Page 34 of 51 FirstFirst ... 242526272829303132333435363738394041424344 ... LastLast
Results 331 to 340 of 502
Like Tree1Likes
Thread: RRFusion- My Fusion Brain plugin for RR
  1. #331
    Sep 2007
    Export, PA
    what i meant is in that ini file, you can define how many decimal places you want displayed for each input.
    by default the ini says 0 for A0, 1 for A1, 2 for A2, 3 for A3 and 4 for A4+
    Planning: [|||||||||-] 90%
    Purchased: [|||||||||/] 99%
    Installation: [|||||||||-] 90% (when is anyone's project ever REALLY done...)
  2. #332
    FLAC Dougw133's Avatar
    Nov 2007
    PA
    Quote Originally Posted by sxtnitehawk View Post
    Got ya!+ Thanks man,.
  3. #333
    Nov 2007
    PA
    Having an issue getting FBCONNECT to work on skin startup. I have added "FBCONNECT" to the exectbl.ini OnSkinStart chain and nothing
    Im sure I have it WAY wrong.
    Code:
    "OnSkinStart","DFXDLLCHECK||ONSCREENCHANGE||ReLock||SpeedIndicatorLoader||GreetingPlay||FBCONNECT"
    Also, any way to have RRfusion shut all Digital Outs off before exiting, sleeping, etc..?
  4. #334
    Nov 2007
    PA
  5. #335
    Sep 2007
    Export, PA
    You need to have fbconnect in the riderunner exectbl not the skin exectbl. Why are you calling onscreenchange? Rrfusion automatically saves the status of the outputs, and then everything shuts off when RR closes
  6. #336
    Nov 2007
    PA
    I tried fbconnect in rr.ini and when it didn't work I tossed it in the skin ini. What your looking at is existing code from a skin. O am not a coder that's why I'm on here asking.
  7. #337
    Sep 2007
    Export, PA
    Quote Originally Posted by Dougw133 View Post
    it has to go in exectbl in the vonfig folder not in your skin folder.
  8. #338
    Nov 2007
    PA
    Thank you that was very helpful...When I don't know I look throught ini files etc and try to find something relative before asking on here. I know nothing about code or rr code.. I saw ONSKINSTART in the skin ini and tried it out.
    That's all I needed. It worked great.
  9. #339
    Sep 2007
    Export, PA
    No problem. Glad I could help. I'm no expert with riderunner but I will gladly help anytime...
  10. #340
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Correction, though not sure why/how it seemed to work when you put it in the rr exectbl file. As far as the main exectbl file and the skin's, the way RR handles that is that the skin one can and usually does overide any of the cmd that you have in the main one. Its executed on a last match made, and seeing that the skin's tbl gets appended to the main one, any dup'd cmds would be exec'd using the skins match.
    He is not calling that, we are, for an internal startup check.
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  1. *NEW* USB Input/Output Board -- Fusion Brain
    By 2k1Toaster in forum Fusion Brain
    Last Post: 02-22-2010, 03:33 AM
  2. Replies: 15
    Last Post: 09-22-2008, 09:02 AM
  3. Noob has some biginner questions about the Fusion Brain
    By phreaknes in forum Fusion Brain
    Last Post: 04-29-2008, 03:57 AM
  4. pc reboot on sd startup
    By duanes7 in forum StreetDeck
    Last Post: 12-14-2007, 09:55 AM
  5. Replies: 5
    Last Post: 10-22-2007, 09:40 PM
