Page 26 of 48 FirstFirst ... 161718192021222324252627282930313233343536 ... LastLast
Results 251 to 260 of 471
Thread: RRFusion- My Fusion Brain plugin for RR
  1. #251
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by JohnWPB View Post
    Ok, what is the -.04 that you are referring to? Is there a way with RRFB to "tune" the readings?
    Yeah, get some silvery metallic liquid, some sand and some squid juice.
    Heat sand to a liquid, blow into a thin tubular shape. Wait to cool then pour in the metallic liquid, leaving some space at the top and then seal.
    Dip a stick in the squid juice and make some horizontal marks going up the thin tubular shape.
    get some 5th graders to write some numbers next to the horizontal marks in the same squid juice.
  2. #252
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Dude... you really, I mean REALLY need to stop smoking that S#IT!!!!!
    My Fiero Build Thread
  3. #253
    Nov 2004
    St Louis
  4. #254
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    41
    Yea, that is in Sonic's source code, which I do not have. I see there is a way to alter analog correction values, but that's for something I have no idea what it is
    From the RRFB.ini
    "Analog correction values pertain to the static voltage divder types only"
    i can add correction values for temp sensors too. Thats no problem.
    Live mp3Car Facebook Chat
  5. #255
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    That would be fantastic! It would give a quick fix to tweak the temp values a bit. With it matched up to another digital thermometer, And "tuned" for each individual sensor, I bet one could get better than the +/- 1.5 degrees. Heck, I would be happy to be within just a couple degrees actually, 15 degrees of makes it almost pointless to use.
    BTW, if ya wanna check out the plugin I wrote for the FB you are welcome to, just drop me a PM. Still needs a little polishing up, but it is working well. I used the labels you made available with your RRFusion Plugin
  6. #256
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    One other nice feature would be to be able to have event driven fired events for the analog ports. This would only require minimal code additions
    /,Analog# = <TYPE(RAW or OPT)>;<LIMIT>;<OPERATOR(< or > or <>)>;<ALERT>
    Add a "<>" to the operator options, which would then fire the <ALERT> as the event if that ports value changes by more than the +/-<LIMIT>.
    Make sense, I hope? This would be nice in the instance of say Johns Plugin where it wouldn't have to constantly check if the value changed, becuse it would fire off an even saying it did, which then another PI/app could act upon it, saving wasted resources for something that might have not changed or changed by a little bit 2-3 values...
    The more flexible this is the more one can use it for with minimal extra coding and resources.
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  7. #257
    Mar 2006
    Colorado, but Canadian!
    I just wanted to say I think it is funny how the development of this plugin pretty much mirrors that of MDX.
    Every feature on here was requested before and I implemented it almost in the same order. I wouldnt be surprised if you made a function parser soon so that instead of static offsets, the entire equation could be customized. And if you do I already have the code for that, so I can give it to you!
    Keep up the good work, it just makes me giggle a bit that is so closely related!
    1.9in x 2.9in -- 47mm x 73mm
  8. #258
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    Well 2k, we DID try to get you to make or spear-head a RR plugin in the first place I have to say, that the integrated plugin is a much better option.
    I know you spend countless hours on MDX, and it is a fantastic piece of software! But, just having all the commands native to RR, with no need for another program to be running, and have all of the commands native to RR is just the better option. Plus not having to skin to seperate programs, and being able to use RR"s native skins with transparencies, intermixed labels ect. I can put a temp label in the main menu, lighting control switch on the audio screen, RR indicators mixed with the FB indicators on a control screen ect ect.
    Using the labels and var's that sonic exposed, I wrote that lil plugin mentioned above for automatic dimming, or manual overide by using the Potentiometer. I am sure there will be many more cool plugins to come now that all the readings have been exposed to RR natively.
  9. #259
    Woodbridge, VA
    Blog Entries
    41
    Could be the loratab i'm on... could be because i havent looked at the stuff you just helped me add.. but isnt that what you helped me with? lol Explain the difference.
    Quote Originally Posted by 2k1Toaster View Post
    Thats already been requested and considered.. i just had the slightest idea how to implement it. I will certainly look at your code once i get back into RRFusion development. For now i'm trying to get movietimes back up and running.
  10. #260
    Mar 2006
    There is a RR plugin already available as well just FYI.
  1. *NEW* USB Input/Output Board -- Fusion Brain
    By 2k1Toaster in forum Fusion Brain
    Last Post: 02-22-2010, 02:33 AM
  2. Replies: 15
    Last Post: 09-22-2008, 08:02 AM
  3. Noob has some biginner questions about the Fusion Brain
    By phreaknes in forum Fusion Brain
    Last Post: 04-29-2008, 02:57 AM
  4. pc reboot on sd startup
    By duanes7 in forum StreetDeck
    Last Post: 12-14-2007, 08:55 AM
  5. Replies: 5
    Last Post: 10-22-2007, 08:40 PM
