Page 32 of 51 FirstFirst ... 222324252627282930313233343536373839404142 ... LastLast
Results 311 to 320 of 502
Like Tree1Likes
Thread: RRFusion- My Fusion Brain plugin for RR
  1. #311
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    i will double check see what the problem is. Perhaps i have a parenthesis in the wrong place or something.
    Live mp3Car Facebook Chat
  2. #312
    Constant Bitrate KennyKen's Avatar
    England
    Quote Originally Posted by Sonicxtacy02 View Post
    My mistake.. they arent in the code currently. If i can find the functions he provided i will add it this week
    Thanks Sonic, if its of any help i got the information for the FB from this post in the FB section: http://www.mp3car.com/vbulletin/fb-d...ml#post1187598
    Hope that helps
    Ken
  3. #313
    Woodbridge, VA
    Blog Entries
    55
    LASAL- I've looked at this for an hour and there's no difference in the code between ports. I thought this was the case because i remember literally copying/pasting it and only changing variable and array indexes. My code for calculating converted values is very simple there's practically no room for error. AnalogIn() is an integer, Analog#Opt is an integer, and AnalogDecimalPlaces() is an integer. Here are is the code for the first 4 ports for the voltage option (6)
    Code:
    <ANALOG 0 CODE>
    ElseIf Analog0Opt = 6 Then
                            ReturnLabel = ((AnalogIn(0) * (5 / 1023) / analogCorrection(0)))
                            ReturnLabel = Math.Round(CDec(ReturnLabel), CInt(analogDecimalPlaces(0)))
                            ReturnLabel = ReturnLabel + "V"
                        End If
    <ANALOG 1 CODE>
    ElseIf Analog1Opt = 6 Then
                            ReturnLabel = ((AnalogIn(1) * (5 / 1023) / analogCorrection(1)))
                            ReturnLabel = Math.Round(CDec(ReturnLabel), CInt(analogDecimalPlaces(1)))
                        End If
    <ANALOG 2 CODE>
    ElseIf Analog2Opt = 6 Then
                            ReturnLabel = ((AnalogIn(2) * (5 / 1023) / analogCorrection(2)))
                            ReturnLabel = Math.Round(CDec(ReturnLabel), CInt(analogDecimalPlaces(2)))
                        End If
    <ANALOG 3 CODE>
    ElseIf Analog3Opt = 6 Then
                            ReturnLabel = ((AnalogIn(3) * (5 / 1023) / analogCorrection(3)))
                            ReturnLabel = Math.Round(CDec(ReturnLabel), CInt(analogDecimalPlaces(3)))
                        End If
    I'm honestly baffled as to why the same raw values change to different converted values. I'm not giving up on it.. but i dont know what avenue to venture next. Did you say that MDX doesnt have the same issue? If thats the case i'll search their source to see if any special handling is done on those ports.
  4. #314
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by lasal View Post
    This is what I said
    With the temperature sensors do not have any problem.
    If you connect ΑΑ batteries then you see the problem
    PS.
    I like rrfusion very much and just want to help in debugging
    Two things spring to mind.
    In the screen shot, the second set of three have formatted as true as opposed to false, would that be relevant.
    Secondly the user is using comma seperated as opposed to decimal point seperated, not sure why that would make a difference between the two but I know it can cause weird things.
  5. #315
    Woodbridge, VA
    Blog Entries
    55
    KennyKen- I looked in my PMs and no i dont have a function for PSI. I also looked at the air suspension thread and dont see a function not built around MDX architecture. I've never used MDX, and my whole purpose in creating RRFusion was i simply dont understand MDX lol. If someone can provide me a function that converts the FB raw value to PSI i'll throw it in the plugin no problem.
  6. #316
    Nov 2004
    St Louis
    You're gonna need two equations - one for the 150PSI sensor and one for the 400PSI sensor cause they're not the same.
  7. #317
    Woodbridge, VA
    Blog Entries
    55
    thats no prob i can use the ANALOG#CORRECTION flag to specify which type it is
  8. #318
    England
    Quote Originally Posted by GizmoQ View Post
    Thanks Gizmo, i will be using a 400psi sensor as well the 150.
    So are you saying the formula for the 400 is: y = 0.0035x^2 + 1.4409x - 14.099
    Do you happen to know the one for the 150 or should i ask Greenman to see if he still has it?
    Prepping for Trax in september
    Re-Building the whole CarPC to upgrade all the software
    Whole new boot build and moulding my screen into the dash...Again
  9. #319
    Woodbridge, VA
    Blog Entries
    55
    Quote Originally Posted by KennyKen View Post
    i saw that one, but as i read it X is voltage not the raw data from the FB. Is that correct?
  10. #320
    Nov 2004
    St Louis
    Yes that is the polynomial equation that I came up with. I probably should have taken it out to the fourth polynomial, but the accuracy of the sensor above 150 is atrocious so why bother.
    The same pressure function that 2kToaster built for the 150 is here:
    5v gives you 600+ psi.
    using a 100ohm resistor for R1 of a voltage divider, you get:
    FB Voltage = 5 * (sensor/(sensor + 100))
    The pressure function models this: y = 8.4879x^3 - 27.568x^2 + 49.943x - 18.313 where y is in pressure and x is in volts.
    150psi ~= 3.29v
    Yes, that is correct.
  1. *NEW* USB Input/Output Board -- Fusion Brain
    By 2k1Toaster in forum Fusion Brain
    Last Post: 02-22-2010, 03:33 AM
  2. Replies: 15
    Last Post: 09-22-2008, 09:02 AM
  3. Noob has some biginner questions about the Fusion Brain
    By phreaknes in forum Fusion Brain
    Last Post: 04-29-2008, 03:57 AM
  4. pc reboot on sd startup
    By duanes7 in forum StreetDeck
    Last Post: 12-14-2007, 09:55 AM
  5. Replies: 5
    Last Post: 10-22-2007, 09:40 PM
