Page 86 of 92 FirstFirst ... 367677787980818283848586878889909192 LastLast
Results 851 to 860 of 911
Thread: RRMedia Plugin by Blue ZX3 [v1.3.0 Released]
  1. #851
    Sep 2003
    Thousand Oak, Ca
    I'm running DFx5 and still no WMA tags showing up. RRMedia 1.3 comes with DFX5 built in? Aside from rebuilding the database is there anything I need to do?
  2. #852
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    I think there might be something with your files. I'll check tonight using the v1.3 released with dfx5 and let you know, if mine show up. I only have one album that's wma format.
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  3. #853
    Mod - all of it.
    Jul 2007
    Buena Park, So Cali
    I have 850+ albums of wma files and RRMedia plugin works great for me. I think it is something with your files too. Delete your database and try again.
    CAR: 2007 G35 Sport Coupe 5AT
    HARDWARE: Dell D630 w/ dock, internal 80G HD, internal 320G HD, Verizon Wireless Card, iBlue GM-2 GPS w/iGuidance, OBDPros w/DashCommand, Visteon HD Radio w/ Home Made Cable, Current Version of RR w/ DFX Skin. My Install.
  4. #854
    Variable Bitrate navputer's Avatar
    Jan 2007
    DFW Area
    Automation Error: Invalid syntax RMBuilder
    I am having a problem rescanning my database after doing a reinstall of RR and DFX 5.0. I have deleted the database and well as uninstall RR and DFX 5 but still the same error message upon running any scan. I went directly to the RRMedia folder to run the rmbuilder.exe file and the got the error as well "Automation error - invalid syntax...Rmbuilder". I have registered the rrmedia.dll file as well. However, I see my music files and can play them without any problems just can't do a rescan.
    Anything else I should look for or correct?
    RR Dec Rel
    WinXP Pro SP2
    Thanks for your help.....
    Edit:
    I unregistered all RRMedia dll files and completely uninstall RR, DFX 5, remove all RR/Skin folders, winamp and did a registry clean to be sure everything was gone.
    After this, I install winamp (5.13), RR (Dec). I could see my music listings in Carwings. This works.
    So, I install DFX 4 next and tried to run a scan and it did not work. So, I ran a manual scan using the rmbuilder.exe and it puledl a scan. So, I thought it would work in DFX 5 too.
    Next, I installed DFX 5 and tried to run a scan and got the same error message as before.
    I've looked to see which dll or rmbuilder it is using and I can't tell. I am lost on this one and need help.
    Since I did a clean install of WinXP Pro, I only wanted to install RR, DFX 5 and plugins. So, is the RMDatabase installer required as well before installing DFX 5?
    Attached Files Attached Files
    Gee
  5. #855
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Sorry, didn't notice your issue posting...
    We (DFX Dev Team) are no longer recommending the WA v5.13 as the newest versions have no issues and is what we are using when developing and testing.
    DFX 4 used the 1.2.2 version, which didn't get updated to follow the newer RR plugin guide lines, though not a deal breaker. Mostly was just the PI files locaton, Plugins folder verse RR root. The 1.3.0 version is now in the plugins folder, and if you have the 'RMDatabase' folder in your RR root, make sure that the RRMediadb.dll is unregistered. You really should be able to just delete that folder after that as there should be no issues with using the newer version with DFX4.
    As far as the debuging logs are conserned, you'll need to go to the: %APPDATA%\RRMedia folder (C&P into run box), open the RRMediaDb.ini and set the general debug (and if there debugfull) to True. Then delete your db file and try another scan, posting all the debug logs from that same folder. Log filename formats will be 'RRMedia(xx)_Debug.txt', where xx is what part that log belogs to, like RRMedia(Builder)_debug.txt / RRMedia(Main)_debug.txt / RRMedia(DLL)_debug.txt.
    DFX5 comes with the latest RRMedia, so no further RRMedia install is nessary till there are updates to the 1.3.0 version.
    Then we'll go from there.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  6. #856
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Arrow v1.3.0 Installer
    The stand alone RRMedia v1.3.0 installer is now up on the download page.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  7. #857
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Smile
    I have just tried this new 1.3 version .
    A very cool version that run well now
    Just one thing , i have a folder with a title like that, that RRMedia don't see
    Code:
    01-Bill Haley _ 1.  Rock around the Clock.mp3
  8. #858
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Um I lost... What part is the file and what part is the folder name?
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  9. #859
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by pierrotm777 View Post
    Code:
    I think he means filename.
    If so I know I've previously had issues with filenames with "." in the middle when doing RRUpd8
    or if he really means that's a folder name then I can see many folder searches ignoring it.
  10. #860
    Maximum Bitrate RAWPWR's Avatar
    May 2007
    Blue, this newest version of RRMedia is already in DFX5, but without the skin changes? (I think). The reason I ask is that I don't have 100 disks in disk changer, all I see is 10 disks. So this should be in the upcoming DFX5 patch, right? Thx.
  1. Is there an Alpine blue for RR?
    By turbosx in forum RR Skins
    Last Post: 06-01-2008, 03:35 AM
  2. problems with navigation in streetdeck
    By customaudioman in forum StreetDeck
    Last Post: 01-25-2008, 12:46 PM
  3. RR 04-08-05 .. BETA Base Plugin ...
    By guino in forum Road Runner
    Last Post: 04-10-2005, 11:39 PM
  4. Does Any Winamp Plugin Work With Media Car ?
    By ccsnet in forum MediaCar
    Last Post: 11-23-2003, 01:39 PM
