Page 17 of 42 FirstFirst ... 789101112131415161718192021222324252627 ... LastLast
Results 161 to 170 of 420
Thread: RRFusion- My Fusion Brain plugin for RR
  1. #161
    Mar 2006
    Colorado, but Canadian!
    I meant backwards compatible as in the hardware doesnt care and the byte stream doesnt change. The programming does. Sonic uses WinUSB. We use LibUSB.
    So you will need to use the older drivers and use Sonic's RR work, or use the libusb drivers and use MDX's COM object for RoadRunner.
    Cant do both at the same time because they require different device drivers.
    1.9in x 2.9in -- 47mm x 73mm
  2. #162
    FLAC Dougw133's Avatar
    Nov 2007
    PA
    Same here...I cannot get it to do anything it all using the plugin....
    EDIT...toaster we posted at the same time but I imagine that's why the plugin won't work for me!
  3. #163
    Mar 2006
    Quote Originally Posted by Dougw133 View Post
    MDX's COM plugin, or Sonics?
  4. #164
    Nov 2007
    PA
    Sonics, however I don't understand the com plugin nor even know what it is
  5. #165
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Don't you people EVER sleep!!! (hehe look who's calling the kettle black )
    Can you elaborate more on the "MDX's COM object for RoadRunner".
    Also, where are the older versions of the plugin? The software link in http://www.fusioncontrolcentre.com/ only goes to the new MDX Installer package.
    My Fiero Build Thread
  6. #166
    Nov 2007
    PA
    I sleep, I'm a west coaster at the moment( until 2 weeks) so I am 2 hours behind you any how!
  7. #167
    Newbie hugenius79's Avatar
    May 2006
    New York
    Quote Originally Posted by JohnWPB View Post
    Ok, Finally got the FB hooked up and testing I have 2 temp sensors, and a pot hooked to it. I can see these in the MDX software, and can control the outputs (See the LED's lED's light up), and read the temperature correctly. Thus, the drivers are installed and working.
    I can not however get the RR plugin to work no matter what I do.
    By the way, I have just read every single post in this thread before posting here
    Sonic, you mentioned in a previous post:
    I have no WINUSB folder or key listed. (See attached screen cap) This is a full WinXP Pro install BTW.
    I also noticed that when I issue the "RRFUSION" command with the skin tool, the rrfusion.skin does not load, which seems to tell me the DLL is not "running". I have added it to the plugins.txt, and even disabled all other plugins for testing... nothing.
    You also mentioned in a previous post to look in device manager for "Da Fusion Brain" My entry is "The Fusion Brain V3". Not sure if this makes a difference 2k1Toaster said that drivers are backwards compatible.
    When the new Fusion MDX installed yesterday, it updated my .net so I now have 1,1.1, 2, 2.1, 3, and 3.5 installed.
    There are no references or anything pertaining to the FB in the RR.ini or in the Skin.ini as you stated, just in the:
    \Road Runner\Plugins\RRFusion\rrfusion.ini
    I ran the RunMeFirst to register the .net dll, and even unregistered and re-registered a couple times during trouble shooting.
    Any clues on where to go from this point?
    This issue was addressed by another user :
    http://www.mp3car.com/vbulletin/1260414-post24.html
    John Just place the contents of the RRfusion plugin in your RR folder it will work..
    That's the way i have RRfusion plugin working IN DFX 4
  8. #168
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    As mentioned above, and in the FB thread there is a problem loading the plugin from a RR subfolder for some reason.
    Quote Originally Posted by Sonicxtacy02 View Post
    -Plug your FB to your computer.. give it power, install the drivers
    -Place your RRFUSION folder where u want it (the preferred RR location is inside the "PLUGINS" folder in your rr folder)
    -Run the "RunMe1st.cmd" in the RRFusion folder
    Sonic, I can confirm, that the plugin will not load from my Road Runner/Plugins/RRFusion folder.
    I moved all files to the Root RR folder, restarted RR, and then issuing the RRFUSION command does now in fact load the rrfusion.skin.
    So the skin loads, but I am unable to use the FB with it, as I have the new software, and it will not work with the FB plugin. I am gonna have to skin the FB software and embed it I guess
  9. #169
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    I'll take a look today but i thought i already converted it for use in the plugins subfolder. Maybe i'm confusing fusion with another one of my plugins. The problem you're having with the actual operation not working is tied to the newer drivers. I'll see if i can coordinate with nick.. he did mention to me a few ago about the driver change i just havent followed up because i wasnt sure anyone but me was using this plugin. If i can get RRFusion working using both older or newer drivers I will re-do the plugin adding the additional outputs and inputs for the newer version. I'll need someone with the newer fusion brain to test however because i dont have one and dont have the cash to purchase one now.
    Live mp3Car Facebook Chat
  10. #170
    Mar 2006
    MDX can communicate with RR directly.
    http://www.mp3car.com/vbulletin/fb-s...ig-update.html
    The plugin was created with help from sonic, but they are for different purposes. If you dont need fancy custom formula or event triggered events, and you just want display and easy control then Sonics seems to fit the bill.
    The MDX COM object is everything in MDX exposed to RoadRunner including all I/O and all Variables. Also accepting commands from RR to do any "vote" from sending an email to playing a sound, triggering an output, changing a variable, anything that is available in MDX.
  1. *NEW* USB Input/Output Board -- Fusion Brain
    By 2k1Toaster in forum Fusion Brain
    Last Post: 02-22-2010, 03:33 AM
  2. Replies: 15
    Last Post: 09-22-2008, 09:02 AM
  3. Noob has some biginner questions about the Fusion Brain
    By phreaknes in forum Fusion Brain
    Last Post: 04-29-2008, 03:57 AM
  4. pc reboot on sd startup
    By duanes7 in forum StreetDeck
    Last Post: 12-14-2007, 09:55 AM
  5. Replies: 5
    Last Post: 10-22-2007, 09:40 PM
