Page 35 of 51 FirstFirst ... 252627282930313233343536373839404142434445 ... LastLast
Results 341 to 350 of 502
Like Tree1Likes
Thread: RRFusion- My Fusion Brain plugin for RR
  1. #341
    Sep 2007
    Export, PA
    speaking from experience...anytime i put commands in onskinstart, onsuspend, onresume, etc they dont work if they're in the skin'd exectbl.ini...
    i dont know why, i know that the skin's file should override the main file...but for me it doesnt...
    Planning: [|||||||||-] 90%
    Purchased: [|||||||||/] 99%
    Installation: [|||||||||-] 90% (when is anyone's project ever REALLY done...)
  2. #342
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    Correction, though not sure why/how it seemed to work when you put it in the rr exectbl file. As far as the main exectbl file and the skin's, the way RR handles that is that the skin one can and usually does overide any of the cmd that you have in the main one. Its executed on a last match made, and seeing that the skin's tbl gets appended to the main one, any dup'd cmds would be exec'd using the skins match.
    He is not calling that, we are, for an internal startup check.
    I dont remember specifically why it doesnt work in the skin exectbl.ini, but it had something to do with the having to be done during a specific point in RR's routine. I think its discussed somewhere in this thread (probably a few years back)
    Live mp3Car Facebook Chat
  3. #343
    Woodbridge, VA
    Blog Entries
    55
    Latest version available at the mp3car app store. Link in my sig or post 1
  4. #344
    Sep 2007
    Export, PA
    I knew i wasnt going crazy! lol
    Quote Originally Posted by Sonicxtacy02 View Post
  5. #345
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    I will refresh my RR code knowledge today and see how relevent this is....and if found put in a fix, as skin exectbl cmds should always trump the main file.
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  6. #346
    Mod - all of it.
    Jul 2007
    Buena Park, So Cali
    When I download RRFusion from the app store, there is no file extension. Does it just go in the Plugins folder and nothing else, or am I missing something etc? Thanks.
    CAR: 2007 G35 Sport Coupe 5AT
    HARDWARE: Dell D630 w/ dock, internal 80G HD, internal 320G HD, Verizon Wireless Card, iBlue GM-2 GPS w/iGuidance, OBDPros w/DashCommand, Visteon HD Radio w/ Home Made Cable, Current Version of RR w/ DFX Skin. My Install.
  7. #347
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by drewbp View Post
    There is a problem with the AutoAppMArt at present, it's truncating all extensions.
    try adding .zip to it
    if not try .rar
    or even .exe
  8. #348
    Mod - all of it.
    Jul 2007
    Buena Park, So Cali
    I had tried .exe, and it didnt work. Thanks for the .zip suggestion, worked great.
  9. #349
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Sonic, is there any way you could add a command in the plugin to reload the RRFusion.ini? I am working on a skin that will allow you to set the inputs, name, relays and such from within the skin. The problem I ran into, is when I save the settings to the RRFusion.ini, a restart of RR is necessary.
    I tried firing FBDISCONNECT, and then FBCONNECT, but that does not reload the .ini.
    Something like "FBReload"?
    [EDIT]
    I even tried this, and it somehow still remembers the settings in memory:
    pluginmgr;disable|rrfusion||wailt;1||pluginmgr;ena ble|rrfusion
    My Fiero Build Thread
  10. #350
    Woodbridge, VA
    Blog Entries
    55
    Quote Originally Posted by JohnWPB View Post
    [EDIT]
    No idea how i missed this post but yea i'll add it.
    RRFusion is receiving a much needed update soon. I'm adding some features that make some of the existing features more accessible. Threshold Monitoring options will not be easily set via a GUI inside of RR. Monitors will no longer be limited to 1 per analog port. Threshold Monitoring will now allow commands to be run when the analog port exceeds and returns under a threshold. RRFusion will also soon be able to support multiple Fusion Brains. Lastly, i've created a new skin based on the default RR skin. Here are the images for the skins in the event you skinners want to get a grasp on the new concept.
  1. *NEW* USB Input/Output Board -- Fusion Brain
    By 2k1Toaster in forum Fusion Brain
    Last Post: 02-22-2010, 03:33 AM
  2. Replies: 15
    Last Post: 09-22-2008, 09:02 AM
  3. Noob has some biginner questions about the Fusion Brain
    By phreaknes in forum Fusion Brain
    Last Post: 04-29-2008, 03:57 AM
  4. pc reboot on sd startup
    By duanes7 in forum StreetDeck
    Last Post: 12-14-2007, 09:55 AM
  5. Replies: 5
    Last Post: 10-22-2007, 09:40 PM
