Sorry chap, i'm a bit confused when you say they should be in there.
I've looked through all f the txt and ini files in the RR Fusion directory and i cant see anywhere to actually put formulas or anything.
In MDX i assign an analogue port to a variable and then run the variable through the function that converts the input voltage to PSI and then i put that to a label.
How would i do the same in your plugin? By looking at your sample skin i assume the actual values will automatically appear in the raw data next to each port. How can i put that number through the voltage to PSI calculator thats in MDX?
Thanks and sorry if i have missed something obvious. I am also assuming that when i press connect it searches for a brain every time as i couldnt see anywhere to define my Brain ID in any of the files. I havent got my FB with me today so just wanted to make sure i knew how this connects.
Ken
LinkBack URL
About LinkBacks
