Page 27 of 51 FirstFirst ... 171819202122232425262728293031323334353637 ... LastLast
Results 261 to 270 of 502
Like Tree1Likes
Thread: RRFusion- My Fusion Brain plugin for RR
  1. #261
    Jan 2007
    woot got my fusion brain today! implementing this week. working on a remote starter....kinda hard in high security vehicles...but we shall see.
    ultimate goal is to "remote control" the car over VNC with the Iphone....so far it looks very promising.
    currently im facing the issue where to put the FB since it can get rather hot in the "EBOX" of the car... it would be the most convenient spot tough.... any idea how hot the board can run before i seriously lower the MTBF...?
  2. #262
    Jan 2006
    How can I go about troubleshooting why the RRfusion plugin is not working? I seem to always have a problem when I install on a new computer...
    This time I copied everything over exactly how I had it set up on my laptop and it does not seem to be working on my carpc...
    How can I start trouble shooting to find out whats wrong??
    Thanks!
  3. #263
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    does the latest MDX work.. that would indicate you've got the correct driver installed. Have you checked your debug.txt to see if RR is loading the rrfusion.dll?
    Live mp3Car Facebook Chat
  4. #264
    Jan 2006
    Quote Originally Posted by Sonicxtacy02 View Post
    Yes it works with the MDX... How do I get the debug.txt? I did it a long time ago and was trying to do it last night and couldnt remember how
  5. #265
    Woodbridge, VA
    Blog Entries
    55
    Quote Originally Posted by djurchicprelude View Post
    open up RRConfig, and in one 4 general tabs you will see debug enabled?. Make sure that setting is checked then run RR and open RR's root folder to find debug.txt.
    If MDX works, you have .net 2.0 (which i believe MDX requires), and you have RRFusion.dll registered it should be able to run the command FBCONNECT in RR and be able to read analog raw inputs without any setting adjustments. converted inputs will need to be setup via the instructions in the readme
  6. #266
    Jan 2006
    Ok I ran the debug and the only two line refering to the rrfusion i found were:
    Plugin manger: warning plugin rrfusion does not support initialize method
    Plugin manager: plugin loaded (menu.skin): rrfusion
    what do I do next?
  7. #267
    Woodbridge, VA
    Blog Entries
    55
    what do I do next?
    that means the plugins loaded.. which means it should be working. What exactly are you trying to do that makes you think its not working? run the command LOAD;rrfusion.skin... run the command FBCONNECT... and use your fb
  8. #268
    Jan 2006
    Im trying to get the outputs and inputs working... I made a skin to make my heat work in my car, so when i press the button the low speed next button med speed....ect ect.. and to show temperature...
    when I plug the FB into my laptop it works and shows everything just fine... when i open the skin on my car pc.. its like a dead image, It does not show any values and the buttons dont work??
    where should I run the command LOAD;rrfusion.skin?
  9. #269
    Jan 2006
  10. #270
    Jan 2007
    ok i successfully connected the fusion brain WOHO!
    now can someone point me into the right direction of where i would start to program in some logic... for example i would like to turn on a Digital out when im going faster than 75mph (which is a RR variable...) how would i go about doing that????
    also is there a way i can make a certain skin show for a couple of seconds whenever a analogue in goes over a certain value?
    thx for any help!
  1. *NEW* USB Input/Output Board -- Fusion Brain
    By 2k1Toaster in forum Fusion Brain
    Last Post: 02-22-2010, 03:33 AM
  2. Replies: 15
    Last Post: 09-22-2008, 09:02 AM
  3. Noob has some biginner questions about the Fusion Brain
    By phreaknes in forum Fusion Brain
    Last Post: 04-29-2008, 03:57 AM
  4. pc reboot on sd startup
    By duanes7 in forum StreetDeck
    Last Post: 12-14-2007, 09:55 AM
  5. Replies: 5
    Last Post: 10-22-2007, 09:40 PM
