Page 20 of 42 FirstFirst ... 101112131415161718192021222324252627282930 ... LastLast
Results 191 to 200 of 420
Thread: RRFusion- My Fusion Brain plugin for RR
  1. #191
    Low Bitrate docbreezy's Avatar
    Feb 2008
    Maryland
    Nice little piece of hardware. I just got the Version 3 a week before the version 4 came out. It will do though, i don't need that much automation. Anyway, im not too savi with it and i'm trying to get this working right for me. I'm trying to add this "ONSKINSTART","DIGITALOUT8SWITCH;2" to my Exctbl for a 2 second power on to turn my monitor on. It turns the port on when i start RR but before then stays on and the following error appears.
    "Unhandeld Exception has occured in a component in your application."Index was outside the bounds of array""
    ************** Exception Text **************
    System.IndexOutOfRangeException: Index was outside the bounds of the array.
    at RRFusion.Form1.Timer2_Tick(Object sender, EventArgs e)
    at System.Windows.Forms.Timer.OnTick(EventArgs e)
    at System.Windows.Forms.Timer.TimerNativeWindow.WndProc(Message& m)
    at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
    How do i rectify this???? Thanks in advance.
    506 Skin
    506 Flash!
    NEVER BLEND IN!!!
  2. #192
    Low Bitrate Laminar's Avatar
    Oct 2008
    What's the current status of this? Sonic's site appears to be down.
    1999 SVT Contour
    3.0
  3. #193
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    sorry guys my sites down for good and i've been goin thru some CRAZY stuff with my move.. but RRFusion is still active and there is a new version very much ready for action. Bare with me a few more days and i'll release the V4 compliant version.
    Live mp3Car Facebook Chat
  4. #194
    Oct 2008
    Thanks for the update.
    Forgive me for asking, but at this point in RRFusion's development, can buttons to control the FB be placed in RR skins alongside normal RR buttons? After reading the whole thread and doing some searching, the answers I found for this question all seemed to be a couple years old.
    1999 SVT Contour
    3.0
  5. #195
    Woodbridge, VA
    Blog Entries
    32
    yes the buttons for RRFusion can be skinned and placed anywhere on a skin as long as the plugin is enabled. They work just like standard RR commands.
  6. #196
    Oct 2008
    Fantastic. I got my relays and GM vacuum solenoid manifold last week, my FB should come this week. Needless to say, I'm excited.
    1999 SVT Contour
    3.0
  7. #197
    Oct 2008
    Any updates on when the update will be posted. Thanks
  8. #198
    Woodbridge, VA
    Blog Entries
    32
    Quote Originally Posted by wrxyboy View Post
    Nope.. oh wait.. check post 1
    NEW VERSION RELEASED!
    I know its taken awhile but i'm all moved in and internet connected. The moving nightmare is OVER. So now i present RRFusion 3.0. Anyone thats used RRFusion prior til now will notices some changes that may affect .skin files. The primary changes from old versions is the change of the DIGITALOUT#TOGGLE command. This command is no more! Instead change your skin file to incorporate DIGITALOUT#;TOGGLE. Change was done to incorporate new control options. More on this later.
    The other change from previous versions is the removal of FBAUTOCONNECT. The plugin no longer looks for this variable upon start. My suggestion for those who want the FB to connect when RR starts is to place FBCONNECT into the ONSKINSTART event in exectbl.ini. If you have a bunch of commands in that EVENT i suggest you place FBCONNECT on the end of the command chain.
    Now for the additions/improvements. First and foremost the plugin is now V3 and V4 FB compatible. All thats required is using the fusionbrain_winusb.dll drivers. If you dont have these read up in the FB forum about them. I've also added the analog INS and digital OUTS for V4. Using these with a V3 FB will do nothing. No harm no foul. I've also added 2 NEW control options in addition to DIGITALOUT#;TOGGLE. First there's DIGITALOUT#SWITCH;<SECONDS>. This turns on the digital output for a user-specified amount of time then turns it off automatically. Then there's DIGITALOUT#;HOLD. This command controls digital outputs like momentary buttons. It requires the command DIGITALOUT#;RELEASE to turn the output off. So in your skin an example button would read:
    Code:
    B,X,X,X,X,"DIGITALOUT0;RELEASE",&DIGITALOUT0;HOLD&
    See skin commands for more info on the new buttons. Also see the new .skin files which show each of these options at work. Thats all for now i believe! Hopefully this will be the last SINGLE INSTANCE version released.
