Page 33 of 48 FirstFirst ... 232425262728293031323334353637383940414243 ... LastLast
Results 321 to 330 of 471
Thread: RRFusion- My Fusion Brain plugin for RR
  1. #321
    Fusion Brain Creator
    Mar 2005
    Quote Originally Posted by KennyKen View Post
    Thanks Gizmo, i will be using a 400psi sensor as well the 150.
    So are you saying the formula for the 400 is: y = 0.0035x^2 + 1.4409x - 14.099
    Do you happen to know the one for the 150 or should i ask Greenman to see if he still has it?
    Really, it is best to come up with the equation yourself.
    These sensors are cheap and vary a good bit from sensor to sensor. You should get it, calibrate it against a known gauge, and build a curvefit from there.
  2. #322
    Oct 2009
    Anything new with this?
  3. #323
    Newbie SkyPainter's Avatar
    Jan 2009
    Chicago Area
    Where's The Beef?
    Hmmmmm. Plug-in link seems to be dead.
  4. #324
    Oct 2009
    Quote Originally Posted by SkyPainter View Post
    Its still there. You just have to navigate his directory.
  5. #325
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    41
    fixed the link
    Live mp3Car Facebook Chat
  6. #326
    Jul 2005
    OH my god sonic...!!! i just read the entire topic, this is exactly what ive been looking for, can i still run this plugin in without MDX installed? just install the plugin? i already have fusion installed within ,my car pc, im just going to update RR. and install your plugin and i should be right togo.. i noticed i have to create a CONNECT statement in my skin for it to be enabled? correct? thanks for taking the time to create this, its going to show my airbag pressure and control solenoids......
    Will i be able to add logic to .. lets say.
    Turn output 1 and 2 on,
    Untill Pressure 1 is equal to 80psi
    The turn off output 1 and 2
    anyways im pretty excited here so im just ranting lol
  7. #327
    Woodbridge, VA
    Blog Entries
    41
    Quote Originally Posted by Ryann View Post
    You do not need MDX installed. The whole reason for me creating this plugin was MDX was far too complicated for me at the time.
    in order for it to auto-start you simply need to open your exectbl.ini in the main RR folder and add an event such as:
    Code:
    "ONSKINSTART","FBCONNECT"
    And yes, you can have simple logic in the form of the rrfusion_thresholds.ini. Open that file up and look at the example for the way to set your logic.
  8. #328
    FLAC Dougw133's Avatar
    Nov 2007
    PA
    I have 2 temp sensors connected to A/0 and A/1. In RRfusion one is reading in a standard evenvalue (ie 75F) and the other with a decimal (Ie 75.6F) Why would this be?
  9. #329
    Sep 2007
    Export, PA
    If you have not already done so, decimal points are set in the ini file in the rrfusion plugin folder.
    Planning: [|||||||||-] 90%
    Purchased: [|||||||||/] 99%
    Installation: [|||||||||-] 90% (when is anyone's project ever REALLY done...)
  10. #330
    Nov 2007
    PA
    All I did was art value of 1 to the ini to add temp sensors. They act different. Ill check into it.thanks
  1. *NEW* USB Input/Output Board -- Fusion Brain
    By 2k1Toaster in forum Fusion Brain
    Last Post: 02-22-2010, 02:33 AM
  2. Replies: 15
    Last Post: 09-22-2008, 08:02 AM
  3. Noob has some biginner questions about the Fusion Brain
    By phreaknes in forum Fusion Brain
    Last Post: 04-29-2008, 02:57 AM
  4. pc reboot on sd startup
    By duanes7 in forum StreetDeck
    Last Post: 12-14-2007, 08:55 AM
  5. Replies: 5
    Last Post: 10-22-2007, 08:40 PM
