Page 23 of 51 FirstFirst ... 131415161718192021222324252627282930313233 ... LastLast
Results 221 to 230 of 502
Like Tree1Likes
Thread: RRFusion- My Fusion Brain plugin for RR
  1. #221
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    Quote Originally Posted by sxtnitehawk View Post
    im just waiting to be able to download it so i can start learning how to use it!
    Its coming soon dont you worry. And my testers are making sure its worth the wait
    Live mp3Car Facebook Chat
  2. #222
    Sep 2007
    Export, PA
    i need multibrain support, lol....i'm already out of outputs on the first brain, lol
    Planning: [|||||||||-] 90%
    Purchased: [|||||||||/] 99%
    Installation: [|||||||||-] 90% (when is anyone's project ever REALLY done...)
  3. #223
    Woodbridge, VA
    Blog Entries
    55
    i'm looking at it as i type this. However, like v4 support, i have NO means of testing the results. If you or anyone else is SERIOUSLY looking for multibrain support then speak now because you WILL become a tester lol. The input side of things i get. Whats yet to be determined is the RR command/label side. Commands, Indicators, and Labels will be hella confusing if each FB connected has X number of ports and X number of commands/labels/inds per port. If anyone's interested and have msn pm me at sonicxtacy02 at hotmail.com
  4. #224
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Might have to rethink your cmds/labels/inds/ect... to be able to incorp the multi FB support.
    like change everything to a DOut107, which would be the digital output port #7 on brain #1... IDK
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  5. #225
    Mar 2006
    Colorado, but Canadian!
    That's what is done in MDX. You have to specify the command, the brain instance, and the port instance for each one. I dont see any other way really.
    1.9in x 2.9in -- 47mm x 73mm
  6. #226
    Sep 2007
    Export, PA
    i'll definitely test for ya...
    i have both a v3 and v4 brain...though i'll be buying another v4 to replace my v3(the v3 has a few dead ports)
  7. #227
    Woodbridge, VA
    Blog Entries
    55
    i was thinking something along the lines of using the ; separator in a different manner but your suggestion would actually be easier and more simple in the long run i think. I'll run with that and see how it goes. I should probably know this but if a user wanted to run "DOut$Var$07" would that work assuming $Var$ is a FB instance?
    Quote Originally Posted by 2k1Toaster View Post
    Would you suggest i slow down the send/receive timer based on the number of instances? right now my timer interval is 100 based on a single instance.
    I really need to take a look at the MDX source as i havent in awhile.
    I'm gonna put together a basic version without all the new stuff blues been working on as a test that RRFusion can read/write to different FBs
  8. #228
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Ya, that would work, as RR replaces any vars before the PI even see the cmds.
    And I, for one, think that the shorter names are nice too instead of the long "DIGITALOUTPUT#1", yada yada...
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  9. #229
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    <takes the risk of looking silly>
    Would it not be simpler to have the badger badger badger and sonic work together to create a RRplugin that bypasses the MDX?
    Or in other words an MDX version that is an RRPlugin.
    <goes and hides in a corner>
  10. #230
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    And hopefully stays in said corner...
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  1. *NEW* USB Input/Output Board -- Fusion Brain
    By 2k1Toaster in forum Fusion Brain
    Last Post: 02-22-2010, 03:33 AM
  2. Replies: 15
    Last Post: 09-22-2008, 09:02 AM
  3. Noob has some biginner questions about the Fusion Brain
    By phreaknes in forum Fusion Brain
    Last Post: 04-29-2008, 03:57 AM
  4. pc reboot on sd startup
    By duanes7 in forum StreetDeck
    Last Post: 12-14-2007, 09:55 AM
  5. Replies: 5
    Last Post: 10-22-2007, 09:40 PM
