Page 8 of 18 FirstFirst 1234567891011121314151617 ... LastLast
Results 71 to 80 of 178
Thread: Outlook Express Email Plugin- Re-Release!
  1. #71
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    here is fine
    Live mp3Car Facebook Chat
  2. #72
    Nov 2004
    St Louis
    When I first hit the RRMail utton I waqs pleasantly surprised how well designed your sample skin was as well as how well RRMail worked. The preview mode is outstanding. The plugin has some difficulty with HTML mail but it looks very professional. Too bad about the fonts, text size could have been a little bigger.
    O.K. since my preferred email browser is outlook, I just imported my inbox into express to test this. I started out with 60 messages total and all unread. when opening your sample skin I got the following popup.
    My choices were 1,2,5, and 10 minutes. So for those of us reverting from Outlook you can only use this plugin for 10 minutes at a time???
    I know I didn't open all the emails, and I checked back and forth between RRMail and Express, but I believe having paged down in preview mode through my mail, RRMail thinks all mail had been read:
    And somehow dropped three messages. When I go back to Express all 60 messages are still there and three are marked read.
    Lastly, when I try to send a message I have three issues. The text typed into the message body doesn't wrap so reviewing it prior to sending is difficult with a touchscreen. If I try to use the Contacts button, the selected contact is not put into the "TO:" field. Also the Contact menu doesn't close properly using the cancel command. And if I open the Contacts menu again it duplicates the contacts (I started with 4 contacts, closed the menu, reopened it and there were 8, closed and reopened and there were 12 - the same 4 repeated over and over). Finally, when I hit SEND, I got another popup:
    I guess this one is based on the security settings in outlook but it was still annoying.
    Overall, great progress! Its usable now but I haven't skinned all the available commands yet so there should be more to come later this week.
  3. #73
    Woodbridge, VA
    Blog Entries
    32
    Quote Originally Posted by GizmoQ View Post
    Thanks for the compliments on the example skin. I'm pretty bad with photoshop so i appreciate it! And yes the plugin currently cant read html mail, tho if ican find a way to download the html content to a file i should be able to parse any text.
    This has to have something to do with Outlook vs outlook express. With vb6's mapi everytime a messages body is accessed the file is marked read.. so each time RRMAIL is run all messages in the folder are marked read in OE. I personally dont like that ... but there's nothing i can do about that unless i get rid of the preview box.
    did you put kwab.dll into road runners base directory? and have you added the lines to exectbl.ini? kwab.dll has everything to do with contact management and there are lines in the addtoexectbl.ini file needed to tell RRMAIL which contact is selected. The cancel button issue is more than likely caused by the same thing causing yoru contacts not to work. The commands functionality is dependent of the contacts list telling RRMAIL what its doing (selecting or cancelling). The contact duplication thing is something iknew but obviously forgot to fix.. so i'll do that. Lastly, the pop up is definitely an outlook security feature. This plugin is really only meant for OE at this time... so you'd have to switch OE to your preferred for the time being. I will look at Outlook integration.
  4. #74
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    For some reason I cannot even get the skin to open when I push a button I made “RRMAIL” rr just speaks rrmail.
    I tried to adding x,rrmail.dll to the MENU.skin
    I just do not know what else to try.
    2001 S10 ZR2
    Chucks Skin - to old
  5. #75
    Woodbridge, VA
    Blog Entries
    32
    its not rrmail.dll... just put x,rrmail
  6. #76
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    Sorry I did have x,rrmail but I had it in INC,Plugins.txt and that would not work.
    None of the INC,files work.
    And I had to set outlook express as the default e-mail.
    Still having problems trying to see panview.
    2001 S10 ZR2
  7. #77
    Woodbridge, VA
    Blog Entries
    32
    try to manually run RRMAILREFRESHPREVIEW to see if preview displays, but make sure the email is NON-html
  8. #78
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    Sorry I had the text set to black and could not see them. LoL
    2001 S10 ZR2
  9. #79
    Woodbridge, VA
    Blog Entries
    32
    lol ah well one less bug for me
  10. #80
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    so far so good
    2001 S10 ZR2
  1. New Features Progress Update
    By reddeath30 in forum Mobile Impact
    Last Post: 07-31-2007, 06:54 PM
  2. Plugin Request - Email reading application
    By ankur in forum CF Plugins
    Last Post: 01-25-2007, 01:06 PM
  3. Receiving email (Pop3) what am I doing wrong
    By pshadwick in forum Wireless Communications
    Last Post: 06-02-2006, 11:37 AM
  4. Outlook XP Problem
    By ODYSSEY in forum Off Topic
    Last Post: 12-22-2002, 02:52 AM
  5. Resumer Winamp plugin..works with MPC, too
    By Tony S in forum Software & Software Development
    Last Post: 03-30-2002, 06:10 PM
