Page 18 of 42 FirstFirst ... 8910111213141516171819202122232425262728 ... LastLast
Results 171 to 180 of 420
Thread: RRFusion- My Fusion Brain plugin for RR
  1. #171
    Newbie hugenius79's Avatar
    May 2006
    New York
    John i can confirm that the new driver (8/28/2008)version 3 is not working with the fusion brain in RR.
    I tried them and just as you stated it opens the RRfusion.skin but no activity.
    Old version of driver is (08/29/2007) version 1 is working
    If you want i can send you the drivers that were released before they will change "THe fusion Brain V3" you have to "Da fusion brain"
    Let me know..
    Sonicxtacy02 can you look into this :why is the new driver not working with
    the RRFUSIOn plugin and location can the location of the fusion brain be altered.
  2. #172
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    I'm going to look at it today.. i hope.. i came into work and my programming pc smelled like burnt rubber.. power supply failed. So i'll have to replace that. Then i'll take a look at mdx's source to see how the new driver version reads the PID of the fusion brain. HOPEFULLY after than RRFusion will work with both versions.
    Live mp3Car Facebook Chat
  3. #173
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Sounds good!
    Hey at least you weren't sitting next to it and the cap blew in the power supply! Happened to me once and I came about 2 feet out of my computer chair! Sounded like a gun shot! (A very large gun!)
    My Fiero Build Thread
  4. #174
    Woodbridge, VA
    Blog Entries
    32
    Ok i've found the fix for having RRFusion in plugins path. That was easy enough. Next i'll be checking MDX for the pid info. Stay tuned.
  5. #175
    Woodbridge, VA
    Blog Entries
    32
    Well thanks HUGELY in part to Toasters guidance i've now got the new drivers working in rrfusion. I've also taken a look at MDX and how it manages multiple brain instances. The implementation looks doable.. but to say this will require a MAJOR rewrite of RRFusion is an understatement. Its doable.. but will require each command and label to be renamed to make use of multiple FBs. Instead of DIGOUT0TOGGLE you would see DIGITALOUT0TOGGLE;1... 1 being the FB instance. At first i'd like to support up to 4 FB instances.. does that sound like enough? It will take me awhile to get this release out.. so should i just release a newer single instance version that is compatible with all FB versions first? Choice is up to you guys.
  6. #176
    Nov 2004
    St Louis
    Quote Originally Posted by Sonicxtacy02 View Post
    ... so should i just release a newer single instance version that is compatible with all FB versions first? Choice is up to you guys.
    If it supports the new drivers and commands I say yes! I have the older sets in one of my cars up and running RRFusion, but when I get my V4 in Jan I'll need a new RRFusion to support both.
  7. #177
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    so should i just release a newer single instance version that is compatible with all FB versions first?.
    Yes! Please do I would love to get the FB working with your plugin. It would be so much easier to skin, than trying to skin the MDX and then have to embed it as an external app.
  8. #178
    Woodbridge, VA
    Blog Entries
    32
    ok... i'll do my best to crunch thru this when i'm back to work monday.
  9. #179
    Fusion Brain Creator
    Mar 2005
    Quote Originally Posted by JohnWPB View Post
    you dont have to skin mdx - you can use it to feed data to/from roadrunner through COM
  10. #180
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    Any luck yet?
  1. *NEW* USB Input/Output Board -- Fusion Brain
    By 2k1Toaster in forum Fusion Brain
    Last Post: 02-22-2010, 03:33 AM
  2. Replies: 15
    Last Post: 09-22-2008, 09:02 AM
  3. Noob has some biginner questions about the Fusion Brain
    By phreaknes in forum Fusion Brain
    Last Post: 04-29-2008, 03:57 AM
  4. pc reboot on sd startup
    By duanes7 in forum StreetDeck
    Last Post: 12-14-2007, 09:55 AM
  5. Replies: 5
    Last Post: 10-22-2007, 09:40 PM
