug 2008
    I get a similar but different error on my song import at 99% complete. I am using DFX 4 with RR media upgraded to 1.22 using the patch exe. The error is
    near ",": syntax error LiteX.LiteStatement.1
    Can I figure out what song is the problem if any, or is this a syntax error in the RRMedia code?
  9. #719
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    E..err both sorta
    It probably a coma(s) in a tag somewhere causing the issue. Seeing that it got 99% it must be a song that is in on of the last folders(alpha wise) in your music path.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  10. #720
    Mod - iPad Forums RipplingHurst's Avatar
    Dec 2007
    Danville, CA
    I am eagerly awaiting v.1.3; I have too many songs to test as it is right now.
    I actually think this should be part of the standard RR code! Media management, playlist creation, etc. should be in every skin. (My favorite one, Carwings, does not have it, sadly).
    I'm sad to hear about unicode issues, though. How can they be a problem? It's just a tag? ().
    Hope they can be solved, I have a lot of music with Unicode tags.
  1. Is there an Alpine blue for RR?
    By turbosx in forum RR Skins
    Last Post: 06-01-2008, 04:35 AM
  2. problems with navigation in streetdeck
    By customaudioman in forum StreetDeck
    Last Post: 01-25-2008, 01:46 PM
  3. RR 04-08-05 .. BETA Base Plugin ...
    By guino in forum Road Runner
    Last Post: 04-11-2005, 12:39 AM
  4. Does Any Winamp Plugin Work With Media Car ?
    By ccsnet in forum MediaCar
    Last Post: 11-23-2003, 02:39 PM
