Page 13 of 18 FirstFirst ... 3456789101112131415161718 LastLast
Results 121 to 130 of 178
Thread: Outlook Express Email Plugin- Re-Release!
  1. #121
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    bah i left a messagebox in there i see it now. redownload from the same link and just change the rrmail.dll
    Live mp3Car Facebook Chat
  2. #122
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    lol.... right ok now thats gone, run cmd , skin loads , no outlook activity (did'nt get any with old version just tryed either) skintool say's RRMAIL;LIST cmd not executed
    which i know dose'nt mean alot ,i get that with alot of plugins and they still work
    Riderunner / Genesis
    Wifiman_NET:Version 1.0.0
  3. #123
    Woodbridge, VA
    Blog Entries
    55
    is kWab.dll installed in RR directory and registered? Do any commands work? Try RRMail;Compose or RRMAIL_CONTACTS
  4. #124
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    Quote Originally Posted by Sonicxtacy02 View Post
    kWab.dll is in rr root ,but could not reg, "entry point was not found"
    RRMail;Compose = nothing
    RRMAIL_CONTACTS = from skin tool, popup appeared but it was blank, no labels in buttons at the bottom or list.
  5. #125
    Woodbridge, VA
    Blog Entries
    55
    Quote Originally Posted by carputer1 View Post
    Code:
    Case "rrmail_contacts"
                RRSDK.Execute ("menu;rrmail_contact_list.skin")
                ContactYes = "Select"
                ContactNo = "Cancel"
                If contactsReceived = False Then
                 Call getContacts
                End If
    ContactYes and ContactNo are the variables that set the labels for RRMAIL_CONTACTYES and RRMAIL_CONTACTNO. There's no reason the labels should not populate if the skin was launched. There's something fishy goin on in your setup bro. You arent in profile mode or anything weird right? Does the plugin manager show the plugin is loaded successfully in RR's debug.txt?
  6. #126
    Variable Bitrate navputer's Avatar
    Jan 2007
    DFW Area
    Ok, i have started testing on my pc...
    Install folder in default riderunner folder
    Copied kwab.dll into root of riderunner path
    Registered rrmail.dll fine
    Registered mapi32.dll did not work
    Registered msmapi32.ocx fine
    Copied info from ADDTOSKIN.ini to skin.ini
    Copied Example skin files to my DFX 4.0 folder
    Opened OE
    Created button to read rrmail_read
    Open RR, ran rrmail, skin opens but no email activity.
    I can choose compose, contact list fine but no activity on the screens.
    I tried it with OE closed but still same thing.
    Gee
  7. #127
    Woodbridge, VA
    Blog Entries
    55
    Quote Originally Posted by navputer View Post
    Copied kwab.dll into root of riderunner path - registered fine
    Opened OE
    i hope you mean you are running the command RRMail;list and not doing load;rrmail_read.skin. What OS are you running?
  8. #128
    Jan 2007
    DFW Area
    I tried it with both but on load;rrmail_read.skin or load;rrmail_list.skin, the skin came up but no activity. When I tried RRMail;list - nothing happened (Edit - locks up RR).
    I am running WinXP Pro.
    Gee
  9. #129
    Jan 2007
    DFW Area
    UPDATE: Did same install steps as before (this time only RRMAIL;LIST)
    I loaded this on my test PC at home (other one was at work) and I was able to get the messages to come through fine. Quick notice is that it only pull some many messages. I will continue trying some of the other options.
    Gee
  10. #130
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    FIY up and running , but at work only (non-profile)
    not sure if its down to profile or not can't why it should be , is your plugin looking for any rr files on start , anyway we are running testing will be limited , due to work ,people keep crashing thier cars lol...
  1. New Features Progress Update
    By reddeath30 in forum Mobile Impact
    Last Post: 07-31-2007, 06:54 PM
  2. Plugin Request - Email reading application
    By ankur in forum CF Plugins
    Last Post: 01-25-2007, 01:06 PM
  3. Receiving email (Pop3) what am I doing wrong
    By pshadwick in forum Wireless Communications
    Last Post: 06-02-2006, 11:37 AM
  4. Outlook XP Problem
    By ODYSSEY in forum Off Topic
    Last Post: 12-22-2002, 02:52 AM
  5. Resumer Winamp plugin..works with MPC, too
    By Tony S in forum Software & Software Development
    Last Post: 03-30-2002, 06:10 PM
