Page 24 of 51 FirstFirst ... 141516171819202122232425262728293031323334 ... LastLast
Results 231 to 240 of 502
Like Tree1Likes
Thread: RRFusion- My Fusion Brain plugin for RR
  1. #231
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    Quote Originally Posted by Enforcer View Post
    <takes the risk of looking silly>
    Would it not be simpler to have the badger badger badger and sonic work together to create a RRplugin that bypasses the MDX?
    Or in other words an MDX version that is an RRPlugin.
    <goes and hides in a corner>
    i would have absolutely no problem with that... with the exception of the fact that he's so knowledgeable about programming it'd be like a full blown language barrier. I mean what i have so far is working with my single instance and there's no real reason it shouldnt work with up to 6 FBs... its just requiring me to do massive amounts of copying/pasting of timers and commands basically. I've been doing this all day and i havent even THOUGHT about the analog and digital ins yet. I mean each port has 3 command options (toggle, hold, switch). So adding support for up to 6 brains and having them all sending/receiving is easy when compared to the number of commands needed in RR. 16 ports x 3 commands per port x 6 fb instances means 288 different ways to control ports in RRFusion now. Sounds nice and flexible... just requires ALOT of backend RR compatibility work. On a side note i'm impressed with the file size of the .dll staying relatively the same. I'm still pushing to get a basic output test to SXNighthawk today. Movietimes release will definitely have to wait
    Live mp3Car Facebook Chat
  2. #232
    Woodbridge, VA
    Blog Entries
    55
    Boy are you guys gonna have fun skinning this!
    just think.. thats only 2 outta 6 instances! lol
  3. #233
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    You could do it like I did the trafficams or the way Centrafuse does the main menu.
    ie have it so that pressing next or prev moves you between instances.
  4. #234
    Woodbridge, VA
    Blog Entries
    55
    sounds like a good plan to me
  5. #235
    FLAC Dougw133's Avatar
    Nov 2007
    PA
    Ive been using mdx embedded in rr/dfx 4 for awhile..i have several instances. Inside/outside temps, heated seat controll and my garage door opener. I am admitedly intimidated by rrfusion because i dont kno where to start..I have played with it and gotten it to open up in rr etc..I have little know knowledge of skinnging however want to have temps values displayed on my main menu.skin files for dfx4. where do i start to make this happen?
  6. #236
    Sep 2007
    Export, PA
    I'm gonna have to do some testing to see how well i can make steering wheel controls work... I'm more than likely buying a used 300C or Magnum soon, and my carpc will go in there instead, either will have steering wheel controls, which i plan on making a somewhat intricate setup with those where i can navigate through menus and settings without needing to take my hands off the wheels, etc...
    it'll be interesting to say the least...interesting to code and interesting to impliment....
    Planning: [|||||||||-] 90%
    Purchased: [|||||||||/] 99%
    Installation: [|||||||||-] 90% (when is anyone's project ever REALLY done...)
  7. #237
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by Dougw133 View Post
    If you already have MDX setup and working embedded, then it is a couple line addition to the config file to get the internal MDX COM object working.
    1.9in x 2.9in -- 47mm x 73mm
  8. #238
    Woodbridge, VA
    Blog Entries
    55
    Welp i still have zero testing going on with multibrain support so that project is on an indefinite hold. I do have another single instance version ready today with the warning label support. Looking to release tonight!
  9. #239
    Woodbridge, VA
    Blog Entries
    55
    Quote Originally Posted by Sonicxtacy02 View Post
    -EDIT-
    Available now. Check post 1
  10. #240
    Nov 2007
    PA
    Quote Originally Posted by 2k1Toaster View Post
    Heh...Com object? Ha...Lines to where...I suck at this man! It takes me forever to leanr this stuff and a day to forget.
  1. *NEW* USB Input/Output Board -- Fusion Brain
    By 2k1Toaster in forum Fusion Brain
    Last Post: 02-22-2010, 03:33 AM
  2. Replies: 15
    Last Post: 09-22-2008, 09:02 AM
  3. Noob has some biginner questions about the Fusion Brain
    By phreaknes in forum Fusion Brain
    Last Post: 04-29-2008, 03:57 AM
  4. pc reboot on sd startup
    By duanes7 in forum StreetDeck
    Last Post: 12-14-2007, 09:55 AM
  5. Replies: 5
    Last Post: 10-22-2007, 09:40 PM