  9. #199
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Fantastic sonic! Been waiting for this! I will give it a try in the next day or so and let ya know how it went.
    My Fiero Build Thread
  10. #200
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    Getting an error with the "Press and hold" buttons.
    Well that was fast huh? What can I say, have been waiting for this plugin for some time heheh
    It's a strange coincedence, as I just installed the FB yesterday, and started tinkering with it again. Its a fresh OS install, with the latest FB software as of yesterday, so the drivers and such are all up to date, and no old drivers were on the system to interfere.
    Loading the fb.skin, I am getting a connected indicator now, and can see the values of the inputs, as well as control the 2 relays I have hooked to it.
    The problem comes in when trying to use the momentry buttons that you just added. When I try to press and hold one of the momentary buttons, the relay clicks, and then I get a .net error. I have to ctrl-alt-del RR to be able to use the computer again.
    Here is the error log that the error reports:
    (I bolded what appears to be the problem in the code)
    Code:
    See the end of this message for details on invoking
    just-in-time (JIT) debugging instead of this dialog box.
    System.InvalidCastException: Conversion from string "release" to type 'Double' is not valid. ---> System.FormatException: Input string was not in a correct format.
       at Microsoft.VisualBasic.CompilerServices.Conversions.ParseDouble(String Value, NumberFormatInfo NumberFormat)
       at Microsoft.VisualBasic.CompilerServices.Conversions.ToDouble(String Value, NumberFormatInfo NumberFormat)
       --- End of inner exception stack trace ---
       at Microsoft.VisualBasic.CompilerServices.Conversions.ToDouble(String Value)
    ************** Loaded Assemblies **************
    mscorlib
        Assembly Version: 2.0.0.0
        Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400)
        CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
    RRFusion
        Assembly Version: 1.0.0.0
        Win32 Version: 1.0.0.0
        CodeBase: file:///C:/Program%20Files/Road%20Runner/Plugins/RRFusion/RRFusion.DLL
        Assembly Version: 8.0.0.0
        Win32 Version: 8.0.50727.1433 (REDBITS.050727-1400)
        CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
    FusionBrain_WinUSB
        CodeBase: file:///C:/Program%20Files/Road%20Runner/Plugins/RRFusion/FusionBrain_WinUSB.DLL
        CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
    System
        CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
    System.Drawing
        CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
    Accessibility
        CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
    System.Web
        CodeBase: file:///C:/WINDOWS/assembly/GAC_32/System.Web/2.0.0.0__b03f5f7f11d50a3a/System.Web.dll
    System.Xml
        CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
    ************** JIT Debugging **************
    To enable just-in-time (JIT) debugging, the .config file for this
    application or computer (machine.config) must have the
    jitDebugging value set in the system.windows.forms section.
    The application must also be compiled with debugging
    enabled.
    For example:
    <configuration>
        <system.windows.forms jitDebugging="true" />
    </configuration>
    When JIT debugging is enabled, any unhandled exception
    will be sent to the JIT debugger registered on the computer
    rather than be handled by this dialog box.
  1. *NEW* USB Input/Output Board -- Fusion Brain
    By 2k1Toaster in forum Fusion Brain
    Last Post: 02-22-2010, 03:33 AM
  2. Replies: 15
    Last Post: 09-22-2008, 09:02 AM
  3. Noob has some biginner questions about the Fusion Brain
    By phreaknes in forum Fusion Brain
    Last Post: 04-29-2008, 03:57 AM
  4. pc reboot on sd startup
    By duanes7 in forum StreetDeck
    Last Post: 12-14-2007, 09:55 AM
  5. Replies: 5
    Last Post: 10-22-2007, 09:40 PM
