Page 21 of 48 FirstFirst ... 111213141516171819202122232425262728293031 ... LastLast
Results 201 to 210 of 471
Thread: RRFusion- My Fusion Brain plugin for RR
  1. #201
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    41
    hmmm i'm not converting that string. Lemme see what i can pull up.
    EDIT-
    Whats the exact command u were performing when you got the error. Show me it from the .skin file. The only time in the whole plugin a double is used is when using the DIGITALOUT#SWITCH;NUMBER command. It takes whatever NUMBER is and weighs it against the timer. In looking at that debug it appears that DIGITALOUT#;HOLD/RELEASE enabled the DIGITALOUT#SWITCH's timer. Anyone else with a V4 brain tested the new version? Remember i only have a v3.
    Live mp3Car Facebook Chat
  2. #202
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    A rabbit out of a hat, perhaps....
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  3. #203
    Jul 2008
    Lee's Summit
    I will take a brew if your getting up...
    Batmaninls
    www.evorbust.com
  4. #204
    Jan 2005
    quick question what is required to use the rrfusion plugin to control a Resistance ladder series of buttons?
  5. #205
    Woodbridge, VA
    Blog Entries
    41
    Quote Originally Posted by yonu View Post
    Define "Resistance ladder"
  6. #206
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    He's taking about a multi voltage divider, that each button would end up sending a different voltage to the analog inputs so that several buttons could be placed on one single analog input.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  7. #207
    Low Bitrate Laminar's Avatar
    Oct 2008
    I installed the latest version of MDX then plugged in the FB and installed the drivers. Per the instructions, I dragged the contents of the RRFusion Skin to my Skins folder. RRConfig complained that I needed general.ini and menu.skin files. I found and renamed the menu.skin file and copied the general.ini file from another skin - now when I open up RR, nothing shows up, but my mouse and taskbar disappear. What am I missing? What am I doing wrong?
    1999 SVT Contour
    3.0
  8. #208
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Those are extra screen that you would place into an existing skin, not to be used as a skin it self and is why the config yelled.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  9. #209
    Oct 2008
    Gotcha. I can't quite figure out how to test outputs. I'll open up Fusion Control Centre and see the buttons but nothing changes when I click any of them. Do I have to have something connected a digital output for it to register any change?
    1999 SVT Contour
    3.0
  10. #210
    Woodbridge, VA
    Blog Entries
    41
    Ah ok... yea way over my head .
    Quote Originally Posted by Laminar View Post
    Installing the latest version of MDX doesnt guarantee you have the latest drivers. Make sure that you're using the fusionBrain_winusb.dll driver. You no longer need to have MDX or FCC installed to use RRFusion. A copy of FusionBrain_winusb.dll should be in your RRFusion folder if you need it.
  1. *NEW* USB Input/Output Board -- Fusion Brain
    By 2k1Toaster in forum Fusion Brain
    Last Post: 02-22-2010, 02:33 AM
  2. Replies: 15
    Last Post: 09-22-2008, 08:02 AM
  3. Noob has some biginner questions about the Fusion Brain
    By phreaknes in forum Fusion Brain
    Last Post: 04-29-2008, 02:57 AM
  4. pc reboot on sd startup
    By duanes7 in forum StreetDeck
    Last Post: 12-14-2007, 08:55 AM
  5. Replies: 5
    Last Post: 10-22-2007, 08:40 PM
