Page 15 of 18 FirstFirst ... 56789101112131415161718 LastLast
Results 141 to 150 of 178
Thread: Outlook Express Email Plugin- Re-Release!
  1. #141
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    the contact list stuff is all done by kWab.dll. That's a 3rd party .dll... but i'll try to debug it through my .dll. For the time being.. put kWab.dll in the plugin folder instead of the RR folder and see if that fixes it.
    Quote Originally Posted by navputer View Post
    I had that occur too. I mentioned that in one of my comments above.
    Some other things I have noticed.
    1. Only happens sometimes - When finish reading a message and select 'back', the top screen that list all of the messages are blank. You have to close rrmail and it will re-populate the messages. It happened a couple times but it worked fine after reopening and closing.
    2. Sorting - Can you sort by newest mail first and not oldest mail first - my opinion.
    3. This may be by default;not sure - on the list skin, when you use the arrows page up, up, down, page down, the view message pane does not change. If you select the message in the list window, the view message pane changes.
    4. Reading a message - When reading a message and using the arrows on the side to scroll up or down(example skin), it seems to show (highlight) the text information twice going from line to line. It only happens if there is a blank line above or under the text.
    Thanks...
    1.the you MUST use CLOSEMAIL to terminate the mapi connection or the list screen wont be able to establish a new connection. I'm brainstorming for ideas around this but that explains the issue.
    2. Sorting is SUPPOSED to be handled by a a method in the mapi functions but i too have noticed it doesnt work correctly. I will work in my own sorting method.
    3. I will fix this... but in the temporary just change the arrow buttons to <COMMAND>||ONCLCLICK ex. UP||ONCLCLICK
    Quote Originally Posted by carputer1 View Post
    Regards to the lines doubling up in read screen, I had this
    I added ilist line to the skin file that seems to of fixed it
    this happens because you need to adjust the charsplit number in skin.ini to fit your skins. Does it happen in the example skin? It doesnt on this end.
    Tomorrow i will be releasing a debug enabled version with all the improvements i can fit into a days worth of work. Hopefully that will help us track down the contact list issue.
    Live mp3Car Facebook Chat
  2. #142
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    its in example skin s mate
    Riderunner / Genesis
    Wifiman_NET:Version 1.0.0
  3. #143
    Woodbridge, VA
    Blog Entries
    55
    hmm .. i'll test it again.. but that split has got to be the issue. The split essentially tries to prevent RR from performing its natural behavior of scrolling the selected line if the content is longer than the CL width. If the split variable isnt right it will tell RR to duplicate whatevers selected to the next line. The email scrolling will never be perfect because of this i'm afraid but i'll work to make it usable
  4. #144
    Woodbridge, VA
    Blog Entries
    55
    did you try putting Kwab.dll in your plugin folder?
  5. #145
    Woodbridge, VA
    Blog Entries
    55
    i re-checked this just now.. that should not be happening. I'm not deleting the content of the CL on the list screen.. using the CLOSE command on rrmail_read.skin takes me back to a populated list every time.
  6. #146
    Woodbridge, VA
    Blog Entries
    55
    i have no idea why but the fetchsorted method for message retrieval simply isnt working. No error messages or anything. I even tried sorting the messages outside of the mapi procedure but vb6 doesnt have any date sort routines. I'm seriously considering making this a .net app
  7. #147
    Woodbridge, VA
    Blog Entries
    55
    fixed issue where rrmail would crash on reloadskin/reloadrr
  8. #148
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    great news sonics, as for the other problems mentioned so far , up/down buttons i'm pretty sure they work for me, and i have not noticed the list going blank after a read , just the double up of lines when useing up/down which you seem to think you have solved, or solving, i can't be 100% as i can't tetst till i'm back at work in 2 days time.
    still trying to get it to work here ,
  9. #149
    Woodbridge, VA
    Blog Entries
    55
    this is gonna be delayed guys i've had a crazy day at work and i'm only halfway done adding the debug lines. I'll have to pick it up monday.
  10. #150
    Maximum Bitrate boelle's Avatar
    Oct 2008
    Odense, Denmark
    subscribed...
  1. New Features Progress Update
    By reddeath30 in forum Mobile Impact
    Last Post: 07-31-2007, 06:54 PM
  2. Plugin Request - Email reading application
    By ankur in forum CF Plugins
    Last Post: 01-25-2007, 01:06 PM
  3. Receiving email (Pop3) what am I doing wrong
    By pshadwick in forum Wireless Communications
    Last Post: 06-02-2006, 11:37 AM
  4. Outlook XP Problem
    By ODYSSEY in forum Off Topic
    Last Post: 12-22-2002, 02:52 AM
  5. Resumer Winamp plugin..works with MPC, too
    By Tony S in forum Software & Software Development
    Last Post: 03-30-2002, 06:10 PM
